Paging suspension gurus
Discussion in 'UK Motorcycles' started by Lozzo, Aug 7, 2004.
  1. Lozzo
    I have a kind of problem with the Thunderace. If I'm cracking on a bit
    and then need to use the brakes heavily I get the back end swaying all
    over the shop. It's quite disconcerting when it happens and forces me to
    back off the brakes to slow the swaying. Now the brakes on the Ace are
    wonderful, stop on a sixpence jobs. I'd like to be able to make full use
    of them but this is hindering me somewhat. In fact it frightens the ****
    out of me, cos today I nearly hit two cars as I had to back off the
    brakes on both occassions.
    Ordinarily the bike handles well, if a little slow to turn in to some
    corners and needs alot of effort to make it do quick changes of
    direction on tight S bends. On fast sweepers it is sublime but at lower
    speeds it feels a touch nervous. I still haven't mastered roundabouts on
    it as it feels like it's going to slide away, even though I have bags of
    confidence in the tyres.
    Talking of tyres, they are Dunlop 207RR which are excellent in both feel
    and condition, pressures are as recommended by Dunlop. All suspension
    settings are as per factory. I have preload, compression and rebound
    adjusters on both ends. Forks are straight with no leaks from seals and
    rear shock still feels like there's some life left in it.
    Wtf is the matter with it?
    Lozzo, Aug 7, 2004
  2. Lozzo
    I'm no expert, but it sounds like the geometry is out somehow - like, too
    high/hard at the back or too soft/shorter springs or spacers missing at the
    front, and hard braking changes it further, from way out to fucking
    dangerous. Is the back end unusually high, have the forks been raised up
    through the yokes, was the previous owner enormously fat? Does it handle
    better with a pillion?
    First thing I'd do is make sure the suspension F and R is absolutely
    standard.
    platypus, Aug 8, 2004
  3. Lozzo
    Colin Irvine Guest
    IIRC it's still the original - now with, what, 40k miles on it?
    Colin Irvine, Aug 8, 2004
  4. Lozzo
    That's a "yes", then?
  5. Lozzo
    Colin Irvine Guest
    I'm watching you, Richard William.
  6. Lozzo
    Colin Irvine says...
    42K now. Still feels like there's plenty of damping though. Other than
    this small thing I'm really very happy with the bike, especially now
    I've welded the fairing back together and done all the paintwork.
    Lozzo, Aug 8, 2004
  7. Lozzo
    platypus says...
    Suspension is all bog-standard.
    No and no
    You'd have to ask Colin or Pat Irvine. I wouldn't like to say :)
    Difficult to say. I rarely take pillions and they are inexperienced ones
    when I do, so I take it relatively easy with them on board.
    It is.
    Lozzo, Aug 8, 2004
  8. Lozzo
    Champ says...
    Thank you kindly, Sir. looks like tomorrow I'll be taking some light
    tools for a ride-out to a favourite road of mine.
    Lozzo, Aug 8, 2004
  9. Lozzo
    Martian Guest
    Lozzo wrote:
    [snip tale of sussy woe>
    Have you set up your sag to your weight?
    This site may help
    http://www.sportrider.com/tech/146_9508_tech/
    also when was the last time you changed the oil in the forks, it would
    be a pisser to fanny about with the fork settings just now only to then
    change the oil and go through it all again.
    Martian, Aug 8, 2004
  10. Lozzo
    Martian says...
    No, I haven't changed a thing on the suspension settings, except put the
    rear preload back to factory setting. Colin, who I bought the bike from,
    is a little heavier than me and often rode long distances loaded with
    gear and a petite pillion[1]
    Excellent, thanks very much.
    I haven't changed it, yet. I may do now. I have a feeling it may have
    been done at the last service when the previous owner had it. It was
    scheduled to be done at that mileage.
    [1] That's put me in Pat's good books :)
    Lozzo, Aug 8, 2004
  11. Lozzo
    You'd better polish up the new one, or you'll be wanting this one back
    Lozzo, Aug 8, 2004
  12. Lozzo
    Colin Irvine Guest
    Heh. Looking forward to seeing it.
  13. Lozzo
    Colin Irvine Guest
    No, its a "no". I'm just a tad short for my weight.
  14. Lozzo
    Colin Irvine Guest
    You can never go back.
  15. It was somewhere around Barstow, on the edge of the desert, when the
    Wear in the swingarm?
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Aug 8, 2004
  16. Lozzo
    Martian says...
    All been checked and are in excellent condition. A small tweek of a few
    settings and it handles lovely now
    Lozzo, Aug 8, 2004
  17. Lozzo
    Martian Guest
    I would also recommend checking the rear suspension pivot linkage
    bearings and bushes for play or maybe needing a lube job, unless of
    course, you know they have been replaced recently and are moving freely.
