Paging the Adriatic-isti
Discussion in 'UK Motorcycles' started by TD, Aug 15, 2010.
  1. TD
    TD Guest
    As a safety nazi, I'm tempted to go on my jaunt in leathers plus some of those
    fancy sweat-wicking longjohns. Will it be a heat-related disaster? I can
    understand being a bit hot in towns, but on the faster parts of the journey
    (i.e. most of it)?
    My alternatives are HG Tricky II textile jacket (even hotter than leathers
    IWHT although the lining is removable), and some badly-fitting Draggin' Jeans
    kevlar jeans.
    I was looking at
    http://www.hein-gericke.co.uk/shop/product_info.php/cPath/1_15_7/products_id/7626
    as an alternative, although as a safety nazi it doesn't really float my boat.
    Anyone tried one?
    I'm normally pretty okay in the heat, for an English bloke that is.
    TD
    2000 GSX1300RX (red and black)
    Missing: SOB, Unreliable Italian exotica, cage
    - What with the Internet, it doesn't take long to feel like one is an
    - expert on any subject these days.
    TD, Aug 15, 2010
  2. TD
    mark Guest
    IME; tricky 2 with the vents open and no lining is *much* cooler than
    leathers.........
    mark, Aug 15, 2010
  3. TD
    I value comfort over any pretension of safety.
    I use leathers & EDZ wicking long johns. They are okay if you are just
    riding at reasonable speed. Better with the long johns than without for
    me in hot conditions as it reduces the chance of prickly heat on the
    back of my thighs.
    On days in the mountains I prefer just to wear jeans. Ordinary jeans.
    They are just more comfortable, especially if you are getting on/off the
    bike frequently. The only drawback is stones flicked up by the front
    wheel which hit my shins and hurt as I don't have a lower fairing on my
    bike.
    I carry a 2 piece oversuit and use this with either the leathers or
    jeans & leather jacket if it becomes too wet to carry on riding.
    I've tried the cordura stuff in the past & just don't like it on long
    journeys. I have a HG Cruise II jacket. It's great for a 30 mile commute
    in winter but I wouldn't want to wear it all day.
    wessie, Aug 15, 2010
  4. TD
    TD Guest
    I'm a safety nazi, but getting too uncomfortable isn't good for concentration
    levels, etc...
    I have the EDZ as well. Cost a small fortune but pretty hard-wearing. I'm
    never sure if wicking is a load of pseudo-science bollocks though.
    Yes, I was going to pack my waterproofs "just in case".
    Interesting. I thought you'd definitely tell me that I'd boil in leathers. I
    can always unzip a little if it gets *really* nasty[1].
    [1] Fill your boots.
    TD
    TD, Aug 15, 2010
  5. TD
    My leather jacket has 2 poppers at the top so I can undo the main zip to
    about half way and nothing flaps about. If I lean forward slightly I can
    get a nice breeze to go down the back of my neck at motorway speeds.
    I forgot to take some sunscreen on my recent trip. I used a dark visor so
    my face didn't get burnt but the back of my neck was a bit red. As you are
    going further south, you really need some factor 30 on the exposed bit
    between helmet & jacket.
  6. TD
    Colin Irvine Guest
    The only time I've worn leathers in hot weather (French Riviera) I
    took them off for a swim and couldn't get the jeans back on. Had to
    ride back to the hotel with them balanced on the tank. Now I always
    wear textiles. The good ones really breath and have vents.
    Colin Irvine, Aug 15, 2010
  7. TD
    SIRPip Guest
    I don't do heat. Not at all, not even slightly. I radiate heat, even
    when it's cold and I sweat like a mofo as soon as the humidity gets
    above 40%. I have a whole rail of summer riding gear to this end, with
    armour, vents and all sorts of hi-tech assistance.
    When I went to Chimay, I was in all sorts of minds as to what to wear
    and what to take with me, bearing in mind the luggage limitations. In
    the end the weather decided for me and I went in full waterproofs and I
    was damn glad of them in pissing rain and 50mph crosswinds in Essex and
    Kent.
    On the return trip it was a different story, as I left in full sun and
    30+ degrees. Waterproof jacket (as I had no other and black jeans were
    the order of the day. At the first fuel stop I arranged the jacket so
    I could unzip the bloody thing without slowing down and unlaced the
    boots in order to get a flow of (hot) air down around the lower legs
    and feets.
    It worked well - as I cooked, I'd unzip to halfway, then after a few
    solid insect strikes I'd zip up again for ten minutes, until I started
    to cook again. Bloody uncomfortable though, even with no lining in the
    jacket and vents open, over a T-shirt. The jeans allowed enough
    airflow to keep Betty at bay and due to the high boots there was little
    road grit impact, although there was an issue with engine heat soaking
    into the frame and becoming incomfortable on the insides of the knees.
    This last may well be less of a problem with a water-cooled machine, or
    one where the knees rest against the tank rather than the frame,
    however.
    I still nearly keeled over with heat problems, dehydration and general
    tiredness coming round the M25, though. I don't do heat.
    SIRPip, Aug 15, 2010
  8. TD
    TD Guest
    And another thing: Venice->Igoumenitsa or Brindisi->Igoumenitsa?
    I think it comes down to whether riding down the Adriatic is actually fun. I
    understand that the autostrada is not too scenic as it's inland, and the coast
    road is very slow as it goes through all the towns - plus it's extra busy at
    this time of year. Not sure if being on a bike mitigates that though.
    I'm knackered and I haven't left yet - perhaps a day sleeping on a ferry might
    not be so bad. It must be an extra 600 miles ride via the Adriatic coast - is
    it actually worth it?
    TD
    TD, Aug 16, 2010
  9. TD
    Adrian Guest
    If you want to see Italy, do Brindisi.
    If you want to get to Greece, do Venice.
    The Greek mountains, heading from Iggy over to Meteora and the East
    coast, were bloody fantastic. Great roads, great scenery. I'd spend the
    time there, and do Italy another time.
    Adrian, Aug 16, 2010
  10. TD
    YTC#1 Guest
    If you take leathers, also carry something lighter to wear.
    I now carry armoured Jeans (hood are my pref) for the heat, and will often
    have a "mesh" jacket.
    YTC#1, Aug 16, 2010
  11. TD
    TD Guest
    Well, that was the plan until I realised that leathers might be bearable. And
    don't know if I'll have room to carry leathers in rather full luggage...
    But will check out HG mesh jacket tomorrow, maybe upgrade with some Hiprotec.
    TD
    TD, Aug 16, 2010
  12. TD
    YTC#1 Guest
    Ultimtely, all you can do is have a read of what people say they do and
    decide for yourself.
    I, like others, have built up my touring choices over the years and what
    suits one person may not suit another.
    Because I now pack light, clotheswise, I have room for other stuff to make
    my life more comfortable on the road. If I am carry leathers and
    non-leathers then when not wearing the leathers they are just bungied on
    the back seat with the tent.
    I can't remember if you are going 2 up or not, if not, then all you will
    need is a tank bag and a tailpack (IMO) for kit.
    When going for a UKRM French RUn weekend 2 up on the XJR Jean and I can
    manage on the contents of the tankbag and the Ventura tail pack.
    The less you carry the better the trip will be.
    An oft quoted phrase is "pack your gear, then throw 1/2 of it away".
    Take the trip as a learning curve, and for each thing that is not right or
    goes wrong, work out how to get around that next time and for each thing
    that goes store that memory.
    YTC#1, Aug 17, 2010
  13. TD
    If you can handle the gayness, Dainese body suits are probably the best
    option for maximum protection with minimum heat. Something like
    http://www.chainreactioncycles.com/Models.aspx?ModelID=51207 I bought
    a much older version in the Dainese shop in Andorra many years ago.
    You can then just use a lightweight jacket with no armour to handle the
    windchill & rain when needed. And cos it won't have armour, it'll roll
    up small for strapping on the back when not needed.
    Krusty, Aug 17, 2010
  14. TD
    Switters Guest
    I've a mesh jacket and trousers made by Held, which were great for touring
    in Spain. I even used them over here the other week and they were spot on
    for that as well. I'd have been toast in my leathers.
    Got them from GetGeared who were bloody brilliant with their service.
    Switters, Aug 17, 2010
  15. TD
    snip>
    Unless you're going on a winter trip because you'll need all of it and
    more.
    I'd always sooner come home with something unused than sit at the side
    of the road (or on a campsite) wishing I hadn't thrown a certain item
    out of my panniers.
    Andy Bonwick, Aug 17, 2010
  16. TD
    Thomas Guest
    The half you're not going to use. Duh.
    Thomas, Aug 18, 2010
  17. TD
    YTC#1 Guest
    Doesn't matter. As long as it is not "the other half".
    YTC#1, Aug 18, 2010
  18. TD
    Jim Guest
    A circular argument that is.
    Jim, Aug 18, 2010
  19. TD
    SIRPip Guest
    Ask Cane, or Ash, or Christofire. It's a self-making decision.
    SIRPip, Aug 18, 2010
