Paging the Alfaisti
Discussion in 'UK Motorcycles' started by SIRPip, Jun 23, 2010.
  1. SIRPip
    SIRPip Guest
    A mate of mine has a problem with his GTV: the gearchange (such as it
    was, cable operated POS) went to **** in that he coudn't get reverse on
    demand. He's found the problem, which is that the moulded nylon socket
    at the base of the gearstick has split.
    The problem is that he cannot get the split socket out of the car.
    Any FOAK got a wise answer for this one?
  2. SIRPip
    http://farm1.static.flickr.com/17/20509366_f6660c76c8.jpg
    wessie, Jun 23, 2010
  3. SIRPip
    zymurgy Guest
    Following on from Wessie's useful suggestion ..
    1) Nuke it from space
    2) AG
    3) Molotov
    Paul
    zymurgy, Jun 23, 2010
  4. SIRPip
    Araldite.
    Krusty, Jun 23, 2010
  5. Qbond will put anything made of abs plastic back together. I've used it on the
    belt tensioner on my Subaru with no problems at all.
    Fraser
    Fraser Johnston, Jun 24, 2010
  6. SIRPip
    Catman Guest
    No. I't snot an issue that *I've* ever heard of. SteveH or one of the
    others may have.
    www.cuore-sportivo.co.uk
    Catman, Jun 24, 2010
  7. SIRPip
    SIRPip Guest
    I haven't had a chance to get my hands on it yet, so I'm working
    second-hand, as it were: he can see three bolts/studs, but can't get at
    the nut on the bottom. Because of this, the heads just rotate without
    loosening and he can't see any way to get at the nuts.
    I can see it'll end up with the car on its side, exhaust off, heat
    shields off and drilling through the flaming floor.
    SIRPip, Jun 24, 2010
  8. SIRPip
    SIRPip Guest
    Qbond, eh? I'll have a look at that; the problem is this socket is the
    self-lubricating high-tensile nylon stuff that as far as I know isn't
    glueable with anything. Araldite, for example, goes hard all right,
    but at the first sign of stress just cracks away from the nylon in one
    lump.
  9. SIRPip
    Dave Emerson Guest
    It's an Alfa.
    Just spray some water on it and the floor will rust through...
    Dave Emerson, Jun 24, 2010
  10. SIRPip
    Catman Guest
    Pretty sure that's not the approved way.
    IIRC there is a sort of collar around the gearstick in the floor that
    can be removed. Does that help? I could go and look at SWMBO's if I can
    get some time today.
  11. SIRPip
    Catman Guest
    It's the new GTV, not the old one.
  12. SIRPip
    petrolcan Guest
    petrolcan, Jun 24, 2010
  13. SIRPip
    Catman Guest
    It's the new GTV not...
    ahh, sorry, that was a 'joke' yes?
  14. SIRPip
    SIRPip Guest
    It's all clear now, I managed to find a download of the manual for the
    beast. I can see this turning into another one of those little jobs,
    you know. Pages 737 to 740 of 788 give the answers:
    Disconnect battery
    Remove ducting between air filter and inlet manifold
    Disconnect gearchange cables at gearbox end
    Remove several shedloads of highly pingfuckitty interior trim around
    dashboard and tunnel
    Remove tunnel unit CAREFULLY (see assembly 70 (WTF?))
    Disconnect wiring
    Hike car into air
    Remove complete exhaust system (this is not without some small caveats,
    like sensor wiring and corrosion)
    Remove heat shields
    Whip trolley jack under gearlever/handbrake assembly
    Remove all eight bolts, and their associated nuts and washers retaining
    said assembly
    CAREFULLY drop out the gearlever/handbrake assembly, complete with
    gearchange cables etc etc
    Drag it all out from under the car ... then start to dismantle that
    assembly to get at the worn/split nylon socket
    Fit new socket assembly at cost of 150 quid plus the vat
    Rebuild car, interior and exterior, underneath and in engine
    compartment. Shouldn't take more than a couple of days if the weather
    stays fine.
    Alternatively, persuade a Jubilee clip around the thing and tack it
    into place so it /cannot/ move. Should take twenty minutes.
    I suppose there's always the petrol and match solution, too.
  15. SIRPip
    Catman Guest
    Sounds like a plan.
  16. SIRPip
    Have I said recently that working on cars is potentially deeply unpleasant.
    There is a lot to be said for the Aerial Atom concept.
    Talking of which, here is an engine to wank over
    www.beststuff.com/blog/2009/06/14/500hp-aerial-atom-expected-cost-160000.html
    Hog, Jun 24, 2010
  17. SIRPip
    Adrian Guest
    <peers over at "how the **** do I remove the carbs" thread>
    Adrian, Jun 24, 2010
  18. SIRPip
    Owning a beam frame Jap multi might compare.
    Lets not mention SD's Wing...
    Hog, Jun 24, 2010
