Paging the bike electricians
Discussion in 'Motorcycle Technical Discussion' started by The Older Gentleman, Nov 12, 2005.
  1. Right, I've recently acquired a lovely old 1981 Yamaha XS650 Special.
    It's a US import (quite common over here in the UK). It's a 1981 model
    with cast wheels.
    Being a US model, it also has the headlight permanently wired into the
    ignition. When you hit the starter button, the headlight goes out,
    presumably to alleviate the load on the battery while cranking the
    engine.
    Recently, the headlight has decided to stay unlit when you turn the
    ignition on. However, the first rotation of the engine brings it up.
    If you hit the kill switch to cut the engine, the headlight stays on
    (and then goes out if you press the starter button, before re-lghting
    when the engine fires, as it should).
    If you turn the engine off with the key, and then turn it on again, the
    light stays out until the engine turns over.
    Also, under the seat is a small grey box bearing the legend Reserve
    Lighting Device. It's made by Koito and carries a serial number
    337-11720. Googling on this brings no hits. I'm assuming it has
    something to do with the headlight, because it doesn't exist on old
    UK-spec models.
    Questions:
    1. Why would the headlight stay out until the engine starts revolving?
    2. Would this Koito thingy have anything to do with it?
    3. As the bike's charging perfectly and running A-OK, should I just
    shrug and put it down to the Bad Yamaha Pixies?
  2. It's because the donor bike (which I'm currently stripping down) turned
    on its headlight with the ignition switch, engine running or not. But
    yes, I'll ignore it. I'm not worried - just curious.
  3. The Older Gentleman
    doc Guest
    Might be the start switch which has push-to-break contacts for the main
    lighting circuit.
    The following info is for a Yamaha triple; it might or might not apply to
    the XS650:
    "The triples came with a reserve lighting unit that acts as a fail safe
    device. If you are riding with the low beam on and the bulb burns out or
    there is a faulty connection, the reserve lighting unit automatically
    switches to the high beam and illuminates the indicator light that is
    marked "headlight". The same thing will happen if the high beam goes out,
    it automaticly switches to the low beam. The "headlight" indicator light is
    there to tell you that there is a problem somewhere in the lighting
    system."
    I have a similar problem with my '95 XV250. In my case, it's the start
    button not always making good contact with the lighting circuit after it
    starts. I simply push in the other end of the start switch (not the
    protruding part, but the part that's flush with the housing IYSWIM) and the
    light comes back on. Dirty contacts is my guess and someday I'll take the
    switch apart and clean it.
    doc, Nov 12, 2005
  4. The Older Gentleman
    OK, I guess there is a relay somewhere in the ignition circuit that is
    supposed to switch 'on' as soon as the ignition is turned on. Pressing
    the starter button interrupts the current to the relay so it turns into
    its 'off' position, thus switching the headlights off as long as you
    press the button. You let go, current flows through the relay again, it
    switches and the headlight comes on again.
    That's roughly when it starts charging, right?
    My guess is that either the relay is a bit dirty and the current
    flowing through it is not strong enough to switch it on, or the battery
    voltage is too low to get it to switch.
    Get your multimeter out, turn on the ignition and check the voltage at
    the battery. If it looks alright, give the grey box a friendly tap and
    see if the headlight comes on.
    Timo Geusch, Nov 12, 2005
  5. Right! I hadn't thought of that.
    OK, so that's what the gizmo does. Makes sense.
    Thanks. I think you've hit the nail on the head.
  6. The Older Gentleman
    Pantah Guest
    Hello,
    If you take a look at the wiring diagram of this XS model you can see that
    the headlight is switched on by the "Headlight relay". When the engine is
    off the relay is in its standard position. In this position it is possible
    to turn on the starter motor. When the engine runs the relay is activated by
    the yellow wire coming directly from the A.C. generator. The headlight is
    turned on but it is not possible anymore to activate the starter motor which
    is quit logical. When you cut off the engine with the kill switch the
    headlight will remain on. After you turn off the ignition the headlight will
    turn off.
    The function of the Reserve lighting device has been described correctly by
    "doc":
    switches to the high beam and illuminates the indicator light that is marked
    "headlight". The same thing will happen if the high beam goes out, it
    system."
    In addition: the high beam is switched on in series with a resitor so you
    will not dazzle any oncoming traffic.
    Greetings,
    Haro van Santbrink
    [Yamaha XS650SE 1983]
    [Ducati Pantah 600TL 1983]
    [www.xs650.nl (Sorry, only in Dutch....)]
    Pantah, Nov 12, 2005
  7. Perfect. Thanks.
  8. The Older Gentleman
    Pantah Guest
    By the way, Older Gentleman, buy a good workshop manual like the one by
    Haynes (ISBN 1 85010 921 4). Cost a few pounds but it is worth every penny.
    Greetings from Holland
    Haro
  9. I have one, actually.
    The Older Gentleman, Nov 13, 2005
  10. The Older Gentleman
    Andy Clews Guest
    Thus spake Timo Geusch unto the assembled multitudes:
    Sounds a bit like the rear screen heater in my car which is controlled by a
    relay. The heater relay will only engage when the engine is running. I
    also immediately thought of a push-to-break contact at the starter button.
    Andy Clews, Nov 13, 2005
  11. (The Older Gentleman) wrote in
    I never liked Haynes. I always went to the dealer and got the factory
    manuals. I have never been been disappointed in the factory manuals. Sure
    they cost more than the Haynes, but you do get what you pay for.
    Pierce
    R. Pierce Butler, Nov 13, 2005
  12. The Older Gentleman
    Which is why you'll commonly find Haynes manuals referred to as Haynes
    BoL (Book of Lies) around here...
    Timo Geusch, Nov 13, 2005
  13. Agree 100%.
    Haynes are pretty good, but a factory manual is worth the extra, if
    you're planning any serious work.
  14. The Older Gentleman
    Frinton Boy Guest
    I also like to have a parts list to hand. The exploded
    diagrams are handy for putting the "pingfuckits" back in the
    right order....
    Frinton Boy, Nov 13, 2005
  15. (Frinton Boy) wrote in
    Mine usually go "sproing..tink,tick,tink...shit!"
    pierce
  16. (The Older Gentleman) wrote in
    The Concours factory manual is thorough, but the coloured wiring diagram in
    the Haynes manual would be nice.
    George R. Young, Nov 14, 2005
