Paging the BMW and touring-isti: R1200GS or other tourers
Discussion in 'UK Motorcycles' started by Pip Luscher, Nov 22, 2009.
  1. Pip Luscher
    K's BIL has just asked me about a suitable bike for riding across Oz.
    He asked specifically about the R1200GS, which I have a vague idea is
    not a good choice from a reliability POV. ISTR also that some modern
    BMWs are a bit buzzy.
    He wants an upright riding position; no Sprots bikes. He'll be
    ridining about 8 days (I guess each way) and will also want it for the
    odd commute (he lives in Perth).
  2. Pip Luscher
    Fr Jack Guest
    BSA Bantam
    Fr Jack, Nov 22, 2009
  3. Pip Luscher
    SteveH Guest
    Weren't the R1100GS and R1150GS more robust?
    Something even older, like an R80GS or R100GS may be even more suitable,
    as they can be repaired with nothing more than a hammer and adjustable
    spanner.
    SteveH, Nov 22, 2009
  4. Pip Luscher
    You have me confused with someone else, sir.
    As a hardened Guzzisto, I would have suggested a Stelvio but I don't
    know enough about their reliability.
  5. Pip Luscher
    I should point out that the chap in question isn't really a garage
    monkey.
  6. Pip Luscher
    I wouldn't take an R1200GS on such a journey. They have reliability issues
    and, due to complex electronics, are less easy to fix with a bodge compared
    to earlier variants.
    The newer F800GS seems to be just as bad. All sorts of problems reported on
    UKGSer.
    Get him to do like the Wellers did for their marathon trip around Europe.
    Buy as late a model R1150GS he can find that does not have EVO brakes[1].
    Relatively simple technology that most competent DIY mechanics can fix on
    the rare accasion it goes wrong. There is a wealth of information on the
    web for every conceivable fault as the bike has been around since 1999. You
    can even get a gizmo to read the not very complex electronics
    http://www.hex.co.za/gs911/index.html with a bluetooth phone.
    In Oz, I think the Honda Afrika Twin was a big seller. This would be good
    too. Maybe an Yamaha XTZ660 if he wants something newish.
    [1] on EVO bikes the brakes won't work if the electronics fail. On earlier
    bikes, if the ABSII system fails then the brakes will still work in a
    conventional manner.
    wessie, Nov 22, 2009
  7. Pip Luscher
    I'll go for the usual trick and suggest a Yamaha Tenere.
    They're a lot cheaper than the GS and unless he wants to go for a
    fairly high touring speed it'd do the job for the touring and the
    commuting. I don't know how good they are for riding long distances on
    less than brilliant road surfaces but according to the owners forum
    everyone who's got one likes it.
    Andy Bonwick, Nov 22, 2009
  8. Pip Luscher
    I'd agree on the 1150GS if he wants a BMW.
    That's not quite correct. The EVO brakes will still continue to work but
    they will need more effort than it takes Nige to stop swearing. This
    isn't hearsay btw, I've had the electronics switch off the rear servo on
    the GSA.
    Timo Geusch, Nov 22, 2009
  9. An old, old bike now, though, so many will be tired.
    Already got my vote :)
    The Older Gentleman, Nov 22, 2009
  10. Tenere.
  11. Pip Luscher
    crn Guest
    <sniffs bait>
    <swims away>
    He needs a comfortable cruiser with the biggest possible tank range.
    A Dullville with a few extra cans in the panniers would probably be
    OK, the biggest problem is that fuel supplies are a long way apart so
    litrebike thirst is a bad idea.
    crn, Nov 22, 2009
  12. Pip Luscher
    My recollection of most non-giant traillies is a narrow seat though.
    Is this likely to be a problem on these?
  13. Pip Luscher
    I've heard a few complaints about the Tenere seat but I've not had a
    problem with it. It's got a 200 mile range and riding it that far
    without stopping isn't a chore.
    I've put a taller screen on mine to remove the buffeting that was
    present with the standard one but most other riders seem happy with
    the standard one so it's probably just me.
  14. Pip Luscher
    He *is* one of the locals. Well, he is now.
  15. I'm in Perth and selling my 650 V-Strom. : )
    You can't go wrong with the GS but it is costly bugger.
    Fraser
    Fraser Johnston, Jan 15, 2010
  16. A friend of mine has done the Nullabor 5 times on his SV1000 but he is a bit
    mad. Fuel range was only an issue on one leg and he was 1 litre short so
    carried a 5 litre fuel can.
    Fraser
  17. Bit old though. By going old you need something easy to work on because it is
    more likely to break.
    Fraser
  18. Africa twins are pretty rare here. Most touring type ADV bikes are V-Stroms,
    Beemers, KTMS, Teneres or Versys.
    Fraser
  19. No kidding. The nullabor is the most boring piece of road on earth. 2000ks of
    salt brush, emus and kangaroos that are intent on killing you.
    Fraser
  20. Pip Luscher
    frag Guest
    So if a con rod broke you'd use the adjustable spanner as a makeshift
    replacement?
    Suitable beaten into shape by the hammer?
    Which you could then use to seal the hole in the crank case by takng the head
    off, beating it into shape using two rocks, chewing the wooden handle into a
    paste to glue things together...
    frag, Jan 15, 2010
