Paging the bodgeristi - Smoothrite?
Discussion in 'UK Motorcycles' started by ginge, Aug 11, 2008.
  1. ginge
    ginge Guest
    I'm in the process of cleaningmy circa 1992 GT mountain bike frame,
    replacing bearings and the like, just to revitalise it as a useful
    runaround.
    Whilst I could go and get it stove enamled, or powder coated, it's
    probably not worth spending more than a £20 on the job. So, what I'm
    wondering is would aerosol based smoothrite be up to the job and any
    more hard wearing than normal auto spraypaint (again in aerosols).
    I'm not looking for any flashy paintwork here, just a basic plain
    colour like red or yellow.
    Any other options you can think of?
    ginge, Aug 11, 2008
  2. ginge
    antonye Guest
    I used silver smoothrite on the race fairing and it looks fine...
    from a distance. That was only because the fairing was previously
    crashed and needed filling & sanding which I spent the minimal
    time on. Applying the (rather thick) Smoothrite helped to cover
    a multitude of sins though: http://tinyurl.com/5phz32
    A few points to note:
    - it's very picky about temperature and humidity, more so than
    "standard" spray tins I found. Too hot/cold or humid and it
    will react badly when applied.
    - it can react with other paints and crackle; combined with the
    above it can create a real mess. Make sure you strip off all
    the old paint first.
    - it's very thick and the spray nozzles get clogged if you use
    it for long periods, leading to spotting. Clean the nozzles
    after each use and don't use for too long.
    - it gets *everywhere*, even more so than normal spray dust.
    A few generic spray tips:
    - wear a mask. They're about a fiver in B&Q for a proper filtered
    one and will stop you blowing coloured snot out of your nose
    for the next week
    - preparation is the key. A smooth surface before paint means a
    smooth surface once it's painted.
    - sand off any old paint then use a good primer.
    - mask off everything you don't want covered in paint dust. twice.
    - Halfrauds now sell paint "wipes" for cleaning off the surface
    before painting. These are Really Good.
    antonye, Aug 11, 2008
  3. BBQ Paint.
    Whinging Courier, Aug 11, 2008
  4. ginge
    ginge Guest
    The whole thing is going to get nitromorsed for starters, then sanded
    with wet & dry to remove the annoying bits of rust... OTOH I might yet
    say **** it, and buy a new frame my current MTB as tarting it up seems
    like a hassle, then I'd cascade it's frame down to be my road bike...
    although then I get into the annoyance of working out if I can be
    arsed sticking old 5 bolt deore XT cranks on, or if newer cranks mix
    with older 7 speed hubs... which also seems like a lot of hassle
    really. And if that's the case I may as well just throw it in the tip
    instead. :)
    Ahh no worries here, I'm planning to empty the little garden shed and
    use it as a spraying booth.
    Good idea with the mask, I'd not have thought about that.
    ginge, Aug 11, 2008
  5. I love the smell of creasote.
  6. Smoothrite goes on great, even looks fine, but you try and get it off or
    touch it up. fnar.
    More suited to gates and railings, but if you must and if it's only for
    a shite old bicycle, ok.
    GS850x2 XS650 SE6a
    "It's a moron working with power tools.
    How much more suspenseful can you get?"
    - House
    Grimly Curmudgeon, Aug 11, 2008
  7. ginge
    SteveH Guest
    Go to a proper automotive paint supplier and get a couple of cans of
    decent quality aerosol car paint plus clearcoat.
    Not hugely more expensive than cheap shit rattle cans from Halfords, but
    capable of producing a 'factory' finish.
    (There's an article in this month's 'Practical Classics' magazine where
    they did an invisible repair to a Mercedes SLK rear 3/4 panel and door
    with such cans)
    SteveH, Aug 11, 2008
  8. Just one more teeny little mouthful...
    "Creosote", btw.
    GS850x2 XS650 SE6a
    - House
  9. ginge
    Tosspot Guest
    I might be tempted to get a quote for a rough and ready spray job. I
    did it for a couple of my frames a long while back and it's going to
    cost more than 20 squids, but may come in far enough under 50 to make it
    worth while.
    Failing that, black smoothrite type stuff is what I would do.
    Tosspot, Aug 11, 2008
  10. ginge
    ginge Guest
    Any idea where I find such a place? Do most cities have them?
    ginge, Aug 11, 2008
  11. ginge
    SteveH Guest
    To be honest, I don't know.
    There's a company that calls itself a 'Vehicle Refinishing Supplier' in
    Derby - but you could also try this:
    http://www.paints4u.com/ProductDetails.aspx?productID=5264&Mainselection
    =4
    A proper aerosol should have a nozzle that can be rotated 90 degrees to
    give a horizontal or vertical coverage pattern with no splatter, unlike
    a cheapo rattle can.
  12. ginge
    search yell.com for motor factor and then phone to see if they do paint.
    Many do. 11 listed in Derby
    wessie, Aug 11, 2008
  13. ginge
    malc Guest
    In the morning?
    Malc
    I said "Oh pretty maid I think you done me wrong"
    "You just wait there boy, I'll do you right after evensong"
    Sid Kipper
    malc, Aug 11, 2008
  14. ginge
    Beav Guest
    It won't cost much more than 20 quid if it REACHES 20 quid to get a frame
    powdered. I paid 60 for a bike frame (LC 125), swingarm (in a different
    colour o the frame), all the bracketry for the ancillaries, the battery
    carrier, side stand and a centre stand I had lying around for a VN.
    Aerosol Smoothrite will work too, but don't leave it more than an hour or
    two between coats or it'll up and die on you, or transform itself into crazy
    paving.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 12, 2008
  15. ginge
    Beav Guest
    And you *actually* believe they did that with rattle cans?
    <boggle>
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 12, 2008
  16. ginge
    Nige Guest
    I have seen some very good results with them, but you really have to
    know how to d it. Like you say, you'll never get a decent finish with it
    like factory etc.
    Nige, Aug 12, 2008
  17. ginge
    Beav Guest
    But apparently *they* can. On top of all that, single component lacquer is
    absolute shite for staying shiny and looking good, so even if the finished
    job looks good on the day, it certainly won't in a week.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 13, 2008
  18. ginge
    ginge Guest
    None of this may matter, I just discovered the bottom bracket
    cartridge the bike takes with it's current crank (73x127) is
    discontinued so I'll also need a new crank, and if I'm spending money
    I'd rather do it on a new frame for the newer bike and cascade things
    down instead.
    Shame really, as I was quite looking forward to having a proper early
    90's GT on the road again, but with modern forks.
    Then again, I might just build it as a singlespeed instead.
    hmm.
    ginge, Aug 13, 2008
  19. ginge
    Ben Guest
    Are you certain on those dimensions? It's not a 68mm shell? I
    thought all GTs were 68.
    Isn't it a 1in headset? In which case you'd have a job running modern
    forks.
    Just buy a new limited edition GT Zaskar frame...
    http://www.bikemagic.com/news/article.asp?UAN=5592&v=1
    ....it'll look classic but take modern stuff.
    Ben, Aug 13, 2008
  20. ginge
    ginge Guest
    Positive. The 1992/93 Richter 8.0 was a 73. I took the measurements
    directly from the BB that I'd removed. I think they settled on 68's
    shortly after that, when the Avalanche took the spot that the Richter
    left.
    The problem turns out to be pretty much all down to the straight arms
    on a 1992 Deore DX crank, they're not kicked out at all so need a
    stupidly long axle, however to get a look at whether a modern crank
    would fix the problem I popped an arm off the Truvativ FiveD from my
    other bike into place and they offered loads of clearance, so it's a
    cheap fix really.
    I might use this as an excuse to put nicer kit on the offroad bike and
    use the cast offs on the GT.. I'd like full shimano on the offroad
    setup.
    Nope. It's definitely a 1 1/8 (inside radius of the head tube is 34mm)
    - that's why finding threaded forks was tricky when I did my quick
    bodge last year, but it'll take anything modern.. the decision now is
    do I bung some Kona P2's on and go for a full rigid, or do I cascade
    the forks off my other bike and upgrade that.
    To be fair, the only modern thing I won't be able to install is a rear
    disk or V-brake as I'll have the Shimano U brake on the back with it's
    non standard mounts. But I've never had any issue with it's stopping
    power and it all adds to the retro charm.
    ginge, Aug 13, 2008
