Paging the bodgeristi
Discussion in 'UK Motorcycles' started by ogden, Feb 18, 2007.
  1. ogden
    I've got a frame with yokes and forks attached.
    I want to remove the forks and yokes as a set, without taking it all
    apart. Removing the top yoke is easy, but how on earth do I get the
    bottom one off? Does it involve a lot of walloping?
    I also need to remove the ignition barrel, which is attached to the top
    yoke with some fearsome shear bolts by the look of it. Any tips?
    TIA.
    ogden, Feb 18, 2007
  2. ogden
    ogden says...
    Take the top yoke off, then undo everything underneath it that has a
    screw thread on it. Seriously, you'll find a large nut with cut-outs in
    the outer circumference under the top yoke, undo that and the whole lot
    will come away.
    Lozzo, Feb 18, 2007
  3. ogden wrote
    I believe so. Others with a clue may have different suggestions.
    Ask your local scrote.
    steve auvache, Feb 18, 2007
  4. Once you have the top yoke off undo the nut under it at the top of the
    bearings. Forks will fall out.
    eric the brave, Feb 18, 2007
  5. ogden
    John H Guest
    You can leave your compendium of hammers in the drawer for this one.
    John H, Feb 18, 2007
  6. ogden
    Use a slim wood chisel to make screw slots in the 'heads' of the shear
    bolts. The slots don't need to be too deep as the bolts will easily
    unscrew.
    That was the method I used on bangers to remove steering barrels and,
    incidentally, it also worked fine on darsy's ZX7 thing.
    sweller, Feb 20, 2007
  7. ogden
    OK, there's a round nut with four cutouts in it under the top yoke. Not
    something I can just wave a spanner at - does it need a special tool or
    something, or am I missing something obvious?
    ogden
    sv650sk5 (chick wheels) cg125 (dead wheels) zx7r (hasn't even got
    wheels)
    buy tat here: http://search.ebay.co.uk/_W0QQsassZdr.daifQQhtZ-1
    ogden, Feb 25, 2007
  8. ogden
    Cheers. Now I just need to buy a chisel...
    ogden
    wheels)
    ogden, Feb 25, 2007
  9. ogden
    SD Guest
    Sir needs a castle socket, sir does. Or summat.
    The Honda version is >£50
    A C-spanner will do, but if you're not planning to use it again, a
    drift anna big amma will suffice.
    | ___ Salad Dodger
    |_\_____/_| ..88045../..23727.../..31893.
    SD, Feb 25, 2007
  10. ogden
    Ah, right. That makes sense. Just need to work out what size, a quick
    google turns them up at around 35-40 quid a pop depending on size.
    What, and pass up an opportunity to but a tool I'll probably never use
    again? NEVER!
    ogden
    wheels)
    ogden, Feb 25, 2007
  11. ogden
    ogden says...
    Hein Gericke do an adjustable C spanner. The one I have works a treat on
    shock absorbers and head race nuts. It costs about 12 quid.
    Lozzo, Feb 26, 2007
  12. ogden
    That sounds much more reasonable. Might swing by there tomorrow for a
    gander.
    Ta.
    ogden
    wheels)
    ogden, Feb 26, 2007
  13. ogden
    ginge Guest
    just drift it off with an old screwdriver and a hammer.. it's not like
    you'll need to put the bike back together again.
    ginge, Feb 26, 2007
  14. ogden
    <looks at thread title>
    <reads posts>
    EUREKA!
    ogden
    wheels)
    ogden, Feb 26, 2007
  15. ogden
    You need to drift it out with any old bit of steel lying around if
    you're breaking it for spares but a piece of softer material such as
    copper or aluminium is your best friend if you don't want to damage
    anything.
    Andy Bonwick, Feb 27, 2007
  16. ogden
    Or a small flat-head screwdriver. One gentle tap and it came loose, one
    wiggle and the whole lot dropped out, along with the headraces. Job's a
    good'un.
    ogden
    wheels)
    ogden, Feb 27, 2007
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, ogden
    Depends. If you want to put it back together you'll need a C spanner. If
    you just want to strip it, use a punch and 'it it wivva 'ammer.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Honda GL1000K2 (Falling apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Wicked Uncle Nigel, Mar 2, 2007
