Paging the Bonwickisti and engineers
Discussion in 'UK Motorcycles' started by TOG, Dec 14, 2006.
  1. TOG
    Pete Fisher Guest
    I did a 'Motorcycle Maintenance' night school course many, many years
    ago. It was held in a school metalwork room and gave use of the
    machinery under supervision. Most of the people there were actually
    tuning racers. Would you believe I upped the CR on a two stroke by
    draw-filing the head? It worked too - for a while. Not to be compared
    with my CR ratio experiment on the 29 Raleigh [1]. A piece sawn off
    another old piston and bolted to the flat top Panther job I had modified
    to fit.
    This actually proved the principles[1] and I later had a proper bodge
    done by an alloy welder as a foreigner at Swan Brand in Brum [2].
    [1] Not as alternative thinking as the boke who achieved this by
    stretching some vintage single motor's con-rod allegedly.
    [2] That it went much better as long as it was on dope, but it was
    fucking impossible for me to bump start with the very 'slow' cam timing
    it had. Even though I had the cams re-profiled by Bruno Engineering.
    [3] Spot the motorcycle connection.
    | Pete Fisher at Home: |
    Pete Fisher, Dec 14, 2006
  2. TOG
    Chris H Guest
    That would be a manager.
    Chris H, Dec 14, 2006
  3. TOG
    SD Guest
    We've got enough cleaners already, tyvm.
    | ___ Salad Dodger
    |_\_____/_| ..87845../..23037.../..31893.
    SD, Dec 14, 2006
  4. TOG
    Beav Guest
    I can't live, but the fucker did.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 14, 2006
  5. TOG
    SD Guest
    Andy's no Cyd Charisse, either.
    | ___ Salad Dodger
    SD, Dec 14, 2006
  6. TOG
    Well, I did Metalwork in school. I *loved* the forge, heating up bits of
    iron and beating them into different shapes. Hmm...
    platypus, Dec 14, 2006
  7. TOG
  8. TOG
    muddy cat Guest
    Phoowar.
    muddy cat, Dec 15, 2006
  9. TOG
    Oh come now the latter was a failure
    Hog, Dec 15, 2006
  10. TOG
    On 14 Dec 2006 04:00:59 -0800, TOG@toil,
    This would be the way to go but unless your local college do short
    'starter' courses then you'll be starting next autumn.
    That's the best place to start from because you'll not be starting
    with an "I already know that" attitude.
    You'll get in a right mess with welding until you understand something
    about what it is you're trying to weld so do the welding after you've
    done a bit of machining. Machining will teach you about materials and
    their properties very quickly and you can progress from there.
    I'm sure Nigel will tell you where to get dinky little cnc mills from.
    His is small enough to be hidden away in the house.
    Only if you're stupid...
    Get an offer of an apprenticeship.
    Andy Bonwick, Dec 16, 2006
  11. Unfortunately, that means ditching the daytime job.
    The Older Gentleman, Dec 17, 2006
  12. TOG
    On Sun, 17 Dec 2006 12:47:41 +0000,
    It's a **** isn't it? I had to jack in my paper round when I started
    my apprenticeship.
    Andy Bonwick, Dec 17, 2006
  13. TOG
    Andy Bonwick says...
    My paper rounds paid £3 a week more than my apprenticeship.
    Lozzo, Dec 17, 2006
  14. TOG
    Most people who went through an apprenticeship could have earned
    considerably more in a different job with no qualifications at all.
    Short term.
  15. TOG
    Ah*ha*!.
    A self-confessed forger.
    Pip Luscher, Dec 17, 2006
  16. TOG
    It's not the only thing I've confessed to.
    platypus, Dec 17, 2006
  17. TOG
    peter Guest
    Someone at my old skool used their metalwork class time to forge a
    master key to the whole new block.
    peter, Dec 17, 2006
