Paging the broadbandi
Discussion in 'UK Motorcycles' started by TOG, Nov 15, 2006.
  1. TOG
    TOG Guest
    Strongly suspect that Pipex is giving me the run-around, but wtf.
    Having a problem with dropping connections, regula as clockwork, around
    7-8pm most nights (ie: peak time). Netgear Gateway four-way
    modem/router is connected to a wireless access point, and wireless
    connection to the computers downstairs. All lights green on the
    Gateway, but connections just seem to freeze at peak hours. Switching
    the pooter on and off usually sorts it.
    OK: BT phone point is by the front door. Computers are at the back of
    the house. A phone extension line runs from the BT point to the back of
    the house. Then there's a microfilter for the phone, which lives beside
    the computers. Cat5 cable from the extended phone connection to the
    modem/router; Cat5 connection to the wireless point, which is right by
    a window.
    My feeling is that given the peak-time regularity of the failures, it's
    a Pipex issue. Pipex reckons that this long a run of phone line doesn't
    do it any favours, and at peak times the line can't hack it. Pipex say
    I'd be better off connecting the modem/router directly to the BT point.
    Trouble is, if I do that, then my daughter's PC (upstairs) is out of
    range of the wireless point (which is why it's by the window at the
    back of the house).
    Comments? Suggestions?
    TOG, Nov 15, 2006
  2. wrote
    For diagnostic purposes you want to reduce the number of links in the
    chain to a minimum. This can be as simple as a dedicated period of
    testing by doing things like:- try it everyday for a week with different
    puters/network bits turned off or just having a single machine and
    bugger all else plugged in where BT enters the house. Or combinations
    of the above. I'd go for the second option if it was my belief that
    pipex were at fault.
    steve auvache, Nov 15, 2006
  3. TOG
    simonk Guest
    Could be anything, though more likely to be a BT issue rather than a
    Pipex issue if it's not something in your house.
    Long runs of extension cable are always a nightmare, and this isn't
    helped by the fact that telephone extension cable is often of dubious
    provenance and unknown quality. I would try their suggestion, even if
    it means your daughter has to go without broadband for a week or so.
    In any case, at £80 a visit, they aren't going to send a BT engineer
    to investigate your line until you've thoroughly eliminated all
    possible sources of problems in your house.
    Might be worth having a think - is there anything that switches on at 7
    or 8 pm in your house - central heating boiler, microwave, lathe, MRI
    scanner? Peak BB usage time tends to be much later in the evening,
    post 10pm, so it's unlikely to be a bottleneck at Pipex at that time.
    simonk, Nov 15, 2006
  4. TOG
    TOG@toil, , <>
    wrote in
    snip connection problems
    Are all the computers wifi or are some connected to the router physically?
    If the former then you might be getting interference from a neighbours wifi
    system used at peak time. Others here have had the problem and the solution
    is to switch channels on your wifi access point.
    If the latter then do as Steve says. Remove as many variables as possible
    i.e. start with 1 computer hard wired into the BT master socket using very
    short cables.
    wessie, Nov 15, 2006
  5. Might be worth having a think - is there anything that switches on at 7
    When I used Pipex dial up, it regularly slowed to buggery at about 8 ish at
    night. We - me and other users - suspected server and internal network
    issues. Sort of implied that their peak was about 8 and after?
    Ali
    Alison Hopkins, Nov 15, 2006
  6. TOG
    Tim Guest
    [snip]
    Something similar happened the last time BT upgraded the line. The
    solution was to remove the house internal extension wires after the
    point the BT line terminates.
    Tim, Nov 15, 2006
  7. TOG
    Colin Irvine Guest
    Are you on a rate adaptive line? If so then it's quite possible that
    additional noise in the evenings (as more users come online, street
    lights fire up etc) is causing your line to disconnect - nothing to do
    with Pipex. As others have said, try reducing the noise within the
    house by reducing connections and line length.
    Colin Irvine, Nov 15, 2006
  8. TOG
    Steve Parry Guest
    Get a USB wireless adaptor for your main PC thereby junking the long line.
    I have Dell USB wifi adapter I got from ebay for my daughters PC, cost
    buttons and saved the hassle of cabling to a back bedroom. Plus if I want to
    be a git and stop her internet I can pocket the device :) [1]
    [1] not that its happened yet but the options there.
    Steve Parry, Nov 15, 2006
  9. TOG
    gomez Guest
    <TOG@toil>; <>;
    In conjunction with what others have said it may be worth trying better
    filters. The ADLSNation XF-1e can be recommened:-
    http://www.adslnation.com/products/xf-1e.php
    Fixed a similar problem for me that started after I went from a 1Mbps
    connection to 2Mbps connection. Now on Max synched at 6.7Mbps and it is
    still doing the job.
    gomez, Nov 15, 2006
  10. TOG
    TOG Guest
    That's possible. The wireless point is by the window that faces towards
    their house. How does one switch channels on a wifi point, then?
    TOG, Nov 16, 2006
  11. TOG
    TOG Guest
    What's a rate adpative line?
    TOG, Nov 16, 2006
  12. TOG
    Pete Fisher Guest
    You change the channel number via the router configuration screen.
    It will depend on your router, but prolly by 'Wireless Settings',
    'Configuration' then a spin box to change the channel number.
    You then have to change the channel setting to match for each Wireless
    adapter on your PCs. Exactly how may depend on which adapter (dedicated
    config application) or with control panel network settings.
    SWK will be along soon.
    | Pete Fisher at Home: |
    Pete Fisher, Nov 16, 2006
  13. TOG
    peter Guest
    Not me obviously. No way or need to set channel for each adapter I
    think.
    Bad Form...
    A quick experiment revealed that this laptop which is set to
    automatically detect networks quite happily reconnected after a channel
    number change on my router without further configuration. This Sony
    sytem uses a PCMIA adapter and is set to use windows to control
    wireless network settings and any available network BTW.
    peter, Nov 16, 2006
  14. TOG
    Ben Guest
    their house. How does one switch channels on a wifi point, then?[/QUOTE]
    It'll be somewhere on the configuration screen for the router.
    Also worth downloading NetStumbler or similar for your Mac) to snoop
    around the neighbours networks first to find out what channel they're
    running on. Then pick on as far away as you can in the numbering.
    Ben, Nov 16, 2006
  15. TOG
    Dan White Guest
    Typo corrected.
    Dan White, Nov 16, 2006
  16. TOG
    Colin Irvine Guest
    Usually advertised as "MaxDSL" or similar. It means that your modem
    and the exchange determine the rate between them based on your line
    quality, in particular signal-to-noise ratio.
    Colin Irvine, Nov 16, 2006
  17. It's a line where the rate is adaptive.
    HTH.
    Phil
    Phil Launchbury, Nov 17, 2006
  18. Are you sure its not "They can charge you what they like"?
    eric the brave, Nov 17, 2006
  19. SOP for most UK ISPs..
    Phil
  20. Ah, I got something wrong. Of the two machines downstairs, one is
    wireless and the other is connected to the modem/router by cable. And
    both go AWOL together. So it's not the wireless point. It has to be the
    modem/router or upstream of it.
    Does this make a difference, and any more suggestions?
    The Older Gentleman, Nov 18, 2006
