Paging the builders
Discussion in 'UK Motorcycles' started by Simon Wilson, Mar 29, 2010.
  1. Rough stone can be repaired but its a job for the experts and not
    cheap , usally only done if the walls part of a listed structure
    steve robinson, Mar 29, 2010
  2. Simon the building or the wall hasnt got a listed status has hit
  3. Is the wall supporting a lateral load (ground higher oneside than the
    other)
  4. Simon Wilson
    Dave Emerson Guest
    and if the wall falls down, Simon will be overlooked...
    Dave Emerson, Mar 29, 2010
  5. Simon Wilson
    Thomas Guest
    Hire a pro, it'll be cheaper in the long run. It's not a one-man-job,
    so find someone who knows more than you.
    Thomas, Mar 29, 2010
  6. He wont need a headstone though :)
    I'll get my coat .
  7. Simon Wilson
    Simon Wilson Guest
    The latter.
  8. Simon Wilson
    Simon Wilson Guest
    Yes. You can see a person standing behind the wall. Ground level the
    other side is about the same height as the roof on the lean-to building
    you can see on the side of the house.
  9. Oh dear....
    doetnietcomputeren, Mar 29, 2010
  10. Simon Wilson
    Simon Wilson Guest
    Wassat then? Is that that stuff that's sort of armco-like cross section?
    Has to be pile-driven[1] in?
    [1] paging TOG
  11. Looks like a job for S W *really* K. Not DIY at all.
    The Older Gentleman, Mar 29, 2010
  12. Simon Wilson
    mark Guest
    ****. That makes a difference; I'd say it needs rebuilding.
    So there's a difference of about 8' ?
    The old rule of thumb for a gravity wall is that it shouldn't support
    and active load of more than a third of its active height (basically the
    difference between the ground levels). (1).
    So that wall should be nearly 3 foot thick by rights...
    That's going to make an awful mess when it comes down
    I'd call the buttress plan a bodge; sorry.
    You'd be taking a risk working under it.
    There will be very little warning when/if it goes (2)
    1.This rule is out of the window if there is a surcharge such as the
    ground sloping up from the wall or parking bull dozers behind it etc)
    2. I know of a few walls that have been bulging scarily for
    years.................
    mark, Mar 29, 2010
  13. That's the stuff, but I didn't know how long a wall it was, until now.
    Cost a bit, that will. Still, it might be cheaper than an insurance
    claim from a squashed passerby.
    Another way - drive some girders in on end and fill in the gaps between
    with concrete panels, railway sleepers, etc.
    Grimly Curmudgeon, Mar 29, 2010
  14. Simon Wilson
    zymurgy Guest
    Should be loads of out of work brickies around IWHT .. ?
    Paul.
    zymurgy, Mar 29, 2010
  15. Simon Wilson
    Simon Wilson Guest
    Something like that, maybe a little less.
    It's probably more like 2' thick.
    No there's nothing extra there, but I suspect the snow/rain this winter
    has helped put more load on it. At least it's completely porous.
    It's hard to tell how fast it's moving - I might glue some glass bits
    on some of the cracks. The wall's probably > 100 years old.
  16. Simon Wilson
    Simon Wilson Guest
    I guess fence posts and larch lap wouldn't cut it.
  17. Simon Wilson
    Pete Fisher Guest
    'Tell-tales' would be a good idea. Often fixed to buildings near sites
    were blasting is going on to see if cracks are 'active'.
    We used to get a lot of complaints alleging building damage from drop
    forging. Strange how the houses were thought to be in danger of
    collapsing, but the forge building had survived for a century right next
    to the 'ommers.
    Still - at least you will have 'RC' cover if it drops on a visitor.
    I've just had to send a 'bon pour accord' email to have the hot water
    tank at 'the chateau' replaced. Despite being fully drained down this
    winter has finished it off. TBF, it has leaked for a while whenever it
    was re-filled, and the joint on the plate thing at the bottom had been
    resealed a couple of times. Not a good idea for water to be dripping on
    to the heater connections with a tenant sitting on the bog just next to
    it.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 29, 2010
  18. Simon Wilson
    mark Guest
    mark, Mar 29, 2010
  19. You need serious support then , i suggest you get a professional to
    advise
    Its been years since i was involved in anything like that and times
    change . We had to have the soil at the back of the wall dug out ,
    graded back and a large concrete L shaped structure installed to
    retain the soil , had to install land drains to then backfill
    steve robinson, Mar 30, 2010
  20. That might not work as thw whole wall might be moving .
    you need to put markers on the wall every few feet and measure back
    to a fixed point you know is stable , personally i would call in a
    surveyour who will have the correct kit to do the job
