Paging the cage air-conisti
Discussion in 'UK Motorcycles' started by Simon Wilson, May 7, 2007.
  1. Simon Wilson
    Simon Wilson Guest
    I have got a BMW cage that leaks all of its gas out in a matter of days.
    When I had it re-gassed for the first time this year, the guy that did
    it noticed that the condensor (auxiliary) fan wasn't working. He thought
    it wouldn't be a problem unless I was stationary for long periods of
    time. A couple of weeks later all the gas was gone. So, I fixed the fan,
    had it re-gassed again, and he also bunged in some leak-fixer stuff.
    That was four days ago. All the gas has gone again.
    Both times he has vacuum and pressure tested the system, and there are
    no obvious leaks. (Second time around, under pressure test, we thought
    the pressure was dropping -ever- so slightly, but it was really hard to
    tell.) Both times he has also added the fluorescent leak indicator stuff
    - but there is no sign of any leak.
    How can I find out where it's leaking? Can anyone recommend someone that
    might be able to fix it, Newbury/Berks area?
    TIA
  2. You soft fucking tossers are all the fucking same. This is Britain ffs
    the last thing you need is fucking air con. Open a fucking window.
    steve auvache, May 7, 2007
  3. Simon Wilson
    mb Guest
    mb, May 7, 2007
  4. Simon Wilson
    SteveH Guest
    Look in the Yellow Pages for a mobile aircon 'man with a van'.
    They put a dye in the system to find leaks.
    SteveH, May 7, 2007
  5. Simon Wilson
    Greybeard Guest
    Being an ex-AC engineer, IMHO it is bloody nigh impossible to find a leak on
    a car system.
    You'll probably find that the evaporator is leaking very slightly, or a
    connection near it. This is normally jammed up under the dash board in with
    the heater matrix. If you can get in there with a sniffer you might be lucky
    to confirm this. You still won't be able to fix it without removing half the
    car to get to it.
    The chances of seeing the pressure drop on a gauge is unlikely as there is
    only a few ounces of refrigerant in the system and if it takes 3 or 4 days
    to bleed away you would have to sit and watch the gauge for a few hours.
    Best take it to Mr BMW and let them have a look if it's a valuable car. They
    "may" have a chance of finding the leak as they do know the weak spots.
    HTH.
    Greybeard
    FLHTCUI UK-07 Mk II
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, May 7, 2007
  6. Simon Wilson
    Simon Wilson Guest
    It does thanks, confirms my findings so far. Not what I wanted to hear
    of course. I'll see what my man with a van guy says when I tell him it's
    all leaked out again. He's been pretty helpful so far.
  7. Simon Wilson
    Gyp Guest
    After the aircon packed up on the Skipda a while back I took it to one
    of the local places (Cheltenham) that's got a good rep for fixing
    aircon.
    The cursory investigation peering through the covers 5 mins before they
    closed led to a "looks like the end has sheared off of the pump... it'll
    set you back about £430 all in... but we can't be sure until we've had
    it up on the ramps and taken the covers off"
    Not that I wanted to spend £430, I dropped it in to them.
    3 hours later, call to say it's done.
    Turns out the nut had dropped off the end of the shaft and the pulley
    wheel had fallen off. Nut and pulley wheel were sat there in the
    under-tray. They took off the compressor and reattached the pulley
    wheel, checking the shimming was still OK. The compressor was lubed,
    re-fitted and the system gassed and checked.
    Total bill, £70.50.
    What impressed me most is that they could very easily have shoved a new
    compressor on and charged me the £430, but they didn't. Any other work I
    need doing, I'll not hesitate to go there again.
    Not entirely local, but if you want their number, e-mail me.
    But in the mean time, open the window.
    Gyp, May 7, 2007
  8. Simon Wilson
    Monkey Guest
    From the little I know about aircon systems, I believe it won't work very
    well at all without the fan running - normal airflow due to the car's
    movement just isn't enough. Shouldn't damage the system though - there
    should be over / under pressure cutoffs to protect it.
    Monkey, May 7, 2007
  9. Simon Wilson
    Simon Wilson Guest
    e-mailed
  10. Simon Wilson
    Simon Wilson Guest
    Yes that's definitely the case. In the brief period it was all working,
    it was much cooler than without the fan, even at high-ish motorway speeds.
  11. Simon Wilson
    HVB Guest
    What model is the car?
    If you haven't already, have a look at the appropriate forum over on
    http://bimmerboard.com.
    It might be a common fault - a handy thing to be aware of if you end
    up going to Mr BMW and it could also help your man with van guy if you
    can tell him where to start looking.
    HVB
    HVB, May 9, 2007
  12. Simon Wilson
    Simon Wilson Guest
    'tis an E38
    I have looked on E38.org - doesn't appear to be a common fault. 30+
    hours to get to the evaporator if it turns out to be that!
    Mr. Man with van is going to come back with his super sniffer next time,
    so perhaps he will get lucky.
    Simon Wilson, May 9, 2007
  13. Simon Wilson
    Dan White Guest
    WTF?! It can't have taken that long to assemble the car in the first place.
    Dan White, May 9, 2007
  14. Simon Wilson
    HVB Guest
    Very nice - I've had two, but never had this problem with either.
    Ouch ouch ouch ouch!
    Hope so! Good luck.
    HVB
    HVB, May 12, 2007
