Paging the Desalinisationisti
Discussion in 'UK Motorcycles' started by jackhackettuk, Jan 7, 2007.
  1. So what's the score then?
    Just been reading up on the ongoing drought issues Australia... like
    them, we're an island surrounded by water, and yet we also have water
    shortages.
    Why not build a load of desalinisation plants?
    Is it down to something along the lines that they're bloody dear to
    build / run vs how much fresh water you'll actually get out of one, or
    is there another reason why they're not adopted on a much wider scale?
    TIA
  2. jackhackettuk
    Nige Guest
    Depends on what type of desalination you use, I have worked for a
    company that made just this kind of thing. I designed the control
    systems. The reverse osmosis type systems work by forcing water through
    a semi-permeable membrane, the size of the holes (tiny, microscopic!) in
    the membrane determine what come out the other side. water moleculkes
    are very small, so most stuff gets stripped out. This can be a problem,
    as you do get rid of the salt, but you get rid of everything else too.
    The water produced is actually very pure to the point of actually
    attacking the stomach lining so it has to be dosed with all sorts of
    chemicals to enable it to become even half potable.
    We did desalination plants for the QE2, the Cunard Princess & Countess.
    We did also do a big plant for Saudi Arabia too.
    They are very expensive to buy & run, the membranbes are horrifically
    expensive & they break down a lot.
    Interestingly enough, a lot of low alchohol beers are made using the
    self same process. we had a lot of 'fun' at Vaux, Gales & Mansfield
    Breweries.
    It's a non starter for this type of unit as it just does not put out
    enough water for the cost & headaches.
    There are other types of desal, but they are all set by big problems of
    thier own.
    Ta
    Nige
    Nige, Jan 7, 2007
  3. Cost
    The Older Gentleman, Jan 7, 2007
  4. jackhackettuk
    Plus, they'll lose half the water in transit anyway.
    Timo Geusch, Jan 7, 2007
  5. jackhackettuk
    muddy cat Guest
    They're only Aussies.
    muddy cat, Jan 7, 2007
  6. jackhackettuk
    They had (have?) one in HK. Huge power consumption, apparently.
    Pip Luscher, Jan 7, 2007
  7. For different reasons. Australia gets FA rain, we get plenty but most of
    it runs off into the sea too quickly. All the old slow-moving rivers
    have been straightened and the flood plains built on, and the land has
    been too well drained over the last 50 years or so. As a result the
    underlying natural water tables don't really get a chance to replenish.
    Some areas get less rain than others, of course, but overall there's
    huge amounts of water fall on the British Isles.
    Grimly Curmudgeon, Jan 7, 2007
  8. jackhackettuk
    Beav Guest
    There's an upside to living oop 'ere then.
    It's usually been the cost IIRC.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 7, 2007
  9. jackhackettuk
    I don't know why we don't just convert Scotland into a big reservoir.
    We /could/ relocate the people first, but there hardly seems any point.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Jan 8, 2007
  10. jackhackettuk
    gazzafield Guest
    It seems like I've been driving through a reservoir of late. I don't need a
    car or a bike, it's a speedboat next. Place will be like Venice (without
    the architecture) if this keeps up.
    gazzafield, Jan 8, 2007
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, Krusty
    I wouldn't bother. They'll only bang on about "clearances" for fucking
    centuries. Kindest all round just to let it come as a surprise. I
    suppose we could cut the tax on Buckfast a few weeks beforehand so that
    they'll be sedated and wouldn't suffer.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Wicked Uncle Nigel, Jan 8, 2007
  12. jackhackettuk
    DR Guest
    ITYF that those parts of Scotland which are suitable for containing
    water already do. The rest of it tends to make water go into those
    areas quite efficiently.
    I'd just like to point out that the part of England in which I live
    had sufficient rain to maintain about 95% capacity in its reservoirs
    last year. If anything, during my lifetime it's only going to get
    wetter here. I own waterproof clothing.
    DR, Jan 8, 2007
  13. jackhackettuk
    Take off, orbit, nuke, repeat as necessary.
    Krusty
    Krusty, Jan 8, 2007
  14. jackhackettuk
    That's a lot of pipe to lay, as they say. Far easier would be to use
    the M25 as a foundation for a <shrugs> 30m high wall, then to divert a
    couple of decent sized rivers to fill it to the brim. Boat trips to
    the sticky-out bits could be an added touristy bonus, but the South
    East would never be droughted again.
    Pip, Jan 8, 2007
  15. jackhackettuk
    SD Guest
    It's the wrong shape, shawly?
    You'd have to put a wall all the way round the outside.
    | ___ Salad Dodger
    |_\_____/_| ..87918../..23274.../..31893.
    SD, Jan 8, 2007
  16. jackhackettuk
    SD Guest
    30m high where?
    It's 200m above sea level in Surrey. That'd be a fecking great wall at
    Dartford.
    | ___ Salad Dodger
    SD, Jan 8, 2007
  17. jackhackettuk
    Scraggy Guest
    Pedant.
    Scraggy, Jan 9, 2007
  18. jackhackettuk
    Domenec Guest
    Timo Geusch ha escrito:
    Spain is on that way... the only experience I know first hand is Blanes
    (near Lloret de Mar, for the cheapoholidayisti), a desalinization plant
    is supplying water to a 30K person village.
    Domenec, Jan 9, 2007
  19. jackhackettuk
    Scraggy Guest
    Do any of your towns use seawater a la Gibralter? I know why Gib uses it but
    for coastal towns in warm/hot countries it seemed like a good idea.
  20. jackhackettuk
    Domenec Guest
    Scraggy ha escrito:
    http://www.elmundo.es/papel/2003/01/17/catalunya/1314272.html
    Desde ayer, las poblaciones costeras situadas entre Tossa y Arenys de
    Mar podrán consumir agua marina tratada. En la primera fase, la
    desaladora producirá 10 hectómetros cúbicos anuales, que se
    distribuirán a tres estaciones depuradoras situadas en Palafolls,
    Tossa-Lloret y Blanes. Ocho pozos captarán el agua del mar.
    Yep, it is sea water. Babelfish for details.
    About the process:
    La depuración
    El proceso químico de purificación del agua se realiza en cuatro
    líneas del proceso fisicoquímico conocido como ósmosis inversa.El
    líquido es captado del mar a través de pozos subterráneos.El
    tratamiento previo, que incluye la acidificación, es fundamental para
    eliminar la actividad biológica, las materias orgánicas y evitar la
    precipitación del carbonato cálcico sobre los módulos de ósmosis. A
    continuación, se efectúa otra filtración para eliminar las
    partículas en suspensión.
    Una vez tratada, unas motobombas de alta presión inyectan el agua en
    los módulos de ósmosis inversa para provocar su desalinización,
    desechando una parte en forma de salmuera. El proceso osmótico se basa
    en el empleo de membranas semipermeables que permiten el paso del
    líquido, pero no de las sales. Por último, se realizarán los
    tratamientos habituales para garantizar la salubridad y potabilidad del
    agua.
