Paging the Gericke-armouristi
Discussion in 'UK Motorcycles' started by TD, Jul 3, 2008.
  1. TD
    TD Guest
    Had some time to kill this afternoon after work, popped into HG Stockwell.
    Thought about getting some hip armour for my leathers. They only had this
    flexible, knobbly Hiprotec stuff, which didn't inspire much confidence.
    Is this as protective as normal "hard" CE armour, or is it more like less
    protective but more comfortable due to flexibility?
    TD
    1991 VFR400R NC30 (black and red)
    2001 ZX-9R (red and black)
    1999 M5 (neither black nor red)
    Missing: SOB, Unreliable Italian exotica, Lardy tourer
    TD, Jul 3, 2008
  2. TD
    According to the tests in DiRE and my failing memory, the HiProtec stuff
    is noticeably better.
    Timo Geusch, Jul 3, 2008
  3. TD
    Eddie Guest
    IIRC, it's meant to be good stuff: it "hardens" under sharp impacts, or
    something like that. I'm sure there's a technical term for it.
    It's been discussed on here before, I'm sure.
    Eddie, Jul 3, 2008
  4. TD
    It's actually Davis Odell Astrosorb by another name. You'll find the
    spec for Hiprotec Sport and Astrosorb is higher than any other armour
    on the market. I have Hiprotec Sport throughout my Gericke textile
    gear, throughout my old Nitro 1-piece; and Astrosorb in the knees and
    hips of my both my MJK 1-piece and MJK 2-piece suits.
    Hard armour transmits shock directly through and into bone, Astrosorb
    absorbs the shock by dissipating it sideways under compression.
    You can't buy higher spec armour.
    Lozzo, Jul 3, 2008
  5. "Non-Newtonian" - the very reason speed bumps should be made of
    custard.
    DoetNietComputeren, Jul 3, 2008
  6. TD
    The other thing is that it takes repeated hits without loss of performance.
    platypus, Jul 3, 2008
  7. TD
    DR Guest
    Out of interest, in your (or anyone else's) experience, how does Knox
    Flexiform compare to that? I have that in most of my gear at the
    moment.
    DR, Jul 3, 2008
  8. TD
    TD Guest
    Thanks to all who responded, very useful[1]. I shouldn't judge a book by its
    cover, I suppose. I'd love to replace all my hard CE armour, but that stuff
    ain't cheap.
    <fx: sets ebay favourite search email>
    [1] Especially Bear. Lozzo, couldn't you do any better than re-hash what Bear
    wrote? ;)
    TD
    TD, Jul 4, 2008
  9. TD
    I remember an episode of Brainiac where they filled a swimming pool
    with custard and got that bloke off Big Brother to walk across it.
    CT, Jul 4, 2008
  10. TD
    This is true, and it quite probably saved my life. I was wearing this
    stuff (in German only, but babelfish gives an idea)
    http://www.schwabenleder.de/index.cgi?a=texte&b=show&c=1158&d=&i=1099&j=1270
    which isn't CE approved, but sounds like it's similar to those you
    describe.
    When I hit the armco with my back flat-on to it (albeit upside-down)
    at aroun 50mph the padding managed to divert enough of the impact away
    from the spine to break 9 ribs _at the front_, as well as the 8 cushed
    vertebrae. Clearly with no armour the spine would have snapped and I
    wouldn't be typing this now, but I've often wondered how good the
    Dainese armadillo stuff would have been in the same circumstances. It
    may well have stopped the spine breaking, but I suspect it wouldn't
    have transferred the forces nearly as effectively, such that there may
    have been a lot more spinal damage.
    I'll never know, of course, but I'm certainly grateful to the germans
    who made my leathers the way they did.
    _______
    Ace, Jul 4, 2008
  11. TD
    I had no idea I'd done so much damage. Once I'd started myself
    breathing it was clear from the pain that I'd broken at least one rib,
    but I stood up shortly afterwards, which sadly did nothing to help the
    rib pain, then lay down again, at which point the jacket hump made it
    very uncomfortable - so a few minutes later, when the first ambulance
    crew arrived, I asked them to help me take it off, and they duly
    obliged.
    Shows how much training they'd had - quite obviously a spinal impace
    and they not only failed to immobilise me but actually helped me move
    my arms and back around to get the tight-fitting jacket off. Lesson
    learnt - the normal SAMU-type French ambulance crews have slightly
    less knowledge that I get from my tri-annual 2-day emergency 1st-aid
    courses.
    The (Swiss) helicopter paramedics and hospital staff were less than
    impressed when I told them, although I was less than impressed with
    them when they cut my trousers off, despite the fact that they could
    have just pulled them off. Bastards.
    Still, they patched me back together, I suppose, but that's one pair
    of leather trousers I'll neve be able to use again.
    _______
    Ace, Jul 4, 2008
  12. TD
    It does
    Lozzo, Jul 4, 2008
  13. TD
    Nope.
    Lozzo, Jul 4, 2008
  14. TD
    DozynSleepy Guest
    Ace wrote:
    snip ouch
    Cheap at that price if you ask me. I can't even *think* of the damage
    you did to yourself without grimacing.
    Hate to think what living with the aftermath is like, still, better than
    being some ashes in a box under the stairs.
    DozynSleepy, Jul 4, 2008
  15. TD
    Don have you heard from Gavin? has my money but no goods yet
    Hog, Jul 4, 2008
  16. TD
    DozynSleepy Guest
    Oh good,an excuse to get out of bed and be properly psychotic before the
    men and women in white drug me up and press gang me back to work.
    I'll swing by the house wearing my best Jack Nicholson "Here's Johnny"
    face and see what's up.
    DozynSleepy, Jul 5, 2008
  17. TD
    Get yourself a Harley and you've a ready-made pair of chaps.
    Pip Luscher, Jul 5, 2008
  18. TD
    I _will_ get back to a pain-free, properly fit state eventually. It's
    just taking longer than I expected, but I'll get there.
    Out mountain biking today, did 20 miles or so without struggling too
    much.
    _______
    Ace, Jul 5, 2008
  19. TD
    TD Guest
    I splashed out on as an experiment for my Kevlar jeans. They came with hard
    knee/shin and thick hip armour, which was so uncomfortable, I had to remove
    it. The Hiprotec has revolutionised the jeans, which are now just as
    comfortable as normal ones.
    If I like it, I'll consider getting some more for other items of clothing.
    It's not cheap, but at least I can move it from item to item, a bit like
    getting a good stereo put in a car.
    TD
    TD, Jul 14, 2008
  20. TD
    Thixotropy?
    ogden, Jul 17, 2008
