Paging the grammar Nazis
Discussion in 'UK Motorcycles' started by Andy Cunningham, Feb 24, 2005.
  1. What's wrong, if anything, with the following sentance:
    "Ok no problem, but if you could send a fax copy that would be
    extremely useful"
    Thangyew.
    Andy Cunningham
    Stockholm, Sweden
    STX1300A
    UKRMMA#17
    The UKRM FAQ: http://www.ukrm.net/faq/ukrmfaq1.html
  2. Andy Cunningham
    porl Guest
    Fax is short for facsimile therefore "copy" is redundant.
    porl, Feb 24, 2005
  3. Andy Cunningham
    flash Guest
    Would instead of could?
    flash, Feb 24, 2005
  4. Andy Cunningham
    that's true, though you can't just leave out the word "copy" from the
    sentence and have it make proper sense.
    I'd suggest:
    "Ok, no problem, but it would be extremely useful if you could fax it
    as well."
    darsy, Feb 24, 2005
  5. Andy Cunningham
    Sorby Guest
    Some sort of punctuation after 'Ok'.
    Anyway, what's wrong with "OK, NP, SND FAX PLS TY"?
    Sorby, Feb 24, 2005
  6. Andy Cunningham
    Bob Mc Guest
    You're missing the comma before "TY"?
    Bob Mc, Feb 24, 2005
  7. Andy Cunningham
    porl Guest
    Of course you can, it's a noun.
    porl, Feb 24, 2005
  8. Andy Cunningham
    Dave Guest
    It's spelt sentence, twat :)
    Dave, Feb 24, 2005
  9. Andy Cunningham
    You left "STOP" off the end.
    platypus, Feb 24, 2005
  10. Andy Cunningham
    porl Guest
    Possibly, but without knowing the situation it's not necessarily the case.
    It might genuinely be unknown if the possibility to send a fax machine
    exists and the statement might not be a request to receive one.
    porl, Feb 24, 2005
  11. Andy Cunningham
    You misunderstand. The word "copy" in the original sentence is not just
    tautological, it implies that the fax is of the particular document
    under consideration. Leaving out the word "copy", and otherwise leaving
    the sentence alone, implies that it would be "extremely useful" to send
    a fax of absolutely anything at all.
    darsy, Feb 24, 2005
  12. Andy Cunningham
    AndyW Guest
    "That" is making the object of the sentence confusing - you have asked
    for an extremely useful fax, rather conveying that it would be useful
    if you were sent a fax, which is what I assume you meant....
    AndyW, Feb 24, 2005
  13. Andy Cunningham
    Spete Guest
    It's sentence
    No comma after ok, if doesn't seem right, no comma after copy, I would
    change that to it.
    Then again, I'm a crazy Dutchie, so what do I know....
    Spete
    Spete, Feb 24, 2005
  14. Andy Cunningham
    porl Guest
    Facsimile means "an exact reproduction", and fax is defined as "a printed
    page transmitted/received by a fax machine". To say "fax copy" is
    redundant, and I'm surprised to see you championing it. Further, I think
    you're talking rubbish and you know it.
    porl, Feb 24, 2005
  15. Andy Cunningham
    I'm not, you fucknugget. In my original reply, I suggested the word
    copy be replaced by another word ("it") making it clear what the score
    was:
    as well."
    using fax in its gerund form, to further clarify intent.
    darsy, Feb 24, 2005
  16. Andy Cunningham
    porl Guest
    I find it amusing, Klaun botti, that you think the exclusion of an implied
    pronoun is of more grammatical importance than the repetition that we all
    know and hate. I assume this is a consequence of your usual work environment
    where management-speak, laziness and redundancy is endemic.
    porl, Feb 24, 2005
  17. Andy Cunningham
    Paul - xxx Guest
    Andy Cunningham composed the following;:
    Anbiguous. One answer could be " ... Yes, I could send a fax copy. Do you
    want one sending then?"
    What about "OK, no problem, but please send a fax as well, as a hard copy
    would be extremely useful"
    Paul - xxx, Feb 24, 2005
  18. Andy Cunningham
    where did I espouse ignoring repetition?
    Sorry for the tardy response, BTW, had to pop out to get some money out
    of the ATM machine.
    darsy, Feb 24, 2005
  19. Andy Cunningham
    porl Guest
    Who said you did?
    Er...ok. Thanks for the update. I might make a sandwich in a minute.
    porl, Feb 24, 2005
  20. Andy Cunningham
    porl Guest
    You'd probably fax the original, wouldn't you? Unless there's any doubt as
    to what would appear at the other end.
    porl, Feb 24, 2005
