Paging the ignition-switchisti
Discussion in 'UK Motorcycles' started by Antony Gelberg, May 23, 2007.
  1. Right, got the top yoke off, and undone the shear bolts with a dremel and
    punch. Surprisingly easy. I'll probably replace the ignition switch, but it
    can't hurt to have a go at taking it apart (tm Lozzo) - try and rescue the top
    bit so I can use the same key. In fact if I can do that, I can reuse both the
    top and bottom.
    I've removed the two small round covers next to the key slot, uncovering some,
    er, things. Are these another, smaller set of shear bolts? If not, HTF do I
    get the switch apart?
  2. Antony Gelberg
    Antony Gelberg says...
    Buy a new switch. The whole thing comes apart from underneath, the lock
    itself stays in the top part, don't try to remove it from its housing.
    The ignition swith is basically a lock sat on top of a switch, held
    together by two screws accessible from underneath.
    Lozzo
    Suzuki SV650 K3
    Suzuki GSX-R750L
    Yamaha 250 Flat-tracker
    I ride way too fast to worry about cholestorol.
    Lozzo, May 23, 2007
  3. Antony Gelberg
    Steve Parry Guest
    In
    I did this with my K when the switch died, as you say saved having different
    keys. On mine there was a small grub screw under a blob of sealing paint
    that once undone allowed the lock part to be swapped over.
    Steve Parry, May 23, 2007
