Paging the metal fabricators.
Discussion in 'UK Motorcycles' started by Krusty, Oct 18, 2005.
  1. Krusty
    If I wanted to make a metal box that could resist being attacked by
    hand tools/electric drills for up to say five minutes, would 4mm steel
    (200 Brinell, 82ksi yield) be up to the job? If not, what'd be a good
    choice? It'll be around 5"x4"x1", & (virtually) uncrushable due to
    what'll be inside it. Weight is an issue - it needs to be as light as
    possible.
    The follow-up question - could the edges be bent 90 degrees & seam
    welded, with the sixth side welded on the back, or is 4mm too thick for
    that? I'm thinking of pro manufacturing here rather than DIY "hit it
    wiv an 'ammer".
  2. Krusty
    Guy Fawkes Guest
    assume battery drill, half decent one, decent bits, or battery angle
    grinder with cutting disk
    tool steel would do it
    generally speaking bendability and hardness are opposites, try and bend
    something hard and you get stress fractures and breakage.
    migh be an idea to start with something like a small house safe, and
    modify as required, make sure it's a quality one though.
    ideally double or triple walled
    again weight might be an issue
    HTH etc
    Guy Fawkes, Oct 18, 2005
  3. Krusty
    deadmail Guest
    Hmm- I've recently been using a petrol angle grinder. Fucking hell,
    what a tool.
    deadmail, Oct 18, 2005
  4. Krusty
    I think that's Bonwick's opinion of anyone who uses angle grinders...
    platypus, Oct 18, 2005
  5. Krusty
    Battery drill, hand tools & freezing spray are all it needs to cope
    with really. The pros armed with petrol angle grinders & portable
    plasma cutters aren't worth trying to defend against in this instance.
    What about case hardened?
    This is a prototype for something I may or may not have commercially
    produced (and for which I hold a patent), so bodging an existing widget
    is out.
  6. Krusty
    MikeH Guest
    It's been done - the tin of sardines I broke the pull thing off last
    night resisted every opening-type tool in our kitchen for a good five
    minutes. Nearly had my finger off when I did get it open too.
    MikeH, Oct 18, 2005
  7. Krusty
    Guy Fawkes Guest
    if bodging an existing one is out, at least learn from their
    construction, double and triple wall safes are very tough nuts to
    crack, possibly even worth buying one just to cut it up and analyse how
    it's made this saving yourself x amount of development work.
    having said all that, from my experiemce of the commercial world, all
    you need to do is make it out of cheaper materials to a far lower
    standard so it is "affordable" (eg costs a fraction of whatever is
    going inside it) and give it some rufty tufty name
    depends if it's designed to hold 100 x £50 notes on a regular basis,
    or just a driving licence and credit card.
  8. What's this for, coke stash?
    Grimly Curmudgeon, Oct 18, 2005
  9. Krusty
    Grimly Curmudgeon says...
    He'll need room for the refrigeration unit too, and little compartments
    to stop the bottles rattling.
    Lozzo
    Track pixie
    GSX-R1000 K1
    I haven't lost my mind, it's
    backed up to a floppy disc
    that's around here somewhere.
    Lozzo, Oct 18, 2005
  10. Krusty
    It's a housing - half of a thing that contains a thing that connects to
    the other half of the thing. I think that makes it clear.
  11. Armoured penis sheath, a case for a packet of fags or a HDD?
    You mentioned case hardening. You could get it made by bending and
    welding then case harden the entire thing. Still wouldn't be resistant
    to an angle grinder though.
    Actually, while electro-brazing steel a few years ago, I accidentally
    made a drill-resistant alloy that blunted every fucking bit I put to it
    for ages. Never did find out exactly what the original steel was (toecap
    grade) or quite what was in the brazing rod.
    You mention 5 minutes resistance; I take it this is the likely time any
    thief has to get into it before the cavalry arrives.
  12. Krusty
    dwb Guest
    What sort of cavalry would this be for the above application?
    dwb, Oct 18, 2005
  13. Krusty
    Big Dave Guest
    Tool steel is a bit brittle and therefore a bastard to fold.
    If you can get it, use some "Red Diamond" plate - its South African spec
    armour plate.
    That'll keep the bastards out
    Big Dave, Oct 18, 2005
  14. Krusty
    http://en.wikipedia.org/wiki/Chobham_armour
  15. http://www.uscav.com/
  16. Krusty
    You'd like banger racing. They were standard issue.
    sweller, Oct 19, 2005
  17. Krusty
    I can just imagine Burnt doing banger racing.
    platypus, Oct 19, 2005
  18. Krusty
    Nicknoxx Guest
    To really make life difficult for power tools you need to have a
    composite structure. An external hard shell of, say, steel with an layer
    of the stuff they put in protective clothing for chainsaw use, followed
    by a layer of something like ceramic.
    Nicknoxx, Oct 19, 2005
  19. Krusty
    Guy Fawkes Guest
    if you're crafty you can defeat a lot of the power tools quite easily.
    drill, all you need is a material harder than the drill, make both
    inner and outer shell out of this
    cutting tools, most of them are likely to be based on cutting disks,
    and they are made of three "components", (abrasive, adhesive and void)
    so you only need to defeat one of them, the void being the easy one,
    zinc is really good at clogging up disks and even fine hacksaw blades,
    do the job properly and cast the zinc in situ after first adding a high
    proportion of aluminium oxides and you're 95% of the way there, just
    make sure the outer shell in particular is a good enough material and
    it will even defeat oxy acetylene from cutting properly, weak points
    then will be door seal and hinge / locking mechanism.
    strong / light / affordable
    pick any two
    I suspect the OP wants all three, that's usually how it goes with these
    things.
    Guy Fawkes, Oct 19, 2005
  20. Krusty
    in a Ford Pinto, presumably.
    darsy, Oct 19, 2005
