Paging the metallurgists
Discussion in 'UK Motorcycles' started by Lozzo, Sep 11, 2005.
  1. Lozzo
    I'm looking to buy stainless steel disc bolts and caliper mounting bolts
    for the Gixer. What grade of stainless steel should I be looking for as
    they'll obviously require a very high shear strength, which I'm told A2
    grade doesn't have?
    TIA
    Lozzo, Sep 11, 2005
  2. Lozzo
    A4 - it's more than paper.
    Pip, Sep 11, 2005
  3. Lozzo
    Guy Fawkes Guest
    irellevant, the shear force on even a bog standard steel bolt of the
    appropriate diameter will be so great, particularly considering there
    will be several of them radially around the disk, that it will be one
    of the last things you need to concern yourself with, long before you
    get there your pads and calipers will have disintegrated and your disk
    itself warped.
    I'd be more concerned about the galvanic effects of a stainless bolt in
    a steel disk rotor going through to an alloy wheel hub.
    stainless steel is a (IMHO) vastly over rated material, I see it
    constantly used (particularly in the marine trade) because it was
    selected for its visual properties, little heed being paid to its
    mechanical properties.
    http://www.hse.gov.uk/lau/lacs/47-17.htm
    You need to do some research on "Thermomechanical Fatigue Behavior of
    Stainless Steel Grades" IMHO before you go buying stainless fasteners
    for modern motorcycle brakes....
    Guy Fawkes, Sep 11, 2005
  4. Lozzo
    Guy Fawkes says...
    I'm sorry, but I'm hardly likely to take any advice from someone who
    regards disc brakes as a bad thing on a motorcycle.
    Thanks and all that, but **** off eh.
    Lozzo, Sep 11, 2005
  5. Lozzo
    Guy Fawkes Guest
    I never said that.
    OK, I'll take 30 years of engineering experience with me, and leave you
    to play with perhaps the most safety critical part of any motorcycle by
    choosing components according to how shiny they are.
    darwinism at work.
  6. Lozzo
    Guy Fawkes says...
    Yes you did, in a thread where you were extoling the virtues of drum
    brakes on the bike you'd chosen for your daughter. You claimed disc
    brakes weren't needed on a motorcycle because they were dangerous.
    Hardly. I asked for advice, I'll take it from someone who has a clue,
    not yourself.
    Lozzo, Sep 11, 2005
  7. Lozzo
    Chris H Guest
    I'll just wait for things to unfold.
    Chris H, Sep 11, 2005
  8. Lozzo
    Sheet, I wouldn't wait too long.
    Pip Luscher, Sep 11, 2005
  9. Lozzo
    Chris H Guest
    The Austenitic grades are inherently weaker than the hardenable (i.e
    martensitic) stainless steel grades. At which point I'll have to claim
    some ignorance of what would be acceptable in that application because
    all my experience is in 'warmer' aerospace applications. I do know from
    (failure) experience that how the bolt is made, as much as what it is
    made from, is important.
    If it was my life on the line and I *really* wanted stainless steel, I'd
    go for an 'AS' (SBAC) bolt in A286 or one of the 12%Cr steels (410
    stainless or better.). I certainly wouldn't immediately go for a 304
    stainless. The A286 would have a similar expansion coefficient to
    aluminium (unlikely to be of much benefit with the low temperatures the
    calipers and disc carrier are going to see).
    There is still the potential for galvanic corrosion between the
    stainless bolt and the disc carrier/caliper, but as they are often
    anodised aluminium it's not that likely to be a problem. Especially as
    you're:
    a) unlikely to ride it much in winter (loadsa salt around)
    b) going to clean the bike after each ride....aren't you?
    btw, you really want to talk to an Engineer with materials experience
    rather than a 'metallurgist' because the latter are just scientists. I
    was going to offer to look up the correct AS bolt, because I have access
    at work, but I'm just a metallurgist with pretensions to being an
    Engineer. Better you talk to a specialist.
    I'd go for titanium alloy bolts myself and avoid salty conditions. Have
    you tried looking on http://www.tastynuts.com ?
  10. Lozzo
    Chris H Guest
    Only if we pad it out.
  11. Lozzo
    Guy Fawkes Guest
    no, I did not say that, but then I never expected you to base an
    argument / flame on what people actually say or mean sans deliberate
    misinterpretation.
    I have more of a clue about such things than you would credit, which is
    I guess par for the course with usenet and talking to people you have
    never met.
    I just deleted a follow up that was typed in here, it explained, with
    links, how to precisely and easily work out the forces at work and then
    look up in a table which materials were suitable. It would have taken
    you all of three minutes and given you irrefutable factual data.
    but you don't need that, you're too clever, you got a smart mouth and a
    motorbike and a net connection, and you like shiny little baubles and
    you don't like me, fine, life's too short.
    when I come on here asking elementary engineering questions feel free
    to tell me I don't have a clue eh.
    for the rest of you, brake components such as disk mounting bolts are
    like elevator cables, they have something known as a "safety factor",
    do not buy either from anyone who cannot tell you what it (the SF) is
    for that component, or if in doubt just buy the factory OEM part.
  12. Lozzo
    Chris H says...
    Excellent. I'll take your advice and search out someone with the
    relevant experience. Many thanks.
    Lozzo, Sep 11, 2005
  13. Lozzo
    Guy Fawkes Guest
    Lozzo wrote:
    oops, you just missed him.
  14. Lozzo
    Thanks, squire.
    Pip, Sep 11, 2005
  15. Lozzo
    Chris H Guest
    This is UKRM.
    This is UKRM.
    This is...oh, I give up!
    If he'd wanted a proper techy answer he would have posted the question
    in sci.engr.metallurgy.
  16. Lozzo
    That would put the brake on it and it'll end up stationary.
  17. I'm glad I don't have to read this thread via a GSM connection.
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - faster when upright
    V2300 - flat cap and rug ~|~ VS800 - borked
    Doesnotcompute, Sep 11, 2005
  18. Lozzo
    Guy Fawkes Guest
    my first reply wasn't "techy", it was straightforwards and accurate,
    and if he'd followed the links given he'd have found high chrome 400
    series stainless and not shitty 316 and understood the difference
    between the two.
    his problem wasn't with the content of the response he got from me, his
    problem was the response from me.
    like I said, life's too short.
  19. Lozzo
    Chris H Guest
    It's called 'common sense'.
  20. Lozzo
    Guy Fawkes says...
    I have a smart brain and a net connection. I don't know much about
    engineering so I ask of those who do know. I don't take advice from just
    anyone, especially anyone who's shown themselves to be a clueless
    fuctard in the past. Your stupidity reared its ugly head regarding disc
    brakes, the very subject I have a query on. I am hardly likely to take
    your advice on this subject, regardless of how qualified you say you
    are.
    Lozzo, Sep 11, 2005
