Paging the (motor possibly) bike shed experts.
Discussion in 'UK Motorcycles' started by Pete Fisher, Dec 5, 2010.
  1. Pete Fisher
    Pete Fisher Guest
    Now I've decided to stay here for a few more years an extra shed for the
    lad to use as static bicycle repair man HQ is urgently required. It will
    have to go on the site of the old brick/timber greenhouse. That is down
    to the brick walls only and theoretically I could get an 8 x 6 foot shed
    within it IYSWIM. That would save a load of work but I'm thinking it
    might not be good for the T&G shed walls as they wouldn't breathe so
    well.
    I've got to get a skip to take the remains of the two old fireplaces we
    are having removed so I guess I really ought to bite the bullet and set
    to demolishing it, then I could get a 10 x 6 or even 10 x 8. It was
    suggested that the bricks might have value to someone but they aren't
    the local specialist baggeridge jobbies so I doubt it.
    Would my pikey Aldi air chisel help or would my Clarke's Tiger
    compressor drive a proper Kango hammer?
    An exploratory bash with a lump hammer reveals it's all rather too well
    built with 9 inch solid walls to come down very easily.
    | Pete Fisher at Home: |
  2. Pete Fisher
    Beav Guest
    Well the chisel will work, it's just a matter of how long you're prepared to
    wield it and how long your neighbours could stand the racket.
    I can't imagine the Tiger compressor being anywhere near man enough to
    handle a good sized Kango though, but I bet there are cordless doobries that
    can be hired.
    9 inchers are always a fucker. I've heard.
    Beav, Dec 5, 2010
  3. Pete Fisher
    On Sun, 5 Dec 2010 15:42:17 +0000, Pete Fisher
    snip>
    You won't get the flow rate out of a small compressor to power a
    decent Kango.
    Just get hold of a decent 14lb sledgehammer and you'll have it down in
    a morning. Failing that you could go to your local HSS and hire a
    cutter and just slice it up in half the time.
    Andy Bonwick, Dec 5, 2010
  4. Pete Fisher
    Pete Fisher Guest
    I suspected as much.
    A pity Aldi aren't knocking pikey ones out at the moment. I've got a
    maul at 'the chateau' that might do the business, particularly if I do a
    bit of nibbling at one corner with the air chisel and an old pick axe
    first. Given the long range weather forecast I can't see me attacking it
    until after my February trip to take the climbing wall boards and
    hopefully refurbished chainsaw anyway.
    At least I have a decent barrow to get the bricks to a skip and the lad
    will have to agree to help or get no workshop.
  5. Pete Fisher
    GeoffC Guest
    I doubt it (X2)
    A 10kg demolition hammer (electric) is what you want, something like this
    http://www.toolstop.co.uk/dewalt-d25901k-10kg-low-vibration-demolition-hammer-240v-p6992
    You can hire them for about 30 quid a day. I reckon you'd have the lot down
    in about an hour and another hour to chop the rubble into heaveable sized
    lumps.
    GeoffC, Dec 5, 2010
  6. Pete Fisher
    Not much if the brick's solid. I got through two pikey air chisels
    before I saw the light & bought a FOAD SDS.
    For very short periods at a time, maybe. Just hire an electric concrete
    breaker (or buy a decent SDS), it'll make life so much easier.
    Krusty, Dec 5, 2010
  7. Pete Fisher
    Pete Fisher Guest
    Hmm, I can use some of the rubble as hard core for a new concrete shed
    base. A trip to HSS might indeed be the best bet.
  8. Pete Fisher
    Pete Fisher Guest
    I've seen the light. I can hire one to do also get down one of the
    fireplace surrounds (York stone) at the same time. The other on is a
    FOAD original cast concrete with glazed tiles in situ job from 1924.
    Must have taken several strong in the arm black country blokes or a
    crane to lift it in to place. I'm leaving that one to the bloke putting
    the new ones in to cut up.
  9. I bet one of the sheddi would like the bricks.
    X-posted.
    The Older Gentleman, Dec 5, 2010
  10. Pete Fisher
    crn Guest
    I have a 5 x 7 shed free to a good home.
    Must be dismantled and removed before Xmas.
    Near Weston Super Mare.
    crn, Dec 5, 2010
  11. Pete Fisher
    Rusty Hinge Guest
    Memememememe!
    But I bet they're nowhere near Snorfolk thobut.
    Rusty Hinge, Dec 5, 2010
  12. Pete Fisher
    Ivan D. Reid Guest
    UKRM is at least as good as UKRS at organising Underground Railway
    transfers. In this case, though, perhaps a more community-spirited
    enterprise could be arranged. I'm in for a wasted weekend taking a train
    somewhere, knocking down a brick wall, helping to drive the remains
    somewhere else, drinking some beer, and taking a train homewards again.
    You meet a nicer class of people that way...
    Ivan D. Reid, Dec 5, 2010
  13. Pete Fisher
    mark Guest
    I once demolished a chapel with a hammer and chisel [1}
    Just start taking them off the top with the chisel under them and you'll
    be surprised how quick it all comes down.
    Or just hire an electric demolition hammer :)
    mark, Dec 5, 2010
  14. Pete Fisher
    mark Guest
    1. I wouldn't, now; recommend this approach for chapels...
    mark, Dec 5, 2010
  15. Pete Fisher
    mark Guest
    Yes, but did you turn them into a useful car parking space afterwards?
    mark, Dec 5, 2010
  16. Pete Fisher
    Pete Fisher Guest
    I did tentatively float the idea of a "demolition party" a couple of
    years ago, but that would work better once spring has sprung. Inertia
    will probably take hold again until then anyway so watch this space.
  17. Pete Fisher
    Pete Fisher Guest
    Having just watched a repeat of Clarkson's "Greatest Raid of All"
    documentary Amatol might be the most rapid if rather messy strategy and
    also enlist the help of the Blaster Bates enthusiasts , but for the sake
    of anybody 'official' listening in that was joke OK.
  18. Pete Fisher
    You can **** off, I'm not ready for another stroke yet.
    Lozzo
    they churn out)
    Lozzo, Dec 6, 2010
  19. Why not build the shed on top of the walls?
    Grimly Curmudgeon, Dec 6, 2010
  20. Pete Fisher
    Pete Fisher Guest
    In communiqué <>, Grimly
    I did think of that, with a very low 'cellar' for storage or drowing
    'shrooms, but I don't think the nearest neighbour to it would be very
    happy. The existing sheds are screened well by trellis on top of a very
    old wall festooned with climbing plants. One time when SWMBO was
    trimming them they made a point of saying not to cut them back too much
    as they "screen your ugly shed and greenhouses". She resisted a "don't
    worry we still want to hide your ugly house" reply. The walls are a good
    2 feet high, so even a low pitched roof high enough to allow space to
    work inside would poke up well in to their line of sight and I don't
    want to get the Planning Officer involved.
    Pete Fisher, Dec 6, 2010
