Paging the my-rear-light-burns-a-tad-too-often-isti
Discussion in 'UK Motorcycles' started by Geo, Jun 13, 2008.
  1. Geo
    Geo Guest
    But first, an ode:
    Oh how I appreciate thee, o nameless Suzuki engineer,
    who has thought of putting a rubber cap on the back of the rear light
    assembly,
    so I can change the burnt bulb in 30 seconds with no use of tools
    whatsoever.
    And now to the question:
    As you can guess, brake light got burnt and my mate and previous owner of
    the bike says that it tends to happen rather often (he didn't specify how
    often). Any suggestions what I should be looking for in case there's a
    slight electrical fault? Could it just be blamed on too many
    vibrations/shaking around due to the fact that the bulb sits rather loosely
    in its fitting? It's a Suzuki Freewind and the roads around here are more
    than just bumpy.
    Side question: Is it normal for the bulb to go completely dead when it burns
    only one of the two filaments?
    Geo
    Geo, Jun 13, 2008
  2. Geo
    Eddie Guest
    You do realise that one filament is the rear light, the other is the
    brake light, don't you? Each should work independently.
    Eddie, Jun 13, 2008
  3. Geo
    Simon Wilson Guest
    Is there any blackening of the bulb glass? That's often a sign of a poor
    connection to the bulb - sometimes you can bend the contacts of the
    holder a little to give slightly more spring pressure.
    Simon Wilson, Jun 13, 2008
  4. Geo
    Geo Guest
    I do, which is why that behaviour puzzled me. I thought it might be some
    sort of perverted security feature that I failed to comprehend, e.g. "if
    brake light filament burns, then whole bulb stops working, in order to alert
    the rider more easily". I realise it makes little sense, but I had no better
    explanation.
    Geo
    Geo, Jun 13, 2008
  5. Geo
    Geo Guest
    Thanks for the tip, I thought an LED would be a nice upgrade either way but
    left it for some other time. Hope I won't need to replace the bulb again too
    soon.
    Bugger. Suggestions anyone?
    Geo
    Geo, Jun 13, 2008
  6. Geo
    zymurgy Guest
    Take a leaf out of TOG's book, and don't use the brakes at all. No
    brakes = no wear on the bulb filament.
    Paul.
    zymurgy, Jun 13, 2008
  7. Geo
    Eddie Guest
    Cool, just thought I'd better check.
    Have you tested the individual filaments with an ohm-meter?
    Eddie, Jun 13, 2008
  8. Geo
    Geo Guest
    Not to mention the even more substantial savings in brake pads....
    ITYF however that pads/bulbs are more easily replaced than broken
    bones/ruptured spleens/torn ligaments/impaled arseholes (for the extremely
    unlucky). Even worse, all these Indian replacement organs on the market are
    hardly acceptable OEM quality.
    Geo
    Geo, Jun 13, 2008
  9. Geo
    zymurgy Guest
    Heh. See YTC on this. If TOG's brake lights come on, it's a good idea
    to use yours.
    P.
  10. Geo
    Geo Guest
    The bulb was quite clean as much as I remember (I'm not home atm), but I'll
    check again tonight.
    Geo
    Geo, Jun 13, 2008
  11. Geo
    Geo Guest
    Erm, not yet, I'll fish the bulb out of the
    garb^H^H^H^H^H^H^H^H^H^H^H^H^H^H^H test it tonight.
    Geo
    Geo, Jun 13, 2008
  12. Geo
    Rudy Lacchin Guest
    My old GSX550 suddenly started blowing head/tail/stoplight bulbs. Turns out
    the voltage regulator had decided to commit suicide and was letting
    much-too-high voltages through. Replaced that and all was well.
    Do you have one of those volt measuring things?
    Rudy Lacchin, Jun 13, 2008
