Paging the PHPisti
Discussion in 'UK Motorcycles' started by Donegal Paul, Jan 15, 2007.
  1. Donegal Paul
    Donegal Paul Guest
    OK, Im about to try and learn some PHP so that i can learn how to set up a
    php/mysql online shop for a mate.
    But there's no idiots guide :-( well there is, there the Dummies books, one
    of which is winging its way from ebay as we speak.
    However, in the meantime ive downloaded the PHP 5.2.0 installer from
    http://www.php.net/downloads.php and tried to install it but its just not
    straight forward and after uploading the shop to the net im getting the
    following
    Fatal error: main(): Failed opening required 'includes/application.php'
    (include_path='.;c:\php4\pear') in
    C:\Domains\sandyscooters.com\wwwroot\catalog\install\index.php on line 13
    So, where im getting confused is seeing the C:\
    Im assuming that i dont have to have php installed actually on my computer
    unless i want to use something like phpMyAdmin?
    And if so, anyone know exactly why im getting this error, i have a feeling
    that "c:\php4\pear'" is the crux but have no feckin clue what to do about
    it?
    If an easy fix, please help, if its a case that im trying to run before i
    can walk and should await the dummies book then feel free to say so :-/
    Donegal Paul
    Eibar Li186 Series II
    www.thepilgrimssc.co.uk
    www.glitterbydesign.co.uk
    Getting into racing for 2007!!
  2. Donegal Paul
    Donegal Paul Guest
    "Donegal Paul" replies
    Never mind, in that time honoured tradition where you ask for help on
    something then immediately fix it afterwards leaving yourself looking an
    even bigger tit than usual, Ive done it!!
    Simple thing, the particular files it was trying to call hadn't uploaded
    properly!
    <shakes head at self>
    Donegal Paul
  3. Donegal Paul
    Pete Fisher Guest
    In communiqué <>, Donegal Paul
    I use PHP/Mysql a bit. So you are uploading and running this all on
    sever somewhere then, not using a web hosting account with PHP/Mysql
    already set up?
    You might want to also consider creating a totally local test bed. I
    managed to get Apache/PHP/Mysql working on my box after googling around
    a bit and some head scratching. Naturally you have to modify your
    connection config settings to match the server it will run on when you
    deploy, but it is useful for trying things out.
    I use myPHPadmin installed on the final hosting server but not locally.
    You should be able to set up a local MysqlGUI Administrator installation
    to do most things you would want in terms of housekeeping on the
    'remote' database anyway.
    I have also found it useful manipulating the Mysql database via a remote
    ODBC view. Visual Foxpro certainly can do that even to the extent of
    creating new records which is useful.
    Are you going to rely on pre-built solutions or get in to the guts of
    PHP? Not done a lot myself yet but just starting to get a feel for it:
    | Pete Fisher at Home: |
    Pete Fisher, Jan 15, 2007
  4. Donegal Paul
    ST Guest
    There is a package on Sourceforge called webserv -
    http://sourceforge.net/projects/webserv/ - which bundles php, apache,
    mysql, perl etc for Windows platforms.
    Only thing that does not install properly when I last installed this
    was mysql, which just needed the service installing. Takes about 2 or
    3 mins to set up correctly.
    After that stick phpmyadmin on and you should be up and running in no
    time.
    ST, Jan 16, 2007
  5. Can I suggest that you short-circuit the whole process and go for
    something like OSCommerce?
    Open source, good support forum, loads of add-ons and written in PHP
    using mySQL as a back-end..
    Admittedly you would still have the problem of installing PHP on
    Windows (and some sort of webserver) but there are installers for
    Apache/PHP on Windows other than PHP for Windows..
    Ah - here you go:
    http://www.apachefriends.org/en/xampp-windows.html
    Phil.
    Phil Launchbury, Jan 16, 2007
  6. Donegal Paul
    Andrew998 Guest
    I think you'll find he is. The clues are in the original post.
    Personally, if it does what he wants, I'd recommend Joomla with Virtuemart
    as being easier to keep up to date and it doesn't need a core hack every
    time you want to add a feature.
    Andrew998, Jan 16, 2007
  7. Well - he doesn't meantion OSCommerce and he is installing PHP manually
    rather than as part of a bundle so I was trying to make it easier..
    Fair enough - I'm used to OSCommerce which is why I recommended it.
    Besides - suffering is good for the soul :)
    Phil
  8. Bad form and all that - the other reason that I'm using OSCommerce is
    that the payment service that we are using (Protx) recommends it and
    has a payments module for it.
    Phil
  9. Donegal Paul
    Eddie Guest
    Protx, eh? 0wn3d.
    Eddie, Jan 16, 2007
  10. Donegal Paul
    Andrew998 Guest
    Fair point and, as I said, Virtumart is only any good if it does what you
    want.
    I've used OSC for a shop because Virtuemart didn't do what I wanted and it's
    a real pain trying to keep it security patched. Every OSC update has to be
    checked against all the hacks you inevitably end up with on OSC! As you say,
    suffering is good for the soul.
  11. Donegal Paul
    Domenec Guest
    Donegal Paul ha escrito:
    osCommerce?
    Domenec, Jan 16, 2007
  12. Donegal Paul
    Donegal Paul Guest
    "Pete Fisher" said toDonegal Paul
    Using my liquidsix.com reseller account, php etc installed. I thought you
    *had* to have it installed on a local machine too, for some reason.
    thats what i think im planning.
    whoosh there (looking forward to my dummies book arriving i have to say.
    Im at the prebuilt numpty stage, but would like to learn a bit more
    Donegal Paul
    Donegal Paul, Jan 17, 2007
  13. Donegal Paul
    Donegal Paul Guest
    "ST" said
    ooohhh ta, ill have a lookie at that.
    Donegal Paul
  14. Donegal Paul
    Donegal Paul Guest
    Thats exactly the beastie im trying to use :)
    Donegal Paul
  15. Donegal Paul
    Donegal Paul Guest
    "Andrew998" said to "Phil Launchbury"
    OK, you two, what will one do that the other wont?
    Before i get too deep into OSC i'd want to know if theres a real advantage
    in using Virtuemart instead?
    The problem really is though, as its all new to me, I dont know what i dont
    know yet IYSWIM :-(
    Donegal Paul
  16. <Deepest Sympathy>
    Phil
    Phil Launchbury, Jan 17, 2007
  17. Dunno - I've only ever used OSCommerce. It does seem *very* well
    supported and has lots of modules available for it.
    As the OP said - it also needs careful handling when you *do* install a
    module as that often requires you to hack around with the PHP source..
    Phil.
  18. Donegal Paul
    Andrew998 Guest
    To be honest OSC will be easier initially. The real issue is keeping it
    up-to-date if you start making core hacks. Unfortunately OSC is riddled with
    core hacks once you start to add features and this makes keeping it current
    very difficult. If you stick to the basic build it will be fine.
    Joomla with Virtuemart will take longer to learn and it won't do so much.
    For example, it isn't good at multi-currency. However, it is much easier to
    keep current and won't be such a security risk over time.
    The Joomla community tends to better organised too whereas the OSC community
    tends to be a bit of a free-for-all with everyone doing the same thing over
    and over again.
    There's no easy answer to this one and if you've started with OSC it's
    probably best to stick to it.
    I'm not sure if that helps!
    Andrew998, Jan 17, 2007
