Paging the R1-isti
Discussion in 'UK Motorcycles' started by Pip Luscher, Mar 18, 2009.
  1. Pip Luscher
    Alex Ferrier Guest
    Eiron wrote:
    in message news:...
    I suspect, I'm one of Champ's 'little friends' for
    the purposes of this reply.
    You are the one making the schoolboy error.
    Alex Ferrier, Mar 21, 2009
  2. Pip Luscher
    Actually, I've not been corrected yet. I'm awaiting your explanation
    as to why I'm wrong.
    Champ, Mar 21, 2009
  3. Pip Luscher
    "Just because."
    Ace, Mar 21, 2009
  4. Pip Luscher
    Eiron Guest
    I couldn't have put it better myself.
    Eiron, Mar 21, 2009
  5. Pip Luscher
    er, surely there *is* travel in the direction of the force?
    Champ, Mar 21, 2009
  6. Pip Luscher
    Colin Irvine Guest
    Not the main force. As Mark says, the only force in the direction of
    travel is the (minimal) force needed to keep you moving at a constant
    speed - as in a straight line, near enough. The main force in a turn
    is at right angles to the direction of travel.
    Colin Irvine, Mar 21, 2009
  7. Pip Luscher
    <shrug> When I was at school I was taught that a change in velocity
    (not speed) was an acceleration. So where's the accelerating force
    coming from, then?
    Champ, Mar 21, 2009
  8. Pip Luscher
    Colin Irvine Guest
    It's the centripetal force along the radius of the curve.
  9. Pip Luscher
    **** sake. If you didn't need extra energy to change direction, you
    wouldn't need to lean the bike over either.
    platypus, Mar 21, 2009
  10. Pip Luscher
    I'll have to check: can't really visualize what I do or exactly when.
    Still doesn't really explain why the R1 is so much more difficult than
    other bikes, though.
    This is the problem I'm having.
    Pip Luscher, Mar 21, 2009
  11. Pip Luscher
    Same as a spinning wheel: every point on the wheel is being
    accelerated towards the centre of the hub; the accelerating force is
    the tension in the material it's constructed from. No energy is being
    expended, though.
    However, recall an earlier argument I had with Simian <winces>
  12. Pip Luscher
    zymurgy Guest
    Whilst we're in the R1 thread, I have got an R1 rear wheel spindle,
    wheel adjuster blocks and nut going spare if anyone wants it.
    If anyone's interested before I lob it on ebay, send me a mail to my
    zym address.
    Cheers,
    Paul.
    zymurgy, Mar 21, 2009
  13. Pip Luscher
    frag Guest
    Ace wibbled...
    On a slight tangent, there isn't always more sidewall to the tyre if they're
    trails tyres.
    You'll know when you've found this point when no amount of leaning off /
    leaning over makes it turn any sharper :-S
    frag, Mar 21, 2009
  14. Pip Luscher
    frag Guest
    Ace wibbled...
    If you didn't need power to go round a bend you could turn the engine off
    and never stop going round a roundabout.
    FFS Eiron, shoolboy howler? Nursery school howler. Put brain into gear
    before typing.
    frag, Mar 21, 2009
  15. Pip Luscher
    frag Guest
    Mark Olson wibbled...
    Which is what Champ was talking about, the real world.
    Unless he's started racing bikes in Space?
    Plus that little bit of power to overcome friction and other losses is on
    top of a neutral throttle to overcome engine braking / gearbox friction.
    frag, Mar 21, 2009
  16. Pip Luscher
    DR Guest
    Mark Olson posted:
    As I understand it [1]:
    Speed is scalar (i.e. has magnitude but no direction).
    Velocity is vector (i.e. has magnitude and direction).
    Acceleration is a change in velocity (i.e. change in either magnitude
    or direction - or both).
    Acceleration (in scientific terms, may be positive or negative)
    requires force to be applied. This should be fairly obvious; Newton's
    Laws of Motion [2] and the Laws of Thermodynamics cover it nicely. You
    cannot change direction, even at a constant speed, without some force
    being applied other than that required to maintain the speed.
    Satellites are a special case - they are constantly falling, but
    nobody's told them that so they stay up [3] ...
    [1] Poorly-remembered 22-year old O-level Physics (grade B).
    [2] http://en.wikipedia.org/wiki/Newton's_laws_of_motion
    [3] This may not be true. If you'll trust Wikipedia, why not trust me?
    DR, Mar 21, 2009
  17. Pip Luscher
    Eiron Guest
    Put your own brain into gear, frag. You need power to overcome friction.
    It was Champ's lack of understanding of the science of circular motion
    that we were discussing.
    See the moon in the sky? Where's the power to keep it orbiting at a
    constant speed?
    It's all explained earlier in the thread.
    Eiron, Mar 21, 2009
  18. Pip Luscher
    frag Guest
    Eiron wibbled...
    You are wibbling on about perfect frictionless systems.
    Champ is wibbling on about a bike going round a corner.
    You can't just ignore half the environment (friction, engine braking, air
    resistance), extract whats left and then say its wrong.
    frag, Mar 21, 2009
  19. Pip Luscher
    Gravitational forces.
    Ace, Mar 21, 2009
  20. Pip Luscher
    Eiron Guest
    Isn't that just what Champ did here:
    "The 'science' behind this is that turning (changing direction) is
    "acceleration, and to accelerate you need a force. So, even to corner
    "at a steady speed, you need some power."
    He seems to have ignored "friction, engine braking and air resistance",
    which is the only reason you need some power to corner at a steady speed,
    extracted what's left, and wrongly deduced that a centripetal force
    requires some power.
    Eiron, Mar 21, 2009
