Paging the S.O. MZ isti. (Sweller?)
Discussion in 'UK Motorcycles' started by Drew, Aug 29, 2010.
  1. Drew
    Drew Guest
    Morning All
    In your humble opinion, (Ha!)
    Would a MZ 150 TS (1980) make a good winter hack (through the town, no
    motorway stuff) or would I be buying a lot of grief, acording to the
    seller it is totaly original and hasn't been on the road for a year
    but "starts first kick".
    Am I likely to be constantly fettling it or are they pretty bombproof.
    Drew
    Drew, Aug 29, 2010
  2. I bought a TS150 from Sweller and it was a perfect town hack.
    It's not completely fit-and-forget, no, as drum brakes need adjustment,
    and ignition timing needs re-setting periodically, but as a cheapo town
    hack for (say) £250, it's good.
    If it runs fine, just buy it.
    The Older Gentleman, Aug 29, 2010
  3. Drew
    It'll be fine - how much does he want for it and does it have an MOT?
    They're pretty unburstable but aren't massively keen on motorways. Keep
    the points and timing checked and it'll not mess you about.
    If the electrics play up check the state of the fusebox.
    I thrashed a 1980 TS150 to Brighton - Frankfurt and back over a long
    weekend.
    sweller, Aug 29, 2010
  4. Drew
    Cab Guest
    <snip>
    Has the question ever been asked, as to what is the most bombproof bike?
    My top 3 choices (with N° 1 being the most bombproof) would be:
    1. Honda CX500
    2. Kawa GT550
    3. Yam XJ900
    Cab, Aug 29, 2010
  5. Drew
    Drew Guest
    No MOT, it's this one http://cgi.ebay.co.uk/220660495729
    I've read your MZ pages, lots of usefull and interesting information,
    Ta.
    Drew
    Drew, Aug 29, 2010
  6. Drew
    Honda XR400.
    Krusty, Aug 29, 2010
  7. 'Kin'ell, that's quite nice. Alpine model wiv the desirable rev counter.
    And it's even got the toolkit present. Helluva long way from
    civilisation, mind, unless you live close by or can UR it.
    I'd buy it if it was closer to London. Every few years I get the MZ itch
    and it's a couple of years since my last one.
    Hell's bells, let it run until the last few seconds and throw £250 at
    it, and it ought to be yours.
  8. Hope so, because I've just bought one for Number One Son's 21st. But as
    with the CX, a million despatchers can't be wrong. Can they?
    Hmmmmm.....
    I'd add Honda CD200 Benly, BMW two-valve K (75 or 100, any model), Honda
    VFR750.
  9. Drew
    Camchains & water pump seals?
    Pip Luscher, Aug 29, 2010
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, Krusty
    <rolls eyes>
    You know *nothing*.
    Honda C90
    Wicked Uncle Nigel, Aug 29, 2010
  11. Drew
    It looks like a Lux - and they all had rev counters by that time. The
    rare ones (in the UK at least) are the speedo in the headlamp models.
  12. Drew
    <rolls eyes>
    Yeah, cos those legshields are really bombproof aren't they.
  13. I defer to the expert :)
  14. Camchains were sorted by the time the A model came along. Seals -
    yeah....
  15. Drew
    Wnich was the A model? My CX500EC had a buggered chain - it had eaten
    away the guides, too.
  16. Drew
    GS 550E - needs a Scotoiler but the engine is pretty unburstable (copy of
    a Kawasaki?) nice gearchange too. Mine handled and stopped ok for a
    1970s UJM.
  17. First one to come with the little flyscreen as standard
    Odd. They were sorted by then - or should have been.
  18. Drew
    crn Guest
    All MZ stuff is built to be thrashed around abysmal lanes by illiterate
    roooshan farm labourers so they are generally idiot resistant.
    Listen for engine noises, if there is any hint of clattering walk away,
    otherwise it should see you out with a bit of care.
    crn, Aug 29, 2010
  19. Drew
    crn Guest
    It depends where you live, Ayrshire is a bloody long way from anywhere.
    If it is practical for you to collect it should be worth around £250
    but will probably fetch less for the location and the fact that all
    of the bidders have vanished for the holidays.
    crn, Aug 29, 2010
  20. Drew
    Bullshit.
    They're based on a pre-war joint BSA/DKW design aimed at the lightweight
    motorcycle market. The Bantam is an MZ engine in reverse.
    **** all to do with "rooshan" farm labourers (it was a Nazi era project).
    As to the clattering they don't - they knock if the big end bearings are
    shot. Oh, and don't believe the MZs knacker mains - it only applied to
    very early ES 250 engines (different lube system). TS125/150s mains are
    lubed by gearbox oil.
    Small ends are almost a service item and a *very* quick and cheap fix.
    Once again you know nothing - although why I'm in the slightest bit
    surprised I don't know.
