Paging the S.O. MZ isti. (Sweller?)
Discussion in 'UK Motorcycles' started by Drew, Aug 29, 2010.
  1. GPZ900R, CBR600, FireBlade, even.
    The Older Gentleman, Aug 29, 2010
  2. The Older Gentleman, Aug 29, 2010
  3. Drew
    Drew Guest
    Fortunately I live miles from civilisation so it's only 5 miles from
    me, my only qualm it the fact it is so complete and original, seems a
    shame to use it on the salted roads, even with a coat of AF50.
    I've been trying to phone the seller all morning to arrange a viewing
    but he's not answering his phone.
    Cheers for the advice.
    Drew, Aug 29, 2010
  4. Drew
    Plaster it in Waxoyl.
    Away for the bank holiday weekend?
    sweller, Aug 29, 2010
  5. Drew
    crn Guest
    Same principle. Built for cart tracks.
    OK, clever clogs, show me a Bantam engine with the mains lubricated by
    gearbox oil. Clatter schmatter - it the engine makes noises it needs
    money spent.
    Bantam small ends do not give problems, its a totally different engine
    only marginally related to the Bantam.
    You are hooked on a meme - get over it.
    crn, Aug 29, 2010
  6. Drew
    I suppose at least he can chop it in in part-ex against something worth
    being seen dead on.
    ogden, Aug 29, 2010
  7. Drew
    Nazi Germany was not the same peasant economy as the 1930s Soviet Union.
    Check seal order on right hand side - main is lubed by gearbox oil. Left
    hand side is dry - receives lube from petroil.
    http://www.sweller.dynalias.org/docs/Pages from D14manual.pdf
    It's reversed on an MZ but same dual bearing arrangement of the clutch
    side.
    Occasional fault is the engine sucks in gearbox oil - usually if it's
    been stood for a long period and the seals have failed. Smells vaguely
    like frying onions.
    Not necessarily - I can rebuild TS engines quickly and cheaply.
    Admittedly it was only one of my TS that ate small ends - Bantams had
    brass bushes and 70s/80s TS have needle bearings that don't like being
    over-revved. Early German RT/ES engines also have bushes.
    Looking up detail on the pre-war deal I can't find my MZ book - Wikipedia
    claims the Bantam to be part of war reparations. Still the same RT based
    engine. So wrong again.
    It's not a meme - it's a fact.
  8. Drew
    Nige Guest
    hehe - they are an aquired taste, that i will say, but cheaper than a pint
    of water & probably good fun...
    Nige,
    'Candygram for Mongo'
    R1
    Nige, Aug 29, 2010
  9. Drew
    ZX7R, at least until Champ got his hands on one.
    ogden, Aug 29, 2010
  10. Very true. OTOH, something cheap to run with a reputation for solidity,
    and shaft driven as well, is just what an impecunious studen with zero
    mechanical sympathy needs.
  11. See Sweller's reply. In any case, MZ paintwork was always very thick and
    durable and the quality of the alloy castings top-notch.
    Chrome used to pit a bit, but you can't have everything.
  12. Drew
    Any student sober enough to ride a bike without being significantly over
    the limit is missing the point of being a student.
    ogden, Aug 29, 2010
  13. Drew
    Fucking useless as a town hack, in fact they're fucking useless at
    pretty much everything involving tarmac - I know because I had one.
    Their only purpose on this planet is to teach the previously inept how
    to pull good wheelies, at least that's all mine got used for.
    Lozzo
    Versys 650 Tourer, CBR600F-W racebike in the making, TS250C, RD400F
    (somewhere)
    they churn out)
    Lozzo, Aug 29, 2010
  14. Drew
    You've not been around long enough to know that when Sweller says
    anything about MZs, you know it'll be correct and on the button. He
    probably knows more about MZs than any person who was ever employed at
    Zschopau.
    Lozzo
    (somewhere)
    they churn out)
    Lozzo, Aug 29, 2010
  15. Drew
    Drew Guest
    Bugger, out sniped, it went for £275, I went to see it earlier and it
    was in lovely condition and covered in old waxoyl, but the seller
    couldn't start it as he was still awaiting a battery for it, so I
    stuck to a max bid of £250, bugger.
    Oh well, back to e-bay.
    Drew, Aug 29, 2010
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    I love it when you do this. Your ability to pick out renowned experts on
    any given matter, and contradict them is quite remarkable.
    Wicked Uncle Nigel, Aug 29, 2010
