Paging the scientists
Discussion in 'UK Motorcycles' started by Nicknoxx, Mar 31, 2006.
  1. Nicknoxx
    Nicknoxx Guest
    Two turbulence question.
    1. Why are fairings smooth? Golf balls are dimpled to generate boundary
    layer turbulence which reduces drag. Why not a bike fairing?
    2. Wind breaks allow some air through to reduce turbulence. Why don't
    bike screens have very small holes to allow air through?
  2. Nicknoxx
    I've seen dimpled fairings, now you mention it.
    Have you ever looked really closely at a fairing - full of holes, it
    is.
    Pip, Mar 31, 2006
  3. Nicknoxx
    Vass Guest
    cos I don't want my bike twatted by tiger woods!!
    the first blades did have :)
    Vass, Mar 31, 2006
  4. Nicknoxx
    Stritchy Guest
    I think the dimples are there to assist the directional stability
    BICBW
    Surely boundary layer turbulence increases drag rather than reducing
    it, which is why high speed aircraft are highly polished.
    Mine has two very nice slots on the windscreen, they supposedly reduce
    the 'vacuum' that forms behind the screen.
    Paging Michael Carley; do you still have the airflow pics of my old
    Pan?
    Stritchy, Mar 31, 2006
  5. Nicknoxx
    Paint yours with black paint mixed with sand, and see if it makes any
    difference.
    What, like that experimental plane with the holes that suck? Bit stupid
    to have that on a bike that doesn't go that fast.
    Muck, Mar 31, 2006
  6. Nicknoxx
    zymurgy Guest
    English Electric Lightning ?
    Paul.
    zymurgy, Mar 31, 2006
  7. Nicknoxx
    Naa.. the one I'm thinking about is an X plane.
    Muck, Mar 31, 2006
  8. Nicknoxx
    Nicknoxx Guest
    Well I was thinking more of those windbreaks you see behind the seats of
    a convertable cage
  9. Nicknoxx
    OH- Guest
    The dimples actually increase drag from the front side of
    the golf ball. This is also true for other designs that
    increase turbulence, you might have seen them on parts
    of the upper surface on airplane wings.
    The desired effect is to get a more "energetic" boundary
    layer that will follow the surface as far as possible on the
    rear side of the object. That way the golf ball does not
    have to fight a large low pressure area where the air flow
    has separated completely. And the wing will respond to
    steering input or use of flaps instead of going into a stall.
    Now, as bike fairings have no rear half to talk about, it is
    of little use to create more drag on the front side as it
    will separate totally at the edge of the fairing all the same.
    Off course there may be designs of fairing or fairing +
    rider that might benefit from increased boundary layer
    turbulence and the designer would find this out by doing
    wind tunnel testing (or computer simulation, I guess).
    OH-, Mar 31, 2006
  10. Nicknoxx
    Mups Guest
    The CBR Thou has a slit at the base of the screen to reduce turbulence.
    Mups, Mar 31, 2006
  11. Nicknoxx
    I don't take much notice.
    Muck, Mar 31, 2006
  12. Nicknoxx
    ts Guest
    Because it is the larger scale shape of the fairing that decides whether
    the air that slides off it gets turbulent, or flows in a smooth laminar
    way?
    Because it would also allow rain water through, to make you wet and the
    electrical system corrode?
    My 2p's worth.
    ts, Apr 1, 2006
  13. Nicknoxx
    Linger Guest
    They also spin and create lift, you wouldn't want that on a bike.
    Some do, the pan has little vents IIRC.
    Linger, Apr 1, 2006
  14. Nicknoxx
    CBR thou and 'aerodynamics' don't sit comfortably with each other.
    ogden, Apr 2, 2006
  15. Nicknoxx
    JackH Guest
    You've not really spent much time looking at anything post the early models
    then, have you really.
    JackH, Apr 2, 2006
  16. Nicknoxx
    "when fluid dynamics go wrong"
    Andy Bonwick, Apr 3, 2006
  17. Nicknoxx
    gomez Guest
    Gofl balls are made in such a way as to limit the distance they can be
    hit with modern clubs. Otherwise, they would have to keep lengthening
    the holes to avoid turning all the current courses into pitch and
    putts.
    gomez, Apr 3, 2006
  18. Nicknoxx
    Linger Guest
    Absolute tosh. Dimples are there to aid flight not reduce it.
    Dimples or texturing have been on golf balls since the gutta percha balls of
    the 1800's
    Linger, Apr 7, 2006
