paging the scotchlokisti
Discussion in 'UK Motorcycles' started by Derek Turner, Jul 16, 2009.
  1. Derek Turner
    Derek Turner Guest
    They say the only stupid question is the one you don't ask so...
    Scotchloks: I've never used them before - can you only join two wires
    with each or two 'tap' wires (or more) be used in the same device with
    one 'run' wire?
  2. Derek Turner
    Colin Irvine Guest
    I would keep it that way.
    Colin Irvine, Jul 16, 2009
  3. Derek Turner
    They're designed for only 2 wires, but if the wire guage is small
    enough, you can probable squish more in. Or you could just connect the
    wires properly.
    Krusty, Jul 16, 2009
  4. Derek Turner
    Doki Guest
    Just use crimps.
    Doki, Jul 16, 2009
  5. Derek Turner
    Adrian Guest
    Indeed. They're not called bodgeloks for nothing.
    Adrian, Jul 16, 2009
  6. Derek Turner
    zymurgy Guest
    Don't use scotchloks. They're a nasty bodge. Motorcycles are open to
    the elements, so you're trying to keep damp and wet out of the loom as
    far as possible.
    Use bullet connectors, soldered for preference rather than crimped.
    Cheers,
    Paul.
    zymurgy, Jul 16, 2009
  7. Derek Turner
    Catman Guest
    I've never had any trouble with them, though granted I've never used
    them in a hostile environment. What's wrong with them, apart from the
    obvious that if you use too small a device, you're cutting the wire.
    www.cuore-sportivo.co.uk
    Catman, Jul 16, 2009
  8. Derek Turner
    AAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaargh.
    Timo Geusch, Jul 16, 2009
  9. Derek Turner
    Derek Turner Guest
    OK I see your point but this is under the seat of a Pan European: very
    dry and well out of the elements. I'm wiring in the socket for a trailer.
  10. Derek Turner
    Colin Irvine Guest
    The wire will probably be either too big or too small for the
    scotchlok, so will either be loose or partly severed, the connection
    is open to corrosion and the contact between the narrow scotchlok
    blade and the wire is inferior to a proper joint.
  11. Derek Turner
    zymurgy Guest
    If you use scotchloks for that you'll be "bodging in the socket for
    the trailer". Seriously, they're not great on bikes, as they're
    difficult to make weatherproof. At the very least, use heat shrink
    sleeving.
    Cheers,
    Paul.
  12. Derek Turner
    Catman Guest
    Well that's user error, but fair point.
    Yeah, I don't use them except inside.
  13. Does anyone else hear a faint "Fizzzzzz*POP*" and small plume of smoke
    in his immediate future?
    The Older Gentleman, Jul 16, 2009
  14. Derek Turner
    boots Guest
    Mr Pot, there's a Mr Kettle calling.
    boots, Jul 16, 2009
  15. Derek Turner
    zymurgy Guest
    What ?
    Bullets are best, followed by Lucars (blade connectors). As long as
    they're covered in the/a weatherproof sheath, they don't seem to
    suffer.
    The bullet connectors I use are rubber covered, so the only piece
    that's exposed is the back of the connector with the wire up it, not
    the contact area.
    http://www.jhps.com/Merchant2/graphics/00000001/bullet4way.jpg
    You can't crimp a proper bullet (like used on old Triumphs/landrovers)
    they have to be soldered.
    http://www.skjagtech.co.uk/images/electrical-tools-and-consumables/bullet.gif
    You can crimp the later ones.
    http://www.toolstation.com/images/library/stock/webbig/16468.jpg
    Paul.
  16. Derek Turner
    Adrian Guest
    No, it's inevitable, since they're pretty much one-size-bodges-all.
  17. Derek Turner
    Beav Guest
    Bullet connectors are responsible for more failures than scotchloks. They're
    (both) only any good for a quick fix until you can get the job done properly
    with solder and heatshrink toobing.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 16, 2009
  18. Derek Turner
    Beav Guest
    If there's *any* vibration, steer clear of scotchloks. What's that old
    saying now? Ah yes, "You have been wanred"
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 16, 2009
  19. Derek Turner
    zymurgy Guest
    Well, there's a lot of classic cars and Land Rovers that would
    disagree with you. As long as you don't let the magic smoke out ...
    Well, yes, that's a permanent connection. So what do you suggest for a
    demountable connector ?
    Paul.
  20. Derek Turner
    Adrian Guest
    The problem isn't with the bullet-to-bullet connection, but with the
    bullet-to-wire connections.
