Paging the SOBMWisti
Discussion in 'UK Motorcycles' started by Rick, May 10, 2009.
  1. Rick
    Rick Guest
    What oil do you put in yours? I'm currently using semi synthetic 10w40 ('cos
    I've got a lot of it) and the bike is going through about half a litre every
    500 miles or so. Would using the recommended 20w50 make any difference?
    Rick, May 10, 2009
  2. Rick
    Yes, 20W50 makes a massive difference to the oil consumption on both the
    airheads and the oilheads.
    Timo Geusch, May 10, 2009
  3. Possibly. Try it and see.
    The Older Gentleman, May 10, 2009
  4. Rick
    From my sample of 1, I agree.
    At 18k, when my BMW dealer started using 20W/50 Castrol, my bike went from
    using 500ml per 1000 miles to about 500ml between services, i.e. reduced by
    five sixths.
    I use an independent service bloke now and he advocates 20W/50 too. He uses
    a Valvoline mineral oil. At 39k now, the oil consumption is still around
    500ml between services.
    Like you, I've got a can of 10W/40 in the garage, used for topping up the
    car. I use this to top up the bike too.
    wessie, May 10, 2009
  5. Rick
    Gyp Guest
    I've always used "basic" 20W50 and never needed to top up between
    services, but this time went for Halfords 15/40 semi synth as it was on
    special offer. Based on the comments of the rest of the SOBMWisti, I'll
    keep an eye on it.
    Gyp, May 10, 2009
  6. Hm. Maybe that's why my K is using rather less oil since Brian serviced
    it than it was before. I was just topping it up with 10/40, and it was
    using a bit.
  7. Rick
    I bet he's using 10W40 or 15W40 as you normally have to request
    20W50. BMW usually specifies 15W40 up to 20C so once it gets warmer they
    start using oil.
  8. Rick
    malc Guest
    I've been trying to get some today, it's non existant in Halfrauds and even
    Asda only had a shite 20W50. Looks like I'll have to try a proper motor
    shop.
    Malc
    Rusted and ropy.
    Dog-eared old copy.
    Vintage and classic,
    or just plain Jurassic:
    all words to describe me.
    malc, May 10, 2009
  9. Rick
    Depends on what sort of 20W50 you're after. It seems the good ones are
    almost always mail order only these days.
  10. Rick
    Halfords sell it as "Classic Motor oil" in a tin, like the olden days.
    http://www.halfords.com/webapp/wcs/...151_storeId_10001_partNumber_537977_langId_-1
    API SE CC - so fine for older BMW boxer twins like my 9 year old 1150.
    The Asda, Wilco & Tesco cheap stuff does not declare an API rating so, as
    you say, avoid. Any motor factor such as Partco will have a 20W/50 in stock
    from Carlube, Unipart etc.
    For those with wet clutches, that want a JASO approved oil, then many of the
    mainstream bike oil makers have a 20W/50, often labelled "for V twins" as
    Harley & Moto Guzzi specify it.
    M&P carry a variety in mineral, semi & full synth flavours
    http://www.mandp.co.uk/products/list/Lubricants/4-Stroke-Oil
    Also http://www.opieoils.co.uk/c-785-20w-50.aspx lists some other brands
  11. Bloody useful stuff. Thanks.
  12. Yes.
    Grimly Curmudgeon, May 10, 2009
  13. Rick
    Malc Guest
    I did look in their internet site yesterday. In the BMW pages under
    lubricants they do list a 20W50 for not very much money so maybe I
    will take a look on the way home some time.
    Malc, May 11, 2009
