Paging the SOBMWisti
Discussion in 'UK Motorcycles' started by rick, Oct 28, 2009.
  1. rick
    rick Guest
    I finally got round to looking at my old R100RT which has been standing for
    a couple of months after it started running very roughly following a missed
    gear change and consequent over revving. The inlet valve on the left is
    stuck open. I will admit to a fairly high level of mechanical numptiness but
    it looks like a fairly straightforward job to sort the bike. With winter
    approaching I'd like to have the old heap running for when it gets really
    shitty. So is it an easy job? Is there anything I should know that isn't in
    the Haynes manual. Help please.
    rick, Oct 28, 2009
  2. Yes. Pushrod head. Simple.
    The Older Gentleman, Oct 28, 2009
  3. rick
    'Hog Guest
    "Stuck open". You mean as in bent? This usually damages the p.bronze valve
    guide too so it is worth having a FOAK do the valve/guide/seat for you.
    'Hog, Oct 28, 2009
  4. rick
    crn Guest
    Sounds like the valve stem got bent by the piston whacking the valve.
    Time to get the head off and see how much damage has been done, usually
    just a new valve is needed.
    Dont attempt to straighten it, the stem has been weakened and could
    break at some random time in the future causing serious damage.
    crn, Oct 28, 2009
  5. rick
    rick Guest
    Yes probably bent. The spring doesn't move when I turn the engine on the
    back wheel (so the rocker ends up with about half an inch clearance).
    Assuming it does need a valve guide is it that hard a job?
    rick, Oct 28, 2009
  6. rick
    Simon Wilson Guest
    Worrabout the pushrod - that might be bent as well?
    Simon Wilson, Oct 28, 2009
  7. rick
    'Hog Guest
    They have plenty of give in them. Usually. But it will be obvious when the
    head comes off. One would naturally check all the valve train. The screw
    and locknut followers can mushroom or split for instance.
    All these parts are very cheap from Motorworks though.
    Has anyone said Clumsy **** yet.
    'Hog, Oct 28, 2009
  8. rick
    rick Guest
    Me about 50 times on the way home.
    rick, Oct 28, 2009
  9. rick
    boxerboy Guest
    All what they said above. If its not been converted to run on unleaded
    then it may be worth doing the vales, guides and seats etc all at the
    same time. Motorworks and several other people do an exchange heads
    package deal. If the bike is up around the 70K plus miles then it may
    be worth doing this anyway as the valve heads are welded to the stems
    and with hard use and high miles they have been known to part
    company.
    Its all basically very simple engineering.
    Boxerboy
    boxerboy, Oct 28, 2009
  10. rick
    malc Guest
    Phil Hawkesley's BMW forum is a good place to look as well.
    http://www.bmbikes.org.uk/Forum/index.php?sid=84bf49df3df4e4d19d9dfbee76c2ae85
    There's lots of technical stuff there as well as helpful bods. You may have
    to register to get the technical pages though.
    Malc
    Rusted and ropy.
    Dog-eared old copy.
    Vintage and classic,
    or just plain Jurassic:
    all words to describe me.
    malc, Oct 29, 2009
