Paging the Triplisti
Discussion in 'UK Motorcycles' started by Catman, Jan 5, 2006.
  1. Catman
    Catman Guest
    Speedo on the Triple (2003) has packed in. It stopped briefly last year, but
    came up again after a reboot as it were. Currently it reads 0 or 1 mph on
    occasion. Given my current point total and need for licence, this is not
    good.
    I'm geussing at a loose connector / cable somewhere, so does anyone know
    where the sender is before I have to cart it off to the dealer (I hope
    under warranty)
    TIA
    Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 OMF#22
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 156 TS S2
    www.cuore-sportivo.co.uk
    Catman, Jan 5, 2006
  2. Catman
    flash Guest
    If your tacho is still working then you can roughly work out speed in your
    head as follows:
    (rev counter reading /100) * (currentgear/currentgear+1)
    flash, Jan 5, 2006
  3. Catman
    Catman emerged from their own little world to say
    Not Triumph, but the 2 bikes I had with electronic speedo sensors, both
    took readings from a sensor on the front sprocket.
    Follow the cable from the sensor and see if there is a connector where this
    wire joins the main bike wiring loom. On one of my bikes this was just
    behind where the main loom emerged from under the tank, to run along the
    subframe rail to the rear end.
    wessie, Jan 5, 2006
  4. dunno. try phoning flitwick and explain your problem, they'll prolly
    tell you.
    Adie
    Triumph 955iSS / ZX9R E1 / GSF1200 bandit (for sale) / CG125
    Adrienne M Bonwick, Jan 5, 2006
  5. Catman
    Catman Guest
    Oooh, ta
    <fx: crash while trying to do mental arithemtic> ;)
    Catman, Jan 5, 2006
  6. Catman
    Catman Guest
    Problem is there are lots of things that look like sensors :(
    Cheers anyway
    Catman, Jan 5, 2006
  7. Catman
    Catman Guest
    Good thought, cheers.
    Catman, Jan 5, 2006
  8. Catman
    WavyDavy Guest
    revs - 5000, gear - 6th
    By your calculation, that's 5000/100 x 6 (or 7)
    So that's 300(or 350)mph......
    Hmmmmm. Maybe I should swap the Daytona for a Speed triple.
    WavyDavy, Jan 5, 2006
  9. Catman
    WavyDavy Guest
    Don't know the answer to the problem, but until it's sorted:
    Most bikes I've had have always had one gear where 1000rpm is roughly 10mph.
    My Daytona does that in 2nd, the NS in 3rd, the R6 was 3rd, but changing the
    gearing messed all that up.
    Given the Speed triple is probably lower geared than a Daytona, I'd got for
    3rd gear, just under 1000rpm per 10mph to keep you relatively safe until it
    gets fixed. Ish
  10. Catman
    Nicknoxx Guest
    You seem to have interpreted the two "/" signs to have different
    meanings. I'd suggest 5000/100*6/7 = 42.8
    Nicknoxx, Jan 5, 2006
  11. Catman
    WavyDavy Guest
    Ahhhhhhhhhhhhhhh! I think I may have done... I don't think I could work
    that one out on the move (esp all the decimal places....), given I couldn't
    work it out sat still.
    Plus, I don't think a Speed Triple would be doing only 42.8mph at 5000 in
    top....... My Daytona's doing around 90 at those revs.
    So, in proper ukrm tradition, even though I'm wrong, I'm right, too. :)
  12. Catman
    Catman Guest
    Cheers. That sounds about right. I'm prety sure it's 70 at 4.5k in top, so
    that's OK, it's more the 30 and 40s that are worrying me. 3rd should do
    fine.
    Catman, Jan 5, 2006
  13. Catman
    Catman Guest
    Still well wrong now I think about it. 5k in 6th >70mph
    Catman, Jan 5, 2006
  14. Catman
    Catman Guest
    Good point, Perhaps my mate with the Speed Triple would be a sensible
    choice. *D'oh*
    Added to 'To Do' list
    Catman, Jan 5, 2006
  15. Catman
    SteveH Guest
    Tankbag + your SatNav kit.
    HTH.
    SteveH, Jan 5, 2006
  16. Catman
    Knowing you, you probably mean it too.
    Although it brings us on to "instrumentation that should have died at
    birth" ... I nominate Kawasaki, for their brilliant idea of putting a
    hard-to-read-in-sunshine LCD fuel gauge on top of the tank on the GPZ &
    750 Turbo models. Good call chaps, nice one.[/QUOTE]
    Try Kawasaki fitting a hard to read LCD tacho on their top of the
    range sports bike for the last two years. Apparently they've changed
    it for this years model but the tacho on my 10R is fucking useless.
    Andy Bonwick, Jan 5, 2006
  17. Catman
    Catman Guest
    Not a chance. I'd lob it down the orad trying to see the damn display.
    Catman, Jan 5, 2006
  18. Catman
    Not if the road's twisty, I go by engine feel or by the limiter.
    Having said that, if you hit the limiter you've fucked up by about 1k
    rpm as far as peak power is concerned. I've got a change light I can
    set to whatever I want if I feel the need to do so (never do though)
    but when I was running the bike in the tacho was a bit of a must.
    My bait's better than yours so go **** yourself.
  19. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    Oh, but it is, you know.
    Wicked Uncle Nigel, Jan 6, 2006
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    Well.
    OK, I'm no riding God. More a riding Goit.
    However. It's a fucking animal. I have to lean back to even see the
    clocks, and I can categorically state that on the go that Bonners let me
    have[1] I didn't bother. Not even once.
    [1] He honestly didn't look that pissed.
