Paging the Voltage Regulatoristi
Discussion in 'UK Motorcycles' started by rick, Apr 16, 2011.
  1. rick
    rick Guest
    As I just had to replace a dead battery on the Sprint I decided to check the
    regulator. I'm getting 14V at just above tickover but this drops to around
    13.65V as the revs go up. Is this correct? (I half expected the opposite
    ie;13.5V at tickover rising to 14V).
    rick, Apr 16, 2011
  2. rick
    Sounds fine. You will be putting a bigger load on the system at higher revs
    as the spark plugs etc will need to produce more bangs per second. If the
    alternator is the typically weedy affair fitted to most bikes then the
    tickover voltage with a very low load i.e. no headlight glowing, could be
    where you see the highest voltage.
    As long as the voltage across the battery remains over 13V then you will be
    sticking plenty of electrons back into the battery.
    wessie, Apr 16, 2011
  3. rick
    rick Guest
    Cheers Wessie :)
    rick, Apr 16, 2011
  4. rick
    Ian Field Guest
    Actually the coils - well er being coils, are inductive, that means as the
    frequency increases the impedance increases.
    With the old Kettering ignition (points) it was commonplace to either wind
    the LT coil with high positive tempco wire or use a series ballast resistor.
    This is because if the engine stalls with the points closed, the LT coil can
    draw enough current to burn out.
    Ian Field, Apr 16, 2011
  5. rick
    Speaking as UKRM's resident electronics expert, I think#~{{&%"¬`#NO
    CARRIER
    Krusty, Apr 16, 2011
  6. rick
    rick Guest
    CARRIER
    rick, Apr 16, 2011
  7. rick
    Nige Guest
    wtf? are you on crack?
    Nige, Apr 16, 2011
  8. rick
    Simon Wilson Guest
    Oh dear. You must be too young.
    Simon Wilson, Apr 16, 2011
  9. rick
    Simon Wilson Guest
    Haha
  10. Given what happens when you charge a battery and the way that the
    surrounding environmental issues can affect what you read on the meter the
    question is reasonable. Person anally I would be happier to see a higher
    voltage at around a quarter to a third revs but a good old fashioned zero
    tech eyeball check of how much the lights brighten when going from tick
    over to this speed is just as good as any reading you can take from a
    meter.
    steve auvache, Apr 17, 2011
  11. rick
    Ian Field Guest
    You're on about dwell angle I was talking about frequency.
    Ian Field, Apr 17, 2011
  12. rick
    Traditional ignition systems (points or transistorized) store a finite
    amount of energy for each spark: I doubt that would change much with
    engine RPM. You're looking at it from a pure inductor/frequency POV,
    which doesn't really apply here.
    If it's a basic CDI system then again, the capacitor will store a
    finite amount of energy for each spark.
    Having said that, I'm not certain that Wessie's correct here. While
    the ignition & FI (if it has this; CBA to Google) current draw will go
    up with revs, so will the alternator output current. I guess it comes
    down to which curve has the steeper slope.
    Pip Luscher, Apr 17, 2011
  13. rick
    well, it could be that his alternator brushes are fucked and make less
    contact at higher revs. For now, the 13.65V will do and rick won't have to
    spend any more on the bike, today.
    Of course, we could send him out to the shed to test the alternator under
    the load of his headlamp which would give a better diagnosis of the
    charging system's health. As rick has publicly stated that he is skint I
    don't think he wants to know...
    wessie, Apr 17, 2011
  14. rick
    rick Guest
    I'm so skint I can't even afford a shed :(
    rick, Apr 17, 2011
  15. You were wibbliung on about the frequency with which the spark happens and
    are wrong.
    The spark itself is unchanging, a mere transient pulse a few
    thousandths[1] of a second long. Engine speed will not affect this at
    all. What will happen with increased engine speed is that this extremely
    short lived pulse of energy will occur more often. Thus leading to the
    confusion of the ill educated in the manner you so ably demonstrate.
    [1] Actually I don't have a clue how long this is but I do know it is
    almost as quick as a libdem dumping manifesto pledges. Which, as we all
    know children, is pretty dammed quick.
    steve auvache, Apr 18, 2011
  16. rick
    Ian Field Guest
    I can give you the facts and you can look up the formulaes and figure it out
    yourself.
    With points the dwell angle is fixed and doesn't change (notwithstanding
    points bounce at high revs).
    When you apply a voltage across a coil (inductor) the current starts at next
    to nothing and rises linearly as the lines of flux build up around the
    core - when the core saturates, the inductance value disapears and the
    current is determoned purely by the DC resistance of the winding wire
    (shouldn't happen in normal operation).
    When you interrupt the current, the lines of flux collapse around the core -
    which happens much more rapidly than due to the linear rise in current that
    put the energy there in the first place - that's the bit that produces the
    much higher voltage.
    Because the dwell angle is fixed, as the revs increase the time period for
    current flow into the coil decreases in direct proportion of 1/T, the
    current is interrupted earlier on the linear rise in current therefore the
    average current draw is less.
    I rather doubt that any TAC pulsers use a monostable (fixed charging period)
    as making the charging period short enough to fit the available time period
    at maximum revs would make it too short for efficient operation at tickover,
    and cold starting a real pig!
    CDI depends entirely on the design (I'd say the HV winding on the alternator
    is probably best) Transistorised one's will have less time to charge the
    capacitor at high revs - some types have a feedback system that makes the
    inverter work harder during the low end of the charging curve, these will
    draw more current at high revs.
    Ian Field, Apr 18, 2011
  17. Indeedly so. It was well known in the days of contact/coil ignition that
    yer typical car coil would draw 4A at tickover and 2A at normal road
    revs.
    Grimly Curmudgeon, Apr 18, 2011
  18. rick
    Ian Field Guest
    Inductance may not be the only factor.
    Tests on a CB200 coil (and several others in the junk box) showed that when
    connected across a 12V battery, the curent started at about 8A and slowly
    sank to about 4A.
    Evidently they wound the LT coil with PTC wire to eliminate burnout if it
    stalls at points closed.
    Although on cars ISTR you're more likely to find a ballast resistor.
    Presumably that limits the current if stopped with points closed, as the
    revs increase and coil current falls the volt drop will shift from the
    resistor to the coil - improving spark performance at high revs.
  19. rick
    Well, having looked it up, Im surprised at how slowly the old points
    ignition coil current rises: you live and learn.
    Pip Luscher, Apr 18, 2011
  20. rick
    That made me think: as far as I know, I've only ever owned one bike
    that had a field coil alternator, and that didn't use slip rings - the
    exciter coil was mounted on the engine cover. All the rest have been
    PM alternators.
    <sand drips out of ears>
    Sorry? What?
