Paging the Windowsisti (FOAK)
Discussion in 'UK Motorcycles' started by Derek Turner, Apr 27, 2008.
  1. Derek Turner
    Derek Turner Guest
    Does WinXP need to be on the first partition to be bootable?
  2. Derek Turner
    Cane Guest
    Yes.
    Cane, Apr 27, 2008
  3. Derek Turner
    Higgins Guest
    Higgins, Apr 27, 2008
  4. Derek Turner
    ginge Guest
    Actually No.
    But you do need a suitable bootloader on the first partition.
    ginge, Apr 27, 2008
  5. Derek Turner
    Tim Guest
    No.
    Tim, Apr 27, 2008
  6. Derek Turner
    Derek Turner Guest
    That, of course, is what's on the first (extended) partition at the
    moment :)
  7. Derek Turner
    Derek Turner Guest
    I'd much rather have third-degree burns.
  8. Derek Turner
    Derek Turner Guest
    Well, that's one vote each for yes and no! I've cloned my XP partition
    onto the end of my new hard drive and set it active but can't seem to
    boot it using GRUB. Googling told me Win2000 /has/ to be on the first
    partition and I wondered whether that was the case with XP. ATM I have a
    largish extended partition with two linux flavours, both of which boot OK
    but the XP clone doesn't seem to want to play. Hey ho!
  9. Derek Turner
    TD Guest
    Aren't you even going to post your menu.lst? This box (XP on hda2) has:
    title Windows XP
    root (hd0,1)
    makeactive
    chainloader +1
    TD, Apr 27, 2008
  10. Derek Turner
    ginge Guest
    And have you updated boot.ini accordingly too?
    ginge, Apr 27, 2008
  11. Derek Turner
    ginge Guest
    How about we try that first?
    ginge, Apr 27, 2008
  12. I'm surprised he's asking actually. Everyone knows about grub, surely?
    Paul.
    CBR1100XX SuperBlackbird (Buen mueble de patio)
    And a pushbike of some sort.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Ovejas y buitres:
    http://obscuredomainname.org
    Paul Carmichael, Apr 27, 2008
  13. Derek Turner
    Derek Turner Guest
    as the windoows partition wasn't there when the menu.lst was written it
    wouldn't help. Supergrub disk can't boot the partition so grub won't, I
    suspect. I've tried Paragon Partitionmagic (DOS-based) and here I am
    posting from that partition so it /can/ be booted, but Supergrub won't do
    it.
    *perks*
    what is this boot.ini of which you speak? where is it and how do I update
    it?
  14. Derek Turner
    ginge Guest
    As I posted the other day, I'm not here to teach you the basics of
    using windows. It's piss easy to find out about it using google
    though.
    ginge, Apr 27, 2008
  15. Derek Turner
    Derek Turner Guest
    Fair enough. I googled 'update boot.ini' and got absolutely no useful
    results. I did a search in my cloned XP partition for boot.ini (including
    hidden files) and got no results so obviously it's as piss-easy as
    everything in windows. Sorry to bother you.
  16. Derek Turner
    geoff Guest
    i think just "boot.ini" will get you there
    geoff, Apr 27, 2008
  17. Derek Turner
    ginge Guest
    hooray for common sense
    one could also try grub and boot ini, as both are probably required to
    give derek what he wants.
    ginge, Apr 28, 2008
  18. Snip
    boot.ini is in the root of the system drive but you need to set the
    view file options, so open up explorer and goto Tools->Options->View
    and select "Show hidden files" and uncheck the option that says "hide
    protected operating system files"
    Boot.ini will look something like this -
    [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP
    Professional" /fastdetect /NoExecute=OptIn
    As you can see it as the options to show which disk(0) and partition
    windows is installed in (1)
    Miles Reading, Apr 28, 2008
  19. Derek Turner
    TD Guest
    This sort of shit makes me laugh at the "Windows is user-friendly" cretins.
    Sniff away.
    TD, Apr 28, 2008
  20. Derek Turner
    Ben Guest
    Your average user, Windows or not, doesn't install multiple operating
    systems on multiple partitions.
    Ben, Apr 28, 2008
