Paging the ZZRisti
Discussion in 'UK Motorcycles' started by JackH, Aug 21, 2009.
  1. JackH
    JackH Guest
    Which models of these onwards were full power, and aside from rotting
    downpipes / saggy suspension etc, is there anything else to check for
    in particular on these?
    TIA
    JackH, Aug 21, 2009
  2. JackH
    JackH Guest
    1100 models rather than 600s, that is.
    JackH, Aug 21, 2009
  3. JackH
    Nige Guest
    Fucked front discs, fucked head bearings, camchain tensioners can go
    rattly, also there's a balancer shaft on the engine that gets
    overlooked, that can sound like camchain rattle. They eat cushdrive
    rubbers & they can be heavy on chains.
    Anyy 1100 can be made full power easily anyway, so don't let that put
    you off a good bike.
    Great bike, i have had a couple & loved them.
    Good fairing, but fit a MRA Vario screen for extra comfort.
    Parts are quite cheap & there's loads knocking about in breakers. Fit
    clear indicators from the ZZR1200 just makes it look a bit less dated.
    Nige
    Nige, Aug 21, 2009
  4. JackH
    JackH Guest
    ....same as most stuff then. :)
    Every bike I've had in recent times seems to have suffered with that,
    bar the VFRs for obvious reasons... but bored with those and want some
    real stomp for once, something a ZZR should provide in spades if what
    I've read about them so far is right.
    Is there any obvious way of differentiating between the two without
    physically stripping it down?
    Good good... I'd expect nothing less on a behemoth of this size which
    wasn't saddled with shaft drive.
    Aye... 'carb tops'.
    Would rather try and get hold of one already as it should be,
    though... for once I'd like to buy something I can just get on and
    ride, and not have to fettle first.
    Ok, cheers for the info. :)
    JackH, Aug 21, 2009
  5. JackH
    Nige Guest
    On the early models, think it was sorted D onwards
    Nige, Aug 21, 2009
  6. JackH
    Timo on tour Guest
    Famous last words...
    Timo on tour, Aug 21, 2009
  7. JackH
    at the price you expect to pay?
    Dream on.
    wessie, Aug 21, 2009
  8. JackH
    JackH Guest
    Indeed... which is why I want to go and look something over properly
    before I commit to buying it.
    JackH, Aug 21, 2009
  9. JackH
    JackH Guest
    Given I've not stated in here how much I expect to pay for a half
    decent one of these, you are Mystic Meg AICM5P.
    JackH, Aug 21, 2009
  10. JackH
    Switters Guest
    The very same carb tops that were on the ZXR750H1/2. Many a 750 owner
    found their second hand bikes had restricted carbs on them.
    Switters, Aug 21, 2009
  11. JackH
    Eiron Guest
    Was the restriction something you could remove with a Dremel or angle-grinder?
    Eiron, Aug 21, 2009
  12. JackH
    Switters Guest
    Nope, the carb top wasn't full height across the whole diameter, so when
    the slider was moved up, it came up short against the plastic. If you
    removed said restriction with said angle-grinder, you'd end up with no
    carb top affixed.
    Looking at it side on, it'd be something like this (fixed width font
    required)...
    As opposed to what it should look like...
  13. JackH
    JackH Guest
    A moot point now, anyway.
    Went and test rode the one I'd spotted locally, and found it had not
    really to my liking in terms of the front brake which seemed to come a
    bit too far back towards the bars.
    That, and the rear subframe looked a bit twisted... and it didn't feel
    all that quick to me, if I'm brutally honest.
    Anyway... I've just won this: http://tinyurl.com/n9b3ar
    Even if I don't like it, and even though I didn't really want
    something that needs a bit of fettling, I reckon it's a steal at that
    price. :)
    JackH, Aug 21, 2009
  14. JackH
    Timo on tour Guest
    And if you don't want it, I might not be interested in it at all, oh
    no. I don't like Italian V-Twins at all, me.
  15. JackH
    JackH Guest
    I thought you were meant to be reducing your stock? :p
    JackH, Aug 21, 2009
  16. JackH
    Timo on tour Guest
    Yes, yes, I know. I actually have and I don't really want another bike
    at the moment. But that's never stopped me.
  17. JackH
    1100 models from 1997 onwards were full power. It is so simple to check
    if it has been restricted. The de-restricted models have carb tops from
    the early ZXR750 fitted. These have a straight sides about 25mm tall
    and a flat top with a small button sitting proud in the middle. The
    restricted carb tops are shallower, about 10mm tall with a taller
    centre button.
    You can see them if you squint under the tank from either side. A
    restricted one is not noticeably slower through the gears until you
    stick a derestricted one next to it in a top gear roll on. They're
    giving away 15bhp but you don't really miss it.
    Lozzo, Aug 21, 2009
  18. JackH
    Only on C1 models, the very first ZZR1100. They were sorted on the C2,
    and most of the C1s that had problems.
    Lozzo, Aug 21, 2009
  19. JackH
    how much. How Much. HOW FUCKING MUCH
    JHC all Aprilia 4T's ever built throughout the history of time are truly
    awful bikes that should never be owned.........but that is an incredible
    bargain. Is it Cat D or something!
    And it's only done 20k, sheesh!
    Hog, Aug 22, 2009
  20. JackH
    Nige Guest
    It is cheap, but it will be rough.
    Nige,
    BMW K1200S (for sale)
    Range Rover Vogue
    Suzuki GSX-R600 Racebike (for sale)
    Honda ST1100 Pan European
    Nige, Aug 22, 2009
