Paging those good with rounded bolts - advice needed.
Discussion in 'UK Motorcycles' started by eatmorepies, Mar 24, 2011.
  1. eatmorepies
    Gyp Guest
    I can see why it wouldn't work... on resessed allens. I'm thinking of
    the little fuckers that hold my forks together
    Gyp, Mar 24, 2011
  2. eatmorepies
    zymurgy Guest
    Bloody hell, hasn't everyone got a set of these, call yourselves tool
    porn stars ?
    Bloody amateurs .. ;)
    Paul.
    zymurgy, Mar 24, 2011
  3. Convince me otherwise by all means but I can't see it. If the threads
    were stuck enough that head was going to come off why would what seems to
    be little more than an auto adjusting hex mole grip make any difference?
    steve auvache, Mar 24, 2011
  4. eatmorepies
    I don't need to convince anybody as to how they remove seized fasteners
    but there are very good reasons why you don't keep forcing something
    until it finally moves.
    Andy Bonwick, Mar 24, 2011
  5. eatmorepies
    Malc Guest
    Dunno, they've been around for about 15 years, RS components sell them,
    or something very similar, and they call them Metrinch
    Malc, Mar 24, 2011
  6. eatmorepies
    Adrian Guest
    AFAICT, they aren't "forcing until it finally moves", merely compensating
    for the fact that there ain't no corners on the bolt head any more, since
    it appears to have been made from furry brown cheese.
    Or, at least, that's what I'm using 'em for.
    Adrian, Mar 24, 2011
  7. eatmorepies
    Adrian Guest
    Sneaky little word, that "recessed".
    Hmm. External version. That's an interesting thought.
  8. eatmorepies
    Adrian Guest
    Nah, they're the flank-drive ones that Hog mentioned.
  9. Yebbut one definition of "it finally moves" is getting it undone. If it
    achieves that then what is wrong with it?
  10. eatmorepies
    zymurgy Guest
    TBQH, if it doesn't move after a sharp tap, i'll attack it with plus
    gas, a shock to the bolt head or a bit of heat.
    Turning a seized fastener slowly isn't a good idea [1]. Heating it
    until it anneals it isn't either.
    Paul.
    [1] that's a good recipe for shearing it off
  11. eatmorepies
    Ian Field Guest
    The cheapo way of getting your 7/16 socket on is to grind the end of the
    socket as flat as you can on the face of a grinding wheel - take out the
    bevel on the entrance to the socket so you effectively have a cutting edge
    at the entrance to the socket, a 12 corner socket will go on easier but will
    just strip again if the bolt is really jammed.
    Ian Field, Mar 24, 2011
  12. eatmorepies
    TMack Guest
    However, it is possible to break one without moving the offending bolt one
    tiny bit. Mined ewe, said bolt also resisted red heat, penetrating oil
    and a foot-long stillson wrench so it was a particularly obstinate example
    (in the end I had to cut the fucker off and drill/helicoil).
    TMack, Mar 25, 2011
  13. eatmorepies
    crn Guest
    True, but very often the head has been mashed by previous fuckwittery
    and the ability to get a grip and apply suitable persuasion with
    rattle gun will be enough.
    If the correct tools had been used in the first instance it would not
    be "stuck", just a bit tight.
    crn, Mar 25, 2011
  14. eatmorepies
    SIRPip Guest
    Tragically not at 12mm, though.
    SIRPip, Mar 25, 2011
  15. eatmorepies
    SIRPip Guest
    Stopping turning it once you've got it going is contra-indicated as
    well. Once it's on its way, keep it going. Stop for a rest and it
    welds itself in place, simultaneously being affected by the heat
    generated so that when you return to it, it snaps like elderly
    liquorice.
  16. We shall see. I have bought a set and will report on their first use,
    whenever that may be.
    <Peruses carcass down side of house>
    In the near future, I suspect.
    The Older Gentleman, Mar 25, 2011
  17. eatmorepies
    TMack Guest
    TMack, Mar 25, 2011
  18. eatmorepies
    TOG@Toil Guest
    Pikey git :)
    When it comes to decent tools to do a specific job and avoid potential
    hours of arse-ache, followed by the inevitable job of taking the
    bastard thing to someone who *does* have the right kit, virtually any
    price is "cheap".
    TOG@Toil, Mar 25, 2011
  19. eatmorepies
    SIRPip Guest
    I don't see how this would help to get a 7/16 socket (11mm) onto a 12mm
    bolt head.
    I take your point if the face of the bolt is rounded but there's useful
    hex below it, or, as is the case with a lot of filtery type bolts, the
    hex is really shallow - the chromed variety springs to mind, where the
    vertical hex face is 1.5 - 2.0mm high, but the bolt head looks good, as
    it is slightly domed. Nice to look at, a right bugger to unseize
    unless you use a flat-faced socket such as you describe.
    As far as the OP goes, I'd go along with a previous suggestion and get
    the thing accessible first. Lie it on its side on a mattress, old tyre
    or something that'll prevent damage. Clean the target area off and get
    to know your enemy - there might be some useful hex hidden under the
    crud. Use a Flank Drive(TM) or surface drive socket that'll drive on
    the flats, ground off flat as IF describes, for maximum purchase.
    Unless you can get the thing inverted, I wouldn't bother with
    penetrating fluids, as that would just lube the bolt head and wouldn't
    get into the threads - heat, similarly, is pretty useless in this sort
    of situation.
    If all else fails (like grinding a screwdriver slot and impact driving
    or hex-shank screwdrivering it), a small sharp cold chisel: make a vee
    in a flat, then raise a (thickasyoucan) curl of bolt steel. Swap to a
    less sharp chisel (you don't want to cut the curl off) and tap - in the
    unscrewing direction (obviously) with the chisel aligned to the circle
    of rotation within the hex. That /always/ works.
  20. eatmorepies
    Hammering in an over-sized Torx bit often works with rounded out
    allens. In fact I can't think of a time when that hasn't worked for me,
    most recently last weekend.
    Krusty, Mar 25, 2011
