Paging those good with rounded bolts - advice needed.
Discussion in 'UK Motorcycles' started by eatmorepies, Mar 24, 2011.
  1. eatmorepies
    First thing I always try if the head's not completely rounded is
    grinding paste. Slap some on the head & use a 6-sided socket.
    Krusty, Mar 25, 2011
    #41
  2. eatmorepies
    Work of the devil, those barstewards
    Hog, Mar 25, 2011
    #42
  3. eatmorepies
    Yeah following up on you and Andy, if it is going to come out, rather than
    shear, then a soaking in release fluid followed by a tap with a cold chisel
    should do it.
    If it doesn't move then get radical on it's arse rather than shear off the
    head. It's never that much trouble to centre punch the head and drill out
    the core, which often lets the thread release, then tap it again.
    Hog, Mar 25, 2011
    #43
  4. eatmorepies
    Pete Fisher Guest
    Works well on a sump plug with a large hex and reasonable access.
    Possibly trickier when the head is sunk in to finning as in this case.
    I had to get one of the notoriously nasty OEM Morini plugs out by the
    method once, but enough access was gained by simply leaning the bike
    against the garage wall suitably padded and at a radical angle.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 25, 2011
    #44
  5. eatmorepies
    Beav Guest
    I'd have thought that by now, everyone who fettled had a set of wither
    Draper/Snap-On or Irwin sockets. They're better than the dog's bollocks.
    Beav, Mar 25, 2011
    #45
  6. eatmorepies
    Beav Guest
    I agree, but.... if something *has* to come off and you've tried a raft of
    other tools, the Irwin's are simply another (very good) option to choose.
    The fact that they're good enough to grip so well that sufficient force
    applied by the breaker bar/ratchet/impact driver could snap a bolt isn't the
    fault of the tool, it's the fault of the tool using the tool.
    And as everyone knows, it's a poor workman who blames his tools.
    Beav, Mar 25, 2011
    #46
  7. eatmorepies
    Beav Guest
    On the follow up thread I wrote exactly the same, but then I thought I'd
    have a look at this original thread on the subject. No point saying it
    twice, although i doea stand the odd repeat.
    Beav, Mar 25, 2011
    #47
  8. eatmorepies
    Beav Guest
    Nope. Allen bolts have parallel sides and any taper to the tool would force
    them out of the bolt head.
    Beav, Mar 25, 2011
    #48
  9. eatmorepies
    TOG@Toil Guest
    Probably several degrees further than you've ever managed on the
    road....
    TOG@Toil, Mar 25, 2011
    #49
  10. eatmorepies
    SIRPip Guest
    Pfft. Even adding the postage, that set works out at about 13 dorra a
    piece, or something less than a tenner. Cheaper than Snap-On sockets,
    that is.
    I remember wincing when buying a Sykes Pickavant set of oil drain plug
    extractors inna tin box. Odd things, milled from 17mm hex stock (so
    you can get a 17mm deep socket or choice of spanner on the middle of
    the body) with a variety of square, hex and just odd pegs and sockets
    on the end. It was a six-piece set, each one double-ended and it cost
    about 20 quid in <guesses> 1980. Expensive at the time, but it is
    still intact, I've used most of the ends at some time, frequently for
    other than oil drain plugs and they've never failed.
    So: 12 items, guaranteed to be effective, for let's say two pounds
    each. Divide that by 30 (years) and then by 100 (uses, total) and all
    of a sudden they've cost me less than a gnat's cock for each use, and
    they've got me out of pretty desperate trouble several times. That's
    alternately cheap ... and priceless.
    SIRPip, Mar 25, 2011
    #50
  11. eatmorepies
    SIRPip Guest
    ***DING***
    There's the agony of failure, the agony of embarrassment and begging
    somebody to fix up your fuckup, the agony of waiting for it to be done,
    then the agony of paying for it.
    Might as well pay thirty quid for the tool in the first place, do the
    job - then be delighted when it works a second time. 30 years later
    and fifty uses gone by and you're so far into profit you might as well
    buy a round.
    Pullers, good circlip pliers and long-reach spline bits come to mind,
    as did the oil drain plug adaptors I mentioned in my other post. All
    bottom drawer stuff, all ready to spring into action when the going
    gets tougher than normal.
    #51
  12. eatmorepies
    SIRPip Guest
    "Double-bent cold chisel". Really - they're designed for raking mortar
    out of brickwork joints while leaving space for fingers to grip 'em.
    Of leaning bikes: I recall doing a wiggly job under a bike by digging a
    hole on the grass and letting the sidestand sink in by three or four
    inches. Well dodgy ;-)
    #52
  13. eatmorepies
    SIRPip Guest
    <indicates saucer of milk>
    #53
  14. eatmorepies
    Agree with the first two, but I've no idea what a spline bit is,
    long-reach or otherwise. As it appears I've never needed one, they
    can't be that important. Which of course guarantees I'll need one this
    weekend, although I won't know that's what I need, cos like I said, I
    don't know what they are.
    #54
  15. eatmorepies
    Beav Guest
    If it's what I suspect it is, it's a tool with splines at one end exactly
    like there is on the end of a shaft drive's shaft and a pocket for a 1/2 or
    3/8 T-bar or ratshit on the other.
    Long reach for jobs like removing cylinder heads from Mk 1 Golf's (and
    various other motors) where the bolts are inaccessible with a normal
    spline-drive.. A godsend as they defy attempts to rip them to shreds. I've
    got one in my box from the early 70's and it's called on regularly. Worth
    every penny of the horrendous sum it cost me, even though I can't remember
    what that sum was. I do remember thinking "**** me, expensive" though.
    You do now.
    Beav, Mar 25, 2011
    #55
  16. eatmorepies
    Isn't that a torx?
    #56
  17. eatmorepies
    Can't be - Beav said it was expensive and everyone knows that torx
    cheap.
    CT, Mar 25, 2011
    #57
  18. eatmorepies
    Simon Wilson Guest
    <groan>
    Simon Wilson, Mar 25, 2011
    #58
  19. eatmorepies
    Ian Field Guest
    That might still be neccessary to get a good enough swing at it with the
    hammer.
    Ian Field, Mar 25, 2011
    #59
  20. Ding.
    First one I bought was for umm... head bolts on a Pinto and that saw
    regular use for a couple of years. I now have a complete set of them (by
    Draper or somesuch, iirc) but that original one is Snap-On and paid for
    itself many times over.
    Grimly Curmudgeon, Mar 25, 2011
    #60
