Paging those who have melted throwovers on silencers
Discussion in 'UK Motorcycles' started by Pete Fisher, Mar 23, 2011.
  1. Pete Fisher
    Pete Fisher Guest
    I test fitted my trusty Oxford Lifetime throwovers on the Shiver today
    as my inner pikey won't sanction expenditure on snazzy new luggage when
    the cash could buy a Puig screen. With some soft mesh stuff to stop
    scuffing the small side panels they rest on I think they will work.
    Though perhaps a piece of aluminised mat glued on the back on the areas
    closest to the Akros might be advisable. They only have to get to Pahnd
    Island and back, I'll be using just a tank bag and my tail pack (which
    I've already checked will work) for the French run.
    The good news is that the old Baglux bag works OK on the new tank
    protector. The bars get a bit proximate to the side pouches on full lock
    but can still get the ignition key in and out with it in place. I can
    even see the speedo with the bag extended to its full height.
    http://flic.kr/p/9sFKTJ
    http://flic.kr/p/9sFL2f
    | Pete Fisher at Home: |
  2. Pete Fisher
    Looks fine when empty, but are those plasic bits above the cans going
    to bend down when they've got some weight in?
    Krusty, Mar 23, 2011
  3. Pete Fisher
    ginge Guest
    Not a chance, once filled they'll touch and it'll be burnt underpants
    on the M6.
    What I did with the Zx10r was to bodge a metal frame that I sit on top
    of the pillion seat which holds the panniers a few inches clear of the
    exhausts and about 4 inches higher. With your bike I'd be tempted jut
    to run the pannier straps over the top of the tailpack, mounting the
    whole lot high, then tie it all down to the pillion grab handles with
    a rachet strap instead.
    ginge, Mar 23, 2011
  4. Pete Fisher
    TOG@Toil Guest
    That's a neat idea. A couple of bits of wood nailed together would do
    the trick.
    I speak as a founder-member, along with Champ, of the ISMTPA[1] club.
    [1] I Set My Throwover Panniers Ablaze
    TOG@Toil, Mar 23, 2011
  5. Pete Fisher
    Jim Guest
    That must be quite spectacular at 165mph!
    Jim, Mar 23, 2011
  6. To be fair, you don't have much luck with motorcycle luggage in
    general.....
    Brownz (via Gurgle Gruppez), Mar 23, 2011
  7. Pete Fisher
    Pete Fisher Guest
    Hmm. good point, they do look a bit flimsy.
  8. Pete Fisher
    TOG@Toil Guest
    What intrigues me is that you actually *kept* them. I don't know
    anyone else who's ever amassed a collection of half-throwovers.
  9. Pete Fisher
    Jim Guest
    If he knew someone with a collection of cable ties he could probably
    assemble some kind of frankenluggage.
    Jim, Mar 23, 2011
  10. Pete Fisher
    TOG@Toil Guest
    <Shuffles feet in embarrassment>
    How many would you like, Champ, and what length?
  11. Pete Fisher
    Eh? You'd throw away perfectly serviceable kit just because you
    couldn't actually make any use of it?
    Wierdo.
    I even tend to hold on to things like broken mirror assemblies if the
    glass is OK, just 'in case'.
    Ace, Mar 23, 2011
  12. Pete Fisher
    TOG@Toil Guest
    Yes, so you keep one damaged set, but *four*?
    I carted the remnants of it to the council tip the other day. I could
    see pain in her eyes
  13. Pete Fisher
    zymurgy Guest
    anyone else who's ever amassed a collection of half-throwovers.[/QUOTE]
    <Raises hand>
    Well, I have one surviving half.
    What galled me more was losing bottles of Belgian beer through the
    hole in the bottom, and most of the rest exploding in situ with the
    heat of the silencer :-(
    I'm sure I posted up a pic at the time !
    Can I have my ISMTPA # now ?
    Paul.
    zymurgy, Mar 23, 2011
  14. Pete Fisher
    Buzby Guest
    Making 'progress' up the M20 at night. Apparently looked like I'd been
    shot down.
    Buzby, Mar 24, 2011
  15. Pete Fisher
    SIRPip Guest
    <jumps up, waving hand in air>
    Ooh! Ooh! If you're givin' 'em away, I've got a good home here for
    'em! Working on the National Collection, I am.
    SIRPip, Mar 24, 2011
  16. Pete Fisher
    TOG@Toil Guest
    I've got some bright yellow ones....?
    TOG@Toil, Mar 24, 2011
  17. Pete Fisher
    SIRPip Guest
    <groaaan>
    SIRPip, Mar 25, 2011
  18. Pete Fisher
    zymurgy Guest
    I solved the problem on the Tiger by buying the Givi pannier bars
    (which were eye-wateringly expensive, BTW)
    They're less intrusive than a wingrack (being as they're bits of bent
    pipe) but they do hold soft panniers well clear of anything spinning
    around at high speed or hot.
    Paul.
    zymurgy, Mar 25, 2011
  19. Pete Fisher
    Pete Fisher Guest
    In communiqué
    Hmm, I see they do one for the Shiver or about £45, but it needs
    modifying if Akros are fitted. Might save a lot of faffing about though.
    http://www.apriliaforum.com/forums/showthread.php?t=221497
    Pete Fisher, Mar 25, 2011
  20. Pete Fisher
    zymurgy Guest
    Mine were the thick end of £180 IIRC, but the problem was that Givi
    had discontinued the line for my model, so I had to get them imported
    from a Triumph dealer in the US (one of only 3 Givi pannier kits left
    in the western world apparently ;-)
    Paul.
