Paging TOG (or anyone else into Honda based four stroke single lumps)
Discussion in 'UK Motorcycles' started by JackH, Oct 31, 2008.
  1. JackH
    JackH Guest
    The Sach Madass, formerly of one Rope of this parish has a 125 'X-Sport'
    lump in it - I believe they're a Honda copy.
    Bearing in mind the offspring of said parishoner managed to blow up at least
    two of the 50cc versions, would tuning this be a 'bad thing', and if not,
    any idea as to what can be had out of them in terms of BHP / top end?
    I've found a place that specialises in these locally that just happen to
    have most of the bits to fix the bike up at sensible prices, (including a
    set of forks which looked like it was going to be an expensive PITA), so I'm
    happy to throw some time at it. :)
    ObPugMoped: I might streetfighter this - the boy hasn't turned his nose up
    at the idea, and it'll be a lot less hassle.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    03 VW Passat TDI Sport
    89 Vauxhall Nova 1.3 Pearl
    JackH, Oct 31, 2008
  2. If it's a Honda copy, why not source a Honda engine? For a start, tuning
    it would be a safer bet, and for another thing, parts will be easier to
    source.
    I know for a fact that the old SOHC Honda 125 engine could be taken out
    to 180cc: 150cc big bore kits crop up from time to time.
    There are three main versions of the OHC Honda 125. There's the original
    basic version, put in the CB125S, SL125, XL125 etc. Five-speed, about
    10-11bhp, rev counter redlined at 9500, top whack at the redline about
    65mph.
    They tweaked the engine for the CB125J (also, confusingly, called the
    CB125S and badged as such on the side panels). The redline on that went
    up to 10,000rpm. Bigger valves. Maybe a slightly different cam. Anyway,
    that was good for 70mph. Claimed BHP was 14.
    Then there was the final version: the CB125RS (which I've just bought).
    I don't know what (if anything) they did to the engine, because it was
    even peppier than the J and was redlined at 10,500rpm. Of course, the
    12bhp limit was in force by then, and they declared it only made 12bhp,
    but the one I tested would hit 75mph, so I suspect Honda measured its
    power at the back wheel instead of the crank, or the filler cap, or
    wherever.
    The RS had a completely different carb: a whizzy thing with an
    accelerator pump, so it's probable this is where the extra poke came
    from.
    Anyway, if I wanted the extra whizz, it would have to be the RS, but the
    engine's useless without the pokier carb (Dave Silver still lists the
    carb brand new for £69+VAT). Or you could experiment with whatever other
    carb comes along.
    The alternative is to source an engine from the XL185 dirt bike and drop
    that in: I *think* it's just a hogged out 125 lump. Certainly, it looks
    identical. Very rare, though, and it'll be hard to find a good'un.
    The Older Gentleman, Oct 31, 2008
  3. JackH
    The engine in the Sachs Madass is a development of the C90 engine, not
    the upright 125s
    Lozzo
    SV650S K5, CBR600F-W, SR250 SpazzTrakka, SR250 Project SpazzCaffer
    Ford Maverick 2.7 litre 4x4 Turbonutterbastard with VTOL.
    and a shit load more 2-wheeled junk in the garage
    I believe in free speech, but I still have to pay my phone bill
    Lozzo, Oct 31, 2008
  4. Is it? Oh, OK, you're quite right, then.
  5. So I've just been informed.
  6. JackH
    JackH Guest
    Silly question, but does it have a manual clutch or is it like a Cub in that
    respect as well?
    I've done little with it bar park it up since I got it back.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Oct 31, 2008
  7. JackH
    Cane Guest
    AAAARRRGGGHHH!!!!!
    Cane, Nov 1, 2008
  8. JackH
    JackH Guest
    Like I said, he has to get a job to pay for the running costs before he can
    have it on the road, so given he's done nothing about that as of yet, I'm
    doing little about the Pug bar accrue all the parts needed to get it up and
    running. :)
    Speaking of which, don't suppose you've found the other side pod for the
    fairing yet have you?
    And... don't suppose you know the whereabouts of the Madass battery cover /
    airbox?
    TIA
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 1, 2008
  9. JackH
    JackH Guest
    Should be a hoot to ride round town once finished, and means I can hopefully
    leave the VFR parked up once the roads get salty.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 1, 2008
  10. JackH
    JackH Guest
    Ta muchly. :)
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 2, 2008
