Paging TOG: Triumph battery question
Discussion in 'Classic Motorcycles' started by Andy Clews, Sep 18, 2004.
  1. Andy Clews
    Andy Clews Guest
    TOG, my Trident 900's battery - about five years old - seems to be giving
    out. Even after being kept charged on an Optimate it feels as if it's
    about to run out of steam if the engine doesn't fire within a few seconds
    (often the case if the bike hasn't been used for a few days). Last winter I
    was forced to use jump leads from my car a few times. I assume your Trophy
    1200 uses the same capacity battery (14Ah). What make and model do you
    use, and are you happy with it?
    Ta.
  2. Funny, that. I was just wondering the same thing about my battery this
    week. It starts feeling weak after a few seconds' cranking.
    It's the OE battery, I know. They're actually quite small, aren't they.
    Like your 900, the 1200 Trophy needs some cranking after a few idle
    days. It seems to start easier if you turn the fuel tap to "prime" a
    couple of minutes before you hit the button.
    I think the batteries are just slightly small for the size of engine, so
    if mine's a bit edgy after three years, I'd say yours is knackered. Buy
    the best replacement you can, before winter.
    The Older Gentleman, Sep 18, 2004
  3. Andy Clews
    Andy Clews Guest
    Thus spake The Older Gentleman unto the assembled multitudes:
    Sounds like a classic case of "they all do that, sir" :)
    I'll give that a try, ta. My bike is always garaged leaning on its side
    stand, and I wonder if that makes any difference to the starting fuel
    supply.
    I too have often thought the battery is too small for these bikes. Wish I
    could squeeze a bigger one in. Off to my local dealer's this afternoon,
    then.
    Thanks
  4. Andy Clews
    Preston Kemp Guest
    Given Triumph's history of sprag clutch problems, I'm amazed you stuck
    with the same battery for another year, even if the later sprags are
    stronger!
    It's well overdue for replacement at 5 years anyway, but have you
    checked the electrolyte level, assuming it's a wet battery? My Tig
    battery does tend to run low when using the Optimate, & I've found it
    virtually dry in the past. Topping up then charging revitalises it. I'd
    still replace it asap at that age though - a new sprag requires a major
    engine strip.
    Preston Kemp, Sep 18, 2004
  5. It's not so much that as the length of the fuel lines. I think that when
    you shut off you get a certain amount of evaporation in the lines. But
    then there should still be plenty in the float bowls to start the thing.
    My dealer says they're very sensitive to choke, and he's right. I
    generally start cranking mine on zero choke and just ease the choke
    slightly open as I'm doing so. Full choke, in anything other than
    winter, it doesn't like at all.
  6. It doesn't actually - but it *does* require the engine to come out of
    the frame, although I think from 1998 or thereabouts on it is slightly
    easier.
  7. Andy Clews
    Andy Clews Guest
    Thus spake Preston Kemp unto the assembled multitudes:
    I am already something of a sprag clutch veteran. My Trident broke its
    sprag clutch in March 1998, about 18 months after I bought it (at 3yrs old
    with 7K miles on the clock). After an assertive exchange of letters with
    Triumph (me citing the low mileage as being a bit suss, them implying my
    maintenance wasn't up to scratch and refusing to admit the sprag clutch was
    a weak design - QED), they agreed to pay for the replacement parts, but I
    still had to fork out 480 quid labour and VAT. The work involved
    machining the engine cases to fit a new design sprag clutch. But then,
    bugger me if it didn't break again just over a year later. After a fair
    bit of arm-twisting with the help of another Triumph dealer, Triumph again
    contributed to the cost, but again I paid 290 quid. So I've spent not far
    short of 800 quid on sprag clutch problems. That was in 1999, and so far
    (touch wood) the new starter clutch has been fine.
    Admittedly when I checked the leccy levels this morning they were on or
    below the LOW line in all cells, and in fact half an inch below on two of
    them, but still plenty of liquid in there. And even when I've topped it up
    in the past it doesn't seem to have made a big difference. Anyways, have
    just ordered a new battery from John Harris of Crowborough. Blimey, 60
    quid for a battery; they've gone up a bit, but I did ask for the best.
    For what it's worth, the outgoing battery is a Yuasa. The OE battery was
    (is - still in my garage :) a Yokohama.
  8. Andy Clews
    Andy Clews Guest
    I agree. My Trident is pretty much the same. In summer I can usually
    start it without the choke an then ease in a bit of choke to let it idle
    for a minute or two, but it can be a right bugger in winter or after a week
    or two idle (that's when the jump leads come in handy). And yet sometimes
    it's start almost as soon as you touch the button.
  9. Ouch. I know that the sprag clutch failure is/was linked to dodgy
    batteries - battery struggles to turn engine over, engine kicks back,
    sprag clutch fails....
  10. Andy Clews
    Andy Clews Guest
    Thus spake my good self unto the assembled multitudes:
    I should add that this was when the battery was also replaced. I just
    wanted to make sure the battery wasn't going to be to blame if the sprag
    clutch broke a third time :)
    I guess one can tend to forget about battery life. My previous car (Astra)
    had the OE battery for its entire life (12 years) and it was still going
    strong when the car was nicked for the second and last time.
  11. Andy Clews
    Preston Kemp Guest
    Lol I had *exactly* the same with my Tiger - out of warranty, the
    denials, the letters, the eventual agreement to cover the cost of
    parts. They initially said I must've been using the wrong oil - til I
    faxed them the service records proving it had been main dealer serviced
    from new. I knew for a fact the original smaller sprags weren't up to
    the job thanks to some info from someone I know who was a Triumph test
    rider in the early years.
    I'm very glad to say this didn't happen in my case - it's still going
    strong. In fact yours is the first case I've heard of the larger sprag
    failing.
    Ouch. You can, as TOG inferred replace the sprag by going in through
    the bottom rather than taking the barrels off first, but that's not the
    Triumph recommended way of doing it, so a main dealer may take a bit of
    convincing.
    Jeez, that does sound steep. I got a hulking great Bosche battery for
    my Jeep for 60 quid recently.
    http://www.tayna.co.uk/category/7/Motorcycle-Batteries.html do a few
    Varta 14Ah for around 26 quid with acid pack...
  12. My 1997 Duke is still on the OE battery. I think it's bigger than the
    Triumph one, too.
  13. Andy Clews
    Andy Clews Guest
    That's about the size of it. The clutch didn't fail immediately though.
    You'd hear a loud metallic CLONK which was presumably a kick-back biting the
    sprag clutch's bum, and this happened on several occasions, progressively
    getting worse until the engine would hardly turn over. The first time it
    happened I didn't even know what it was, and the dealer gave the bad news.
    The second time the sound was all too familiar and the sprag clutch gave up
    much sooner (as nearly did I with Triumphs).
    It has kicked back quite a few times since, but no sprag clutch problems,
    just a loud fart (and I don't think that was me).
  14. Andy Clews
    Andy Clews Guest
    Crikey, I reckon they must have had a pile of pro forma letters for all the
    disgruntled owners with sprag clutch problems. They mentioned inadequate
    lubrication to me too. I too sent them copies of servicing records, which
    presumably helped change their mind.
    I think the second failure may have had something to do with the
    incompetence of the mechanics at Moto Velo of Bolney. The reason I had to
    use another dealer second time around (Alf's of Worthing) was because Moto
    Velo had lost their Triumph dealership. In fact not long after that they
    went out of business. I might still have been using the first replacement
    sprag clutch (and 280 quid better off) if Alf's (who are pretty good but
    expensive) had done it in the first place. Ho hum.
    Bike batteries -> lower volume production -> higher prices? Might also be
    due to Crowborough being in the heart of affluent East Sussex (and no I
    don't live there :)
    Must admit I can't recall what I paid for my Yuasa (also from John Harris)
    in 1999, but it was nowhere near 60 quid. I didn't record it, which is
    annoying 'cos <anorak> I normally record every penny I spend on car and
    Free acid thrown in, eh? Oh, *that* type of acid.... :)
  15. Andy Clews
    Andy Clews Guest
    I had a Guzzi V75 (eugh...spit...) which had a bigger battery too, but it
    still couldn't spin the motor.
  16. yet the SOBoxer, and R60, despite as standard having a battery about the
    size of that for a Ford escort, will in fact start from a 12AH tiddler. much
    to my amazement. The starter on the BM looks about big enough for an
    Escort, too.
    Austin Shackles, Sep 18, 2004
  17. Andy Clews
    One of my Saab 900s had its battery replaced at 15 years old. I assume
    the battery was OE as it was not a type I'd seen before and the
    predominant language was Swedish.
    sweller, Sep 19, 2004
  18. Varta?
    bloody good batteries, them.
    Austin Shackles, Sep 19, 2004
  19. Andy Clews
    Wasn't them - TBH I can't remember who it was except it /looked/ OE IYSWIM
    I concur.
  20. Andy Clews
    Tim Guest
    Funny you should say that. The Daytona battery has just had a sulk. I
    wonder whether we can get a bulk discount?
    Tim two#21, YGL#3 & BOTAFOT#84
    Due to the limitations of current email, the lip movements may be
    out of synchronisation as you move your finger under the text while reading.
    tim dot ukrm2 at dsl dot pipex dot com
    Tim, Sep 19, 2004
