Paging TOG
Discussion in 'UK Motorcycles' started by platypus, Sep 19, 2005.
  1. platypus
    I think we can agree to differ on this.
    I've always liked CXes. Might make more sense than a GL1000...
    platypus, Sep 23, 2005
  2. platypus
    I just shrugged my shoulders and repaired the damage. No need for
    hysterics.
    sweller, Sep 23, 2005
  3. This is all true.
    Now that makes me think maybe yours had a damaged sidestand or
    something, 'cos mine doesn't.
    Again,. no probs here - but my legs are a bit longer than the monotreme
    paddles.
    Agreed. For something cobbled together as an afterthought, it's rather
    well done.
    <G> Indeed. It's one of the thirstiest bikes I've ever owned, and as you
    say, the moment it goes onto reserve the engine sounds like it's about
    to explode.
    Yup. It's easy to service, but getting at the various bits means
    removing a dozen other components. You even have to take off the carbs
    to change the bloody air filter.
    The Older Gentleman, Sep 23, 2005
  4. platypus
    Probably no more than the BMW, but the high CofG made it more of an issue.
    By contrast, I could put the BMW onto the mainstand without getting entirely
    out of the saddle.
    More than once, it had me at the side of the road.
    You had to swap out the entire airbox, but to be fair, it was only every
    40K.
  5. platypus
    Eddie Guest
    I know, Mr "Jammier than a case of Bonne Maman's finest strawberry".
    You can go right off some people.
    Eddie, Sep 23, 2005
  6. platypus
    Eddie Guest
    Eddie, Sep 23, 2005
  7. platypus
    TOG Guest
    platypus wrote:
    Um, I was quoted 26k (miles). I suspect you're thinking in kilometres.
    Bloody silly: the entire airbox/air filter assembly is a single unit.
    Whose bright idea was that?
    As for CXs, I owned a B for a while. More comfy than the Eurospurt. I
    still think it was one of the most advanced designs Honda ever produced
    - incredibly far ahead of its time, if you consider the engine. Worst
    thing about it was the weight. IIRC, a Guzzi V50 (same spec apart from
    air-cooling - 500cc transverse shaft drive vee twin) was 50kg lighter.
    I've always wondered why Honda have never produced an updated version.
    The mid-sized transverse vee-twin shaft drive layout is so right, but
    instead all they've produced is in-line vees with shaft drive, and not
    particularly good ones at that.
    TOG, Sep 23, 2005
  8. Heh. Still a great pic.
  9. platypus
    <throws toys out of pram>
  10. platypus
    Salad Dodger Guest
    You settled on the iR1, then?
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..78875.../...19731.../..31242.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR 2005: Abandoned - Bronze Award.
    Salad Dodger, Sep 23, 2005
  11. platypus
    I'm thinking of joining the CMA.
  12. platypus
    Possibly. Yeh, mine was coming up on 40k and had already had it done once.
    A bit like an oil filter, then.
    Every 26K? That's not the most extreme of hardships, really, and if you
    were doing a service and had the seat, rear rack, sidepanels, tank etc off
    already, it's only another ten or so minutes bodging.
    I always liked the Deluxe.
    platypus, Sep 24, 2005
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    You could, you know.
    A probably pretty cheaply.
    Which unbolts with surprising ease. And I'll Ebay it, or you can.
    Can't do much about its being Yellow, mind.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Sep 26, 2005
  14. platypus
    <panic>
    But it's a heap of shit, isn't it?
    Oh, that's okay, I've got a rattle can of satin black hammerite.
    <thinks>
    <panic x 4>
    platypus, Sep 27, 2005
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Yes, so...
    ....there y'go!
    <fx: Big Honest Smile>
    Wicked Uncle Nigel, Sep 27, 2005
  16. platypus
    Does it, like, actually run?
    <throws away key of bargepole cupboard>
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Actually, I really have little clue. It's currently staying at its Uncle
    Petrolcan's place. It has no MOT, but that could be sorted.
    <fx: Wounded Expression>
  18. platypus
    It's probably a non-runner. I could never countenance an unserviceble shed
    like that.
    Pah. You don't fool me, you TOG-a-like.
  19. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Paging Petrolcan! Would Mr Petrolcan care to comment at this point?
    Actually in all seriousness, I probably need to retrieve it and fettle
    it for sale fairly soon.
    ****. Price just went up.
  20. platypus
    Ah. Can't afford it, then.
