Got an interesting issue with my TVDrive which I'm sure is down to how I have the scart leads connected. They're connected like this... [URL]http://www.bensales.com/pictures/connections.jpg[/URL] All scarts are directional as indicated by the arrows and all the leads are fully wired. The problem occurs with the lead going from the TVDrive to the DVDR. This is connected to the VCR out on the TVDrive and is intended for archiving stuff to disc whilst you watch output from the other connection to the tv. When this lead is disconnected, everything works fine. Apart from me not being able to record from the TVDrive. When it's connected, everything still works, apart from when I'm viewing stuff recorded by the TVDrive. The programs play fine, but when you exit the TVDrive function the tv rapidly switches between pictures. I think it's switching between the TVDrive-TV connection and the TVDrive-DVDR-TV connection. Always after 4 switches it settles back to the TVDrive-TV connection that is was on before. Anyone got any ideas as to how it can be wired to avoid this? I have to wire the TVDrive in that way otherwise I have to record from the 'viewing' tuner (in traditional cable/satellite style) and that puts it out of use for anything else.
