Pan European ABS/TCS disaster
Discussion in 'UK Motorcycles' started by M J Carley, Apr 15, 2005.
  1. M J Carley
    M J Carley Guest
    Fowler's in Bristol have just told me that Mr Honda's solution to the
    unidentified problem with the ABS is to start changing parts until it
    works again. This could cost up to two grand. Anyone got thoughts on
    options?
  2. M J Carley
    Simes Guest
    Start off by going to a decent dealer.
    What's the problem now?
    Simes, Apr 15, 2005
  3. M J Carley
    Simes Guest
    If he's having trouble with a Honda he's not got much chance with any
    of the lesser marques has he?
    Simes, Apr 15, 2005
  4. M J Carley
    Stritchy Guest
    Tell Fowlers to stuff it.
    D'ya want a direct e-mail for someone to hassle at Honda UK?
    Stritchy, Apr 15, 2005
  5. M J Carley
    Simes Guest
    Heh...
    I thought that would get you smiling...
    Especially as you know I'm right.
    Simes, Apr 15, 2005
  6. M J Carley
    Simes Guest
    <smug>
    Do they? You've seen mine - still seems to be going alright.
    </smug before fate notices>
    Simes, Apr 15, 2005
  7. M J Carley
    Andy Hewitt Guest
    Sell it to Timo!
    It'll give him a head start ;-)
    Andy Hewitt, Apr 15, 2005
  8. M J Carley
    M J Carley Guest
    The ABS/TCS lights started flashing which means `go to your dealer'
    according to the manual. I did that and it seems the rear sensor is
    playing up but they can't find a problem and the controller is
    refusing to talk to their computer. They spoke to Honda and Honda said
    follow this sequence:
    -change the rear sensor (180 odd quid);
    -change the front sensor (likewise);
    -change the controller (1200 squids).
    Stop when you change something and it works.
  9. M J Carley
    M J Carley Guest
    Oh go on. I normally prefer paper and ink for my vendettas, but
    electric postage might be handy this time.
  10. M J Carley
    M J Carley Guest
    Nobody's mentioned that option and I doubt they ever will.
  11. M J Carley
    M J Carley emerged from their own little world to say
    As you are worrying about the cost I assume you are outside the 2 year
    warranty period.
    I would check all of the connections to the components you list. Follow the
    sensor wires to where they disappear into the main loom. You'll probably
    find a connector. Check the contacts for corrosion.
    Do you know anyone with a Pan? Can you borrow a sensor to plug into the
    circuit to see if the fault disappears?
    wessie, Apr 15, 2005
  12. M J Carley
    Simes Guest
    follow the instructions here and report back:
    http://www.pan-europe.utvinternet.ie/guides/abs-tcs_fault_codes.htm
    Simes, Apr 16, 2005
  13. M J Carley
    Pete M Guest
    In
    It's because Timo's got one that this's happened.
    Pan Euros *used* to be reliable til they suffered "The Timo Effect"
    Pete M
    Mercedes 260E, Porsche 911 Carrera 3.2
    Ford Capri (ressurection started)
    "Never moon a werewolf"
    COSOC #5
    Scouse Git extraordinaire. Liverpool, Great Britain
    Pete M, Apr 16, 2005
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pete M
    We're not allowed to make jokes about The Timonator any more. There's
    been a decree.
    Wicked Uncle Nigel, Apr 16, 2005
  15. M J Carley
    Pete M Guest
    In
    *oops*
    Pete M
    COSOC #5
  16. M J Carley
    Take the bulb out.
    sweller, Apr 16, 2005
  17. M J Carley
    M J Carley Guest
    I was thinking that but I want to make sure that the ABS is genuinely
    disabled. I don't want it starting up when I don't want it.
    M J Carley, Apr 16, 2005
  18. M J Carley
    Andy Hewitt Guest
    Well put it in the FFAQ then!
    Andy Hewitt, Apr 16, 2005
  19. M J Carley
    Bear emerged from their own little world to say
    Not something to concern a Pan rider but if you took a R-GS off road, and
    many do, you would want to turn off the ABS for the same reasons as driving
    in snow.
    wessie, Apr 16, 2005
  20. M J Carley
    Pete M Guest
    In
    Stoppies?
    Pete M
    COSOC #5
