Pan European; short notes
Discussion in 'UK Motorcycles' started by deadmail, Nov 12, 2007.
  1. deadmail
    Greybeard Guest
    Nope, sorry.
    The VFR _seems_ to like a drink when fully laden. When solo, he nips along
    very nicely, the bike seems to struggle when heavily laden and 2-up.
    Still, I guess it is only a 750 tho'!
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy2!)
    Trumpet Trophy 1200-03
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Nov 12, 2007
  2. deadmail
    Okay. I had an R-reg 1200 Trophy with factory panniers and topbox. It
    could get up to about 130mph, and averaged low 30s mpg. It was reasonably
    comfortable for the rider so long as I kept my head out of the turbulence.
    Not so for the pillion: the airflow would snap her neck round to the
    lock-stops if she got it out of the dead-ahead position. Also, the thing
    was a fucking behemoth, with much weight carried high up. Getting it onto
    the main stand was a test of nerve and sinew; getting it off again,
    sometimes doubly so. Going onto reserve was a full West End production:
    fucking ludicrous.
    The VFR is a J-reg 750 with Gvi-identical panniers and topbox. Capacity is
    probably slightly better than the Trofe. Also, they don't seem to let the
    rain in, something the Trofe did for a hobby. It gets to 130 easily enough,
    and averages low-to-mid 40s mpg. It's comfortable for both rider and
    pillion - daughter prefers it to the Wing and reports "absolutely no
    turbulence." It's light and hand and easy to get on and off the stand and
    wheel around. It's also got about a third of the money tied up in it that I
    had with the Trophy.
    Your mate's VFR sounds a bit fucked. Mine is a model of clarity and
    precision, even two up. Range-wise, I'd expect to manage 120-130 miles
    before reserve in most circumstances. I'd be looking for fuel on the Trophy
    after 100 miles or so, due to the reserve shenanigans. The pillion couldn't
    tolerate a steady speed over 80 for any significant distance anyway.
    platypus, Nov 12, 2007
  3. deadmail
    deadmail Guest
    Tch! I didn't call you a sad **** when you kept checking the lights or
    the cooker or whatever it was.
  4. deadmail
    deadmail Guest
    I don't think so; I've owned five K series bikes (although no RS
    models.)
    The old, non paralever ones are a lot cruder in terms of the steering
    and suspension. Plus the choice of rubber is limiting. The K1100's a
    lot better but has that stupid rubber mounting on the handlebars which
    insulates one from the road somewhat.
  5. deadmail
    deadmail Guest
    Oh, probably. Thanks.
    A full service is on the cards... but I've got the K1100 service to
    finish, the K75 full service to do, the sidecar alignment and valves to
    do, the triumph clutch to sort and.... well you get the picture.
    It's in the queue behind the K1100 and K75.
  6. deadmail
    Yeah but you know what I did to my 1100 and it was *miles* better
    afterwards. That's all I meant.
    Hog, Nov 12, 2007
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    Umm...
    <stares at feet, shuffles>
    I had it for about 7,000 miles and I never looked at the air filter.
    That might be a good place to start.
    Honda GL1000K2 (Fallen apart) Suzuki TS250 "The Africa Single"
    Norton 850 Commando Kawasaki GTR1400
    Wicked Uncle Nigel, Nov 12, 2007
  8. deadmail
    deadmail Guest
    Heh... I'll wait until the family of field mice have left it.
    deadmail, Nov 13, 2007
  9. I must say I hated the rubber mounted bars at first, but I've got used
    to them, once you realise that it will, in fact, get round the corner
    that you can't feel.
    I have to say the odd wheel sizes limit the 1100's tyre choice as well.
    The Older Gentleman, Nov 13, 2007
  10. deadmail
    deadmail Guest
    message
    Oh, I'm used to them but it isn't a good arrangement. If I had time I
    think I'd replace them with metal bushes.
    Could also take a leaf out of the H1 cookbook and fill the handlebars
    with lead to damp the vibration...[1]
    That's true.
    [1] Clearly a joke since the K runs the heated grip wires there.
  11. deadmail
    hey, at least mine was a proper mental illness - you're just a twat.
    darsy, Nov 13, 2007
  12. deadmail
    As I have said before taking the slop out of the bars makes a huge
    difference, in fact that mild weave in corners is mostly caused by your
    negative feedback through the bars. Add some steering damper, perfect head
    races, a proper upgrade to the fork internals and a high quality shock with
    the right tyres.... you have as good a handling big tourer as can be had.
    The 1100RS wheels allow more tyre options, hence I also said that an RS with
    an RT fairing would be the best start.
    Of course an RS with a Boxer RS fairing is even better possibly.
    Hog, Nov 13, 2007
  13. deadmail
    Greybeard Guest
    Standard screen and that's absoluelty correct. I've cahnged all my Trphies
    to the Flic-up screen. Seems to _almost_ solve the problem of turbulance.
    Pillion is certainly much better off, and in the main, unless I sit bolt
    upright, like when stretching my back then I rarely have a problem (I'm a
    bit of a shortarse though;o) )
    It certainly carries weight high, I even have a rack on the lid of the top
    box!
    Can't argue about the centre stand fiasco. It can be a right scarey few
    minutes of wrestling.
    Don't have a problem with reserve, rarely need it, 'specially not if
    travelling with my mate on his VFR. (Which in all fairness has only ever
    been once and probably will stay that way!)
    130 is about the top for the Trumpet, but Christ, who and where would
    anybody want to ride at that speed for any length of time?
    Can't argue about any of that, I'v never even been on a VFR, it's a Honda
    after all, and I don't touch them!
    Can't keep up with a Trophy when loaded though.
    Well, I have to say, it seems in excellent order, and is pretty damned quick
    when solo. Not too much of a slouch when 2-up, but seems not to like being
    loaded to the gills.
    I reckon you must have had something seriously wrong by not getting 130+ out
    of a tank before thinking of reserve, unless of course you are flat out all
    the way, then I would think that pretty bloody good! :eek:) I think a VFR at
    full chat would be bloody thirsty as well.
    Keeping a steady eighty or so on my Trumpet I would expect to get over 140
    miles before reserve. I have had nearly 200 to the tank taking it really
    steady!
    On a similar note, my neighbour, who bought my 1991 Trophy off me a couple
    of years back, and rides _very_ cautiously, is always over the 200/tankfull
    before he fills up, and never hit reserve yet! ;o)
    Horses for courses, but having never ridden a VFR I can't comment on the
    bike itself, but the Trophy is a farking hard bike to beat as full-up fully
    laden long distance tourer.
    And a great bike to just around for fun as well ;o))
    Greybeard
    Greybeard, Nov 13, 2007
  14. deadmail
    snip>
    I don't know if there's a major difference in the handling between the
    K100 and the K1100 but as far as I can tell al, you need to do with
    the older model is throw it at a corner as hard as you can, pucker up
    and get on with it.
    It's a big old unit but all bikes from that era handled like turds
    and without riding it back to back with something like a GPZ1100 it
    doesn't seem to be any worse than I remember bikes as being.
    Mine scared the shit out of me at first but now I'm used to it I don't
    worry about it. Decent tyres would be nice but when you consider that
    Pirelli Phantoms were about as good as it got in 1983 you just have to
    accept that it's old and ignore the problems. I'm positive that my
    K100 handles better than the mid '70s boxer twins that I rode. At
    least I can roll the gas off a bit mid corner without it standing up
    and shaking as if it's got Parkinsons.
    Andy Bonwick, Nov 13, 2007
  15. deadmail
    hog Guest
    The RS doesn't have the rubber mounted tiller like bar problem so it
    doesn't exhibit the same weave in long sweepers. As for the rest,
    horses for.
    hog, Nov 13, 2007
  16. I can do that on the Duke, but I'd prefer not to on the K.
    The K, I set up for the bend nicely in advance, tip it in, and then keep
    the power on all the way round. It seems to go quite nicely round bends
    like that. In fact, I got my boot down yesterday.
    Shutting off in mid-corner? Hm. Haven't tried that. Haven't tried
    snorting prussic acid either.
    The Ducati I like throwing at corners, because I'm certain that whatever
    I do, it'll come out the other side. I like lobbing the K at corners
    because it's a sort of interesting academic experiment.
    It actually corners much better than it should do, given its size,
    weight and soft suspension, but it doesn't handl;e anywhere near as well
    as the Trophy 1200 that preceded it.
  17. deadmail
    snip>
    My 1983 K100 does better than 140 miles to reserve belting up the
    motorway at 110mph and I'm not overly impressed with that when I look
    at it as a long distance touring bike.
  18. deadmail
    [/QUOTE]
    You should try it. I'll probably bring mine on a French trip so try it
    on that, it won't matter if you wreck it because your life insurance
    will replace it.
    It does repay you if you line it up well in advance of the corner but
    changes of line can be accomplished if you're in the shit enough to
    try it.
    Prussic acid? Never tried it but I have snorted vodka and it burnt
    like a bastard.
  19. deadmail
    I had a non-standard screen. It was okay for me, but still problematic for
    the pillion.
    I once got 160 to reserve on my Trophy. However, when it did hit reserve,
    it was chugga chugga choke fart hard shoulder fuel starvation. Which is why
    I'd be getting edgy and looking around for filling stations after 100 miles.
    It was a good bike, but I just didn't get on with it.
    platypus, Nov 13, 2007
  20. deadmail
    platypus says...
    How crap is that, and they call it a full-on tourer? Normal tank range
    on my Daytona is about 155 to 160 miles, and on one occasion I managed
    to drag it out to 225 miles by riding like DWB/Oldbloke/Wizard/Ginge in
    his R6 days.
    Lozzo
    Triumph Daytona 955i SE
    Suzuki SV650 K3
    Honda CBR600 F-W
    Suzuki GSX-R750L
    Yamaha SR250 SpazzTrakka
    Lozzo, Nov 13, 2007
