Checked tyre pressures, all ok. It was pissing it down all day today & the front end has felt just 'not right' Any slight imperfections in the road surface has it tramlining. I havent had chance to have a look at the rear preload etc yet as it aint stopped raining for two days. The front else feels kinda loose & imprecise, nowt knocking or loose. I wonder if the wheels are aligned correctly. The forks feel fine, even under full on braking, tyres quite worn, but nowt silly (metz) I even got to wondering if it's very susceptible to wind, as it's very windy here atm. Maybe i'm used to riding bikes with steering dampers. It's as if the front wheel doesn't want to do what you know it should do. It countersteers fine & drops over amazing for such a barge. It just seems on anything other than perfect flat surfaces it wriggles a bit. I'll have a fiddle with the rear suspension & check the wheel alignment. The front forks can't be tinkered with at all i believe? The large screen is coming off for commuting too, i like to see when i'm slow speed riding, it just gets bshit up with drops of water that won't fuck off at 5mph.
