Panisti please
Discussion in 'UK Motorcycles' started by Nige, Jun 15, 2009.
  1. Nige
    Nige Guest
    Nige, Jun 15, 2009
  2. Nige
    Simon Wilson Guest
    Simon Wilson, Jun 15, 2009
  3. Nige
    Nige Guest
    Are they hard & expensive to sort?
    Nige, Jun 15, 2009
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Nige
    If it's the sensor, a bit over ton from David Silver for a pattern part
    (IIRC) and fairly easy to fit. Getting the old one out can be a slight
    challenge.
    Simes is your man for this kind of thing.
    go and talk to the Catholics.
    Wicked Uncle Nigel, Jun 15, 2009
  5. Nige
    Simon Wilson Guest
    The sensors come up on ebay every now and then, not sure how much a new
    one is. I have a spare you could borrow to try. Mine's currently seized
    in the holder to hard to get out, on a newer bike should be pretty
    straight forward.
    You could also get him to run the diags here:
    http://cain.ulst.ac.uk/st1100/absdiagnostics.htm and see what the ABS
    box reports.....
  6. Nige
    Simon Wilson Guest
    ps, as per the url I posted, battery terminal corrosion/loose is also a
    really common cause of ABS/TCS faults.
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Nige
    Actually, looking again, if the TC's not working and the ABS is, then it
    could be the TC switch that's at fault.
    If it was the sensor, both would be out.
  8. Nige
    Nige Guest
    More than likely fucked connector or cables then.
    Nige, Jun 15, 2009
  9. Nige
    Simes Guest
    Wouldn't worry - as long as the ABS is working it can't be too much wrong
    as they use the same sensors and circuitry apart from the switch...
    Perhaps just wants the switch jiggling a couple of times...
    Simes, Jun 15, 2009
  10. Nige
    Nige Guest
    He sorted the TC by sorting the fuses out.
    I asked him about the aswingarm & he replied it has been repaired. Any idea
    if you can repair them & if they are likely to be any good?
    Nige,
    BMW K1200S
    Range Rover Vogue
    Suzuki GSX-R600 Racebike
    Nige, Jun 15, 2009
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, Nige
    They rot from the inside. They can be welded, if the weld-monkey knows
    what he's doing[1].
    [1] *Waves* to Pip
  12. Nige
    Nige Guest
    Fair to say it's likely fucked then. One has to err on the side of caution.
    Are decent 2nd hand ones available at a right price i wonder...
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Jun 15, 2009
  13. Nige
    Simes Guest
    I wouldn't say that - I would echo Nige - if it's been welded properly it
    will be fine.
    No.
    Simes, Jun 15, 2009
  14. Nige
    Simes Guest
    Nigel WUN is the one I would echo...
    Simes, Jun 15, 2009
  15. Nige
    Nige Guest
    I did wonder...
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Jun 15, 2009
  16. There were too few sweary words in his post to be echoing you ;-)
    Beelzebub_on_Mac, Jun 15, 2009
  17. Nige
    Simon Wilson Guest
    249 or 315 quid from Dave Silver brand new. They come up on ebay now and
    then as well.
  18. Nige
    Simes Guest
    Non-trivial to fit however...
    Simes, Jun 15, 2009
  19. Nige
    Simon Wilson Guest
    Aye. And a special tool to remove and torque up the spindle.
    Simon Wilson, Jun 16, 2009
  20. Nige
    Simes Guest
    A Honda branded hammer and torque-chisel.
    Simes, Jun 16, 2009
