Perth - Scooter Battery
Discussion in 'Australian Motorcycles' started by Bogan, Apr 28, 2005.
  1. Bogan
    Bogan Guest
    Hey,
    does anybody know if a scooter battery is the same as a motorbike battery??
    and where in perth can you buy a scooter battery thanks.
    JD
    Bogan, Apr 28, 2005
  2. Bogan
    GB Guest
    A battery is more or less a battery. Aside from getting the right
    voltage, the biggest issue to deal with is usually getting one that
    fits in the hole and has the terminals in the right spots. With big
    engines, you need to make sure the battery will deliver enough juice
    to turn the engine, but that's not likely to be an issue for you.
    There's some chance your scooter might have a 6V system I suppose.
    Note: Putting a 12V battery in it will NOT make it go twice as
    fast :)
    Best option: Take the existing one out and take it to a bike shop.
    Tell 'em "I want one like this".
    GB
    GB, Apr 28, 2005
  3. But will it charge twice as fast and can you jump start it off the car?
    I'd go the bike shop last and a battery wholesaler first.
    Pisshead Pete, Apr 28, 2005
  4. Bogan
    sharkey Guest
    Can you jumpstart a scooter from a bike?
    Can you jumpstart a bicycle from a scooter?
    -----sharks
    sharkey, Apr 28, 2005
  5. Bogan
    moike Guest
    Depends.
    My first scooter took 4 D-cells.
    Moike
    (Vespa 50, Magneto ignition and lighting, aftermarket D-cell operated
    indicators.)
    moike, Apr 28, 2005
