Petrol pipe blocked - help
Discussion in 'UK Motorcycles' started by Mike Buckley, Dec 17, 2009.
  1. Mike Buckley
    One other thought - if you can stick a small funnel in the hole, drain
    cleaner might do the job. The 2-part foaming gel stuff seems to work
    wonders, but might be too thick, so maybe try the liquid stuff.
    Krusty, Dec 18, 2009
  2. Mike Buckley
    Dave Emerson Guest
    Grease gun didn't work then?
    Dave Emerson, Dec 18, 2009
  3. Mike Buckley
    Mike Buckley Guest
    Don't have one - its on the list to buy though as this bike has about 10
    grease nipples.
    Success on the blockage though - seems me going into the garage every
    couple of hours over the last few days and squirting carb cleaner into
    the hole has cleared it. Pipes and tap now fitted - I was going to fit
    the clutch cover but it's a bit chilly in the garage so I decided to
    watch some cricket :-(
    The reserve pipe routing is a bit weird, the exit from the tank is on
    the opposite side to the tap, so the pipe has to route over the frame
    tube which means that reserve on one side of the tank will be hardly any
    extra fuel.
    Only the clutch cover to fit, fill with oil and set the timing and I'll
    see if it runs.
    Mike Buckley, Dec 18, 2009
  4. Mike Buckley
    Dave Emerson Guest
    Having owned a C72, 2xCB72s and a CB77, I just assumed you'd have a grease
    gun with this bike.
    The pipe runs under the frame tube. It makes it a real bugger if you have
    to remove the tank when it's full - I find a bulldog clip on the end of the
    hose when you pull it off reduces the "petrol shower" effect.
    If you run the pipe over the frame you might as well leave it blocked, as it
    won't work.
    Good luck.
  5. Mike Buckley
    Mike Buckley Guest
    That's interesting, I dug out the old pipe and it went over the tube, so
    I figured that would be the best route especially when I realised you'd
    have to remove the pipe to take the tank off.
    Ta - running over xmas I hope
    Mike Buckley, Dec 19, 2009
  6. Mike Buckley
    Beav Guest
    Mike, it'd be good to see it built back up and looking ready. Any pics up
    anywhere yet?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 20, 2009
  7. Mike Buckley
    Mike Buckley Guest
    Will post some after xmas - it'll be all together even if it isn't
    running. Latest ones are here, but they don't show much progress other
    than the exhausts on:
    http://www.flickr.com/photos/39665805@N05/sets/72157622501687588/
    Will get it out of the garage and take some decent ones weather
    permitting.
    Mike Buckley, Dec 20, 2009
  8. Mike Buckley
    Beav Guest
    Looks pretty good from where I'm sitting.
    It'd look great against a backdrop of snow and cold :)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 22, 2009
