Petrol tap
Discussion in 'Classic Motorcycles' started by Guest, Aug 18, 2003.
  1. Guest
    Guest Guest
    Buggrit! (to quote Terry Pratchett).
    I've just snapped the outlet pipe off the petrol tap on the R80, trying
    to get the LH-threaded nut off the top. Boxers have a strange
    arrangement - RH thread on tank, LH thread on tap, and a weird cadmium
    plated (I think) LH/RH nut to join the two.
    Anyway, it's had it, so the service kit won't be needed now :(
    I bought a new tap for the LHS (couldn't get that one apart to service
    it at all), and the strainer gauze on the new one came with an
    aluminium ring at the bottom - I guess the RH replacement will too.
    So two questions:
    - what should I put on the threads to prevent them gumming up again
    (aly-to-aly for the tap itself and aly to cadmium-plated steel for
    tap-to-tank)?
    - The aluminium ring is news to me. So, should the fibre washer go next
    to the tank or the tap:
    [tank][washer][ring of strainer][tap]
    or
    [tank][ring of strainer][washer][tap]
    I'll evidently get the thing running again just as this good weather
    ends :(
    Regards,
    Simonm.
    Guest, Aug 18, 2003
  2. Guest
    Not that unusual, BMW, Guzzi and MZ use that arrangement (Hmm, I see a
    European theme here)
    Copaslip or loctite (not only does it stop things vibrating loose, it
    helps prevent corrosion)
    IME this is the kiddy
    sweller, Aug 18, 2003
