PGM-FI Malfunction
Discussion in 'Australian Motorcycles' started by Morgan Vening, Feb 5, 2011.
  1. OK, I was riding home, and my FI light on my instrumentation panel lit
    up, and stayed on for the remainder of the trip. Looking through my
    book, it says it indicates a fault in the Programmed Fuel Injection
    system, and says that it should be taken to a Honda dealer as soon as
    possible.
    Exactly how bad is it? I was going to put my bike in for a service
    Wednesday, but have three trips (90km round each) before then I'm
    supposed to do for work. Is it severe enough that I shouldn't ride it
    at all, or should it be OK until then?
    Morgan Vening
  2. OK, I did some snooping, and the 'internets' said that you turn the
    bike on, and it'll flash long and short to indicate what kind of
    error. It makes 8 rapid flashes, pauses, and repeats.
    According to the service manual PDF I appropriated, that indicates
    Causes
    · Loose or poor contact on TP sensor
    - Open or short circuit in TP sensor wire (Simulate using numerica l
    - Faulty TP sensor values
    Symptoms
    · Poor engine response when a connector operating the throttle quickly
    (Simulate using numerical values; Throttle opens 0')
    So again, how bad is this? I really need the work, but if it's going
    to kill the bike, I don't really have much choice.
    Morgan Vening
  3. Morgan Vening
    alx Guest
    TP - throttle position sensor..
    Doubt it's going to cause grief.
    alx, Feb 6, 2011
