photographing bikes
Discussion in 'Australian Motorcycles' started by Daniel M, Sep 23, 2003.
  1. On Sun, 12 Oct 2003 17:22:08 UTC, "Julie and Deb"
    } hmmmm... maybe the thing I'm assuming is the light meter (a red needle in
    } the LHS of the view finder) is actually just a "you haven't wound the film
    } on yet, stupid!" indicator.
    That's what it is. It's more like a tab than a needle, right?
    } And maybe I need to go to remedial camera school..............
    It may be similar to asking a MCSE to explain a ZX81 to you.
    If it's an 1b, the light meter (the indicator part) would be on the
    outside of the camera, to the left of the pentaprism.
    } Julie (confused, but willing to give it a go. I've got a list of
    } 'suggested' f/stops for most light conditions tucked in with the spare film)
    As a rough guideline you set the shutter speed at 1 over the film ASA
    number, so 1/125 for 100 ASA (= 21 DIN) (the film ISO number is just
    these two numbers together for your average film the ASA number is the
    larger of the two), or 1/500 for 400 ASA. Then you set the aperture to
    f/16 or f/22 for bright outside, f/11 for slight overcast, f/8 for
    cloudy. Every doubling or halving of the shutter speed is equal to
    opening (going to a smaller number) or closing the aperture one stop:
    1/500 @ f/8 = 1/250 @ f/11 = 1/125 @ f/16. Fortunately modern films
    have quite a bit of leeway, so your exposure doesn't need to be dead
    on.
    // Rik Steenwinkel '85 R80ST Skippy bike
    // Enschede '91 R100GS/PD The Great Unwashed
    // Netherlands ('76 Honda CB250G Bouwpakketje)
    // "Far away is only far away '90 K75C Kommutabike
    // if you don't go there" '81 MZ TS250/1+LSW Badkuip
    Rik Steenwinkel, Oct 12, 2003
    #41
  2. Daniel M
    RM Guest
    Someone let Rik Steenwinkel at loose on an internet
    connection and the result was:
    specially if using print film...lots of stuff can be corrected in the
    developing process...if using transparency it helps to get it righter than
    wrong
    RM, Oct 12, 2003
    #42
