Ping centrepetal clutch fettlers.
Discussion in 'UK Motorcycles' started by T i m, Jun 8, 2009.
  1. T i m
    T i m Guest
    So, Yamaha Majesty YP250 MOT'd today and after I took it for a little
    shake-down run.
    Something that I thought might go away after a run but didn't was
    quite a bit of drag on the transmission, even at tick over (sufficient
    to make paddling the bike backwards with the engine running quite
    difficult and when on the stand you couldn't stop the wheel spinning
    with yer boot (suggesting it was more that just 'drag')).
    So, I stripped it out this evening and found 2 of the 3 clutch return
    springs missing? What's that all about then? Could they have just
    broken and come out of the housing somehow or has someone taken them
    off to overcome another issue (or just bodged it generally)?
    Cheers, T i m
    T i m, Jun 8, 2009
  2. Performance mod, innit?
    Well-known and mysterious are the ways of the back-street teen tuner.
    Grimly Curmudgeon, Jun 9, 2009
  3. T i m
    T i m Guest
    Ah, indeed, however I'm not sure a 250 Majesty would be seen as a
    street-cred-ped. ;-)
    The PO had the bike quite a while (a few years) but only generally
    used it to get from Herts to Gatwick where he would leave it in the
    car park (free) while he went to his place in Spain / wherever.
    I think he mentioned he'd had the belt changed a few hundred miles
    back but that could have also been a few years. Had it not been road
    tested afterwards the fitter may not have realised the springs were
    missing.
    With hindsight the PO did explain his starting sequence involving
    keeping the bike on the stand after starting for a bit and when it had
    'warmed up' dropping it on the floor, after that it was ok in use [1].
    Daughter rode it home from Clacton (and we hardly stopped) so
    yesterday was the first time I'd had the thing on the road myself to
    see what it was like.
    T i m
    [1] I thought it could just be how_it_was or because it was getting a
    bit tired? Her Piaggio Skipper used to do similar when cold but was ok
    when warmed up.
    T i m, Jun 9, 2009
  4. T i m
    T i m Guest
    Well it certainly seems keen to get away, lift yer feet up on tickover
    and it's off, even two up!
    I bet.
    There is no way they could have just broken and fallen out I guess?
    Right, exhaust is stock (and as I said elsewhere I don't think this
    has been owned by a tweeker). Rollers are ~ 20mm diameter (plus a few
    small flats) and weigh 14g (but I can't find mention of what std ones
    are in the manual). They look identical to a set I've seen on Wemoto.
    It does give me that the 'Clutch – in revolution = 2,100 to 2,700
    r/min and the stall revolution should be 3,700 to 4,700 r/min'. ;-)
    Again, no mention of what 'std' is in the workshop manual. Again, it
    looks untouched (but I appreciate that means little) ;-(
    Phew.
    For me the best combination would be 'working as Yamaha intended' ;-)
    FWIW I have found mention of the free length of the clutch shoe spring
    so at least I can see if the remaining one it stretched much / at all.
    Theoretically I can measure the tension rate on that and then see if I
    can find some from an old clutch or similar?
    I'm going to take the lot over the bike shop now and see what they say
    (and to take the clutch apart).
    I notice they do the complete clutch / drum assy on eBay new for about
    £100 delivered but from China? Are they likely to be as good as the
    original kit (or could the original have come from the same factory in
    98)?
    Cheers, T i m
    T i m, Jun 9, 2009
  5. T i m
    Get new clutch springs, check the clutch drum and that it isn't worn too
    much or warped. Could just have broken off, it'll help the pull away no
    end fixing it. As in, it'll pull away much quicker. :)
    Muck, Jun 9, 2009
  6. T i m
    TMack Guest
    MAJESTY DX 250cc 20x12 14.0g
    MAJESTY ABS 250cc 20x12 11.5g
    SNIP!
    No need to replace the drum unless it is damaged. Shoes and backplate
    assembly is around £60 e.g
    http://www.gileraspares.co.uk/spare...P=CLUTCH&Model=YAMAHA MAJESTY 250 - upto 2001
    TMack, Jun 9, 2009
  7. T i m
    T i m Guest
    Cheers, that fits at least then.
    I guess for damaged read scored when it comes to such things and it
    was a bit. I say was as I've skimmed to high bits off on the lathe
    tonight.
    Cheers again.
    Update. A mate found a new clutch back plate assembly for me (was
    fitted briefly to an X Max but wasn't the problem) but from what I can
    Google it's designed for a 125. Part No: 1B9-E6620-00. It's exactly
    the same as what I took off except the springs look much bigger and
    feel much stronger (it could just be that the one remaining spring on
    my old unit is shagged). My data shows the original clutch as a
    4HC-16620-00. I *think* may have seen mention a substitute part, could
    the 1B9 item be it?
    Anyway, on the grounds that I've little to lose except a bit of time
    I've skimmed all the rollers down to a nominal 19.70 mm dia (min 19.5
    according to the manual. They still have some small flats but
    generally much better) and reassembled the variator and clutch ready
    to fit when I next get a chance.
    Before I do, can you confirm if the 'new' clutch assy is (or isn't)
    suitable for my YP250 and if not what am I likely to find in use?
    Assuming the clutch springs are now stiffer (and the clutch arms the
    same weight as the originals) I guess they will take more revs before
    they start to throw out so would cause the clutch to slip more
    (longer) during takeoff (as it's trying to pull away on a slightly
    higher gearing)? Or am I way out?
    Cheers, T i m
    T i m, Jun 9, 2009
  8. T i m
    T i m Guest
    Trouble is the frictionable material on the two clutch surfaces that
    have been 'dragging' is nearly worn down to the metal so even if I got
    new springs I'd be stuffed there?
    As I've added elsewhere I'm trying a nearly new clutch a mate has
    found for me and if that doesn't work (possible wrong spec) I have the
    old clutch out to either repair (reline, new springs [1]) or replace
    as / when I get the cash / time.
    Cheers, T i m
    [1] Partly for the crack.
    T i m, Jun 9, 2009
  9. T i m
    TMack Guest
    If it fits then it should be fine. You are right about the higher revs
    before the clutch bites but that shouldn't be a problem - the engine will be
    delivering more torque at higher revs so the take-up should be smoother and
    with better initial acceleration. However - if the springs in the clutch
    assembly that you are considering fitting are non-standard (I think they are
    the same standard spec on both 125 and 250) then there are possible
    difficulties. If they are too stiff then you may have to scream the engine
    before the clutch bites.
    BTW - re. the missing springs. The other two may have broken, see
    http://www.twistngo.com/userforum/viewtopic.php?f=6&t=5523&view=next
    Possibly the previous owner couldn't be arsed to replace them and just put
    it back together with one spring.
    TMack, Jun 9, 2009
  10. T i m
    T i m Guest
    Yep, it seems to have done (well together rather than on the bike).
    But might sound a bit 'busy' if just pottering in traffic? It will be
    difficult for me to judge as I'm only used to it as it was, pulling
    away at tickover revs.
    Well the 125 - 250 things is reassuring as my mate *thought* the
    clutch was from a 250 X Max but the only reference I could find to
    that No. was re a 125. If they use the same components and in the same
    role (and I have since found an X Max 125 parts list and it looks
    similar at first glance (but gearing ratios could be different etc))
    then it could be game on. ;-)
    Understood, but I think it's only going to be any difference between a
    YP250 and X Max 125 so ... ?
    Hmm. I wonder if they did redesign it for later machines using the
    same transmission (bigger springs)?
    As mentioned elsewhere the PO only used it as a DIY airport Taxi and
    generally put it into the shop for most work. I'm pretty sure he
    wouldn't have gone as far as taking the tranny cover off!
    I have no idea of the bikes history before that though.
    Another question if I may. When I took the variator apart it was
    fairly well lubed up with a very black sticky grease. There seems to
    be two systems out there, those that are designed to run dry and those
    that are designed to run lubed. After a quick Google I decided to
    re-lube this one upon re-assembly and I used a general purpose high
    melting point lithium based grease. I also use it on the spiral action
    of the rear sheaves etc. Is this ok would you say?
    Cheers, T i m
    T i m, Jun 9, 2009
  11. T i m
    TMack Guest
    If the variator was working OK with greased rollers before you took it apart
    then it should be fine after re-assembly. I hope you only used a thin smear
    beause you really don't want any risk of grease on the pulleys or drive
    belt.
    TMack, Jun 10, 2009
  12. T i m
    T i m Guest
    Swot I though (but just wanted a 2nd opinion).
    I used a bit more than a smear but not OTT as it seems this variator
    is very much designed to run 'wet'. By that I mean there is a large
    'O' ring around the outside of the ally body of the variator itself
    and when you put the steel cover on it effectively seals the assembly
    against any grease [1] from being thrown out by centripetal force.
    It would be like using the spin drying function of a washing machine
    after taking the door off.
    I'm off out and about now but after I've synched up with Paul I hope
    to put it back together later.
    Cheers, T i m
    [1] Ok if grease but oil would spill out if you laid the bike on it's
    l/h/s etc.
    T i m, Jun 10, 2009
  13. T i m
    Heh.. it's an 'on a budget' scooter. Rather like my one has turned into
    [1]. Some spotty yoof nicked the end of my kick start outside uni. So a
    mate welded part of a table leg onto the end of the kick starter. :)It's
    not pretty, but it works. Hurst my foot less when starting the thing too.
    [1] Apart from the last rebuild that included a rather mice long stroke
    crank and new piston / mains / water pump / head.... doh.
    Muck, Jun 14, 2009
  14. T i m
    I miss my old grease filled variator, you didn't need to replace the
    rollers every couple of thousand miles. I may yet find an older greased
    type variator off an old Runner 180 if there is such a thing any more,
    or modify my existing Polini variator.
    Muck, Jun 14, 2009
  15. T i m
    <aside>
    What did he say?
    Krusty, Jun 14, 2009
  16. T i m
    T i m Guest
    It is indeed but one that seems to be performing much better now. ;-)
    I'm not sure if the new clutch is 'right' (as in performing as / when
    it should) but it's certainly not doing the draggy thing and the
    'variomatic' part of the transmission also seems much more apparent.
    ie, When you give it a bit of throttle at standstill the revs now come
    up and you feel the clutch start to bite. Then the revs seem to stay
    the same and the speedo just goes from 0 to about 60 with no real
    obvious change in engine revs. The only bit I'm not sure about is if
    the clutch is now coming in a bit too late, as if the clutch springs
    were too strong? Mind you the only test I've done with it in it's
    latest guise is two up and a farly heavy two at that. ;-(
    It is a bit weird having no direct drive from 0 mph (as with a manual
    bike, clutch / gears etc) and you have to learn a slightly different
    technique for slow speed manoeuvring etc but it does seem an ok scoot.
    I let the Mrs have a go on it along a wide empty road and she got on
    with it straight away (but then she's used to 'different' handling via
    her XV750). She even did a section of the journey home with all 16.25
    st of me on the back. It can be leaned further than her XV750 and even
    two up we haven't grounded anything yet.
    It isn't the same ride as a big wheeled bike and like many 'commuting'
    type machines seems to suffer the 'rubber hinge' issue. I've changed
    the fork oil, checked the head and front wheel bearings and it's got
    new tyres front and back but the front definitely feels a tiny bit
    'drifty' when bundling along in a straight line.
    As something different though I'm quite impressed. I like the electric
    start, a fuel gauge, all the storage, seat comfort [1] and the fact
    that it's a liquid cooled 4/. I should imagine the weather protection
    would be good in the winter. The variomatic bit means it's quite easy
    to frustrate those drivers who thought they would easily get by then
    cut up 'a scooter' (even with my bulk at the helm).
    Why? I mean, are they sought-after or collectable etc?
    Result then. ;-)
    Ah, that's the hook isn't it ... I was looking to replace the variator
    rollers (anyway) and someone sent me a link to Dr-Pulley:
    http://www.unionmaterial.com/rollerweight.htm
    And then it can be a slippery slope towards Malossi, Costa and other
    tuning kit. However, now it seems to be going ok and I've sorted some
    cheap replacement mirrors (with a little lathe work) it's going next
    to the CB Two Fifty [2] ready for when the mood / need arises.
    T i m
    [1] All be it slightly cramped for me at 6' 2" ... but that's the way
    it is on most bikes.
    [2] That really needs one fork leg re-chroming. ;-(
    T i m, Jun 15, 2009
  17. T i m
    T i m Guest
    Oh, as often as that eh? A mechanic mate did mention many clutches
    now seem to be run dry but rather than experiment with this I re-lubed
    it and it seems fine. What are the chances of these rollers being the
    original ones at 24k miles?
    Even with the levels of wear I noticed on the transmission on this
    scoot (pulley sheaves with distinct groves near the outside, flatted
    rollers, scored clutch drum, min spec belt etc etc) it all looked
    sufficiently re-useable, at least till I've worked out if it's a
    keeper or not.
    I should imagine to replace the lot with new Yam stuff would be quite
    expensive (the RRP on just the clutch was £130) but then I guess it is
    like replacing most of an equivalent conventional gearbox. ;-(
    T i m
    T i m, Jun 15, 2009
  18. T i m
    On a soft tuned engine like yours, I'd say it would be unlikely. They're
    a service item. My rollers run dry, and the engine is quiet aggressive
    for a scooter, plus I do a lot of town running about which means the
    rollers are up and down their ramps a lot.
    All scooter clutches run dry, the number of shoes just seems to vary.
    Try using after market parts, clutches do seem to be a lot cheaper.
    Variators vary, with the original part being cheaper on my one. There is
    a shop online that do lots of bits and bobs for 4 and 2 stroke, small
    and large scooters.
    http://www.scooter-center.com/1024-e.htm
    Muck, Jun 15, 2009
  19. T i m
    The revs sound right, the variator is doing its bit well. Dragging is
    bad in the clutch department, and will overheat things / wear them out.
    Mind you, too much wear on the clutch shoes and drum will alter its action.
    My clutch only fully engages after about 20 mph, until then it's
    slipping all the time. Keeping the engine pulling against the back brake
    helps low speed manoeuvring.
    Scooters tend to mount the engine / swing arm unit on rubber bushes,
    which makes for wibbly handling. I've got solid bushes in mine, and a
    modified engine mount to stiffen things up. Rear tyre pressure makes a
    lot of difference on my one, as does having any play in the steering
    head bearings.
    Variomatic is _the_ thing to have for small capacity machines. Ok, it's
    not as efficient as a conventional gear box, but it more than makes up
    for that by keeping the engine at the right speed almost all of the time.
    I think it was just some wanker trying to be funny.
    Interesting, but they've cheated in the pictures. The plate isn't in the
    same position in the two pictures.
    I'm already there with Malossi, Polini, mazzucchelli, Stage 6, PM and
    some Shiny Red custom made bits.
    Muck, Jun 15, 2009
  20. T i m
    T i m Guest
    Belt and rollers together typically then?
    http://shop.wemoto.com/pictures.dyn?u=2147797qqq5828248
    http://shop.wemoto.com/pictures.dyn?u=2147797qqq5828174
    http://shop.wemoto.com/pictures.dyn?u=2147797qqq5828502
    On that last one, do some variators come with a big spring like that
    as I've only got such a thing on the clutch?
    Understood. Have you tried the Dr.Pulley non-rollers?
    http://www.unionmaterial.com/rollerweight6.htm
    Doh, I meant to say 'variator'! The only other bike I've got with a
    dry clutch is the R100RT. (and it's very dry atm as it's in a box
    under the stairs). ;-(
    Ok ta.
    I did see the entire clutch (sheaves, hub, shoes, drum) on eBay for
    £100 delivered but I've no idea about the quality?
    http://preview.tinyurl.com/m3borr
    It looks identical to mine. Is a LINHAI 250 yet another machine that
    uses that engine unit. How many others are there!
    Bookmarked, thanks.
    Oh, assuming most scooter final drives are like the unit on this
    YP250, is there a good technical reason why they would spec an SAE
    10W40 oil in there and not the (more typical?) 80W90 'hypoid / gear
    oil'? Ok, I can imagine there would be a touch more drag with the
    heaver weight oil but would it be sufficient to want to use a lighter
    oil so potentially offer less protection?
    T i m
    T i m, Jun 15, 2009
