Ping centrepetal clutch fettlers.
Discussion in 'UK Motorcycles' started by T i m, Jun 8, 2009.
  1. T i m
    T i m Guest
    *Luckily*, WE didn't do many miles outside getting the scoot home but
    I've no idea home many miles the PO did with it like that (two missing
    clutch return springs). When he handed it over he did tell us how he
    overcame the initial startup_drag_engine_stalling thing and I thought
    it a bit strange at the time? Also possibly luckily I believe he only
    used it on straight (quickish) runs to_-from the airport so the clutch
    would have been locked most the journey?
    I was quite pleased to note that after about 20 miles of use the brand
    new clutch was showing signs of the fricitionable material touching
    the drum over nearly 3/4 their length.
    And I've looked again and the clutch disengages on the way down
    between 10 and 20 mph?
    And how hoes that generally affect the ride comfort? I ask because I
    did a suspension upgrade on the kitcar [1] ready for when I took out
    the 1300 Kent and replaced it with my 2L Pinto but I haven't
    gotroundto doing the engine bit and the front end is now very hard.
    I think mine was 34 PSI for our weekend test run (being between the
    solo 2 and 'above' 2.5 bar) but maybe I'll try it a touch higher at 38
    PSI?
    Ok (they seem ok).
    I think the power of the YP25 and the CB Two Fifty are similar but I
    think I"d have to work the CB quite hard to be able to keep up with
    the YP (to be fair the CB has 50,000 miles on the scoot).
    And how we laughed. Just like I did when I came out of college one day
    and found my Messerschmitt KR200 up on a flower bed. It wasn't that
    they had put it there that pissed me off it was how they put it there
    and the damage they could have done had it gone wrong (to the
    irreplaceable Plexiglass dome to name one bit). I found out who they
    Yup, I spotted that (but gave them it on a bit of poetic / marketing
    licence). The rollers on mine would never get that close to the edge
    of the centre plate (as confirmed by the wear pattern).
    Yep, *if* bikes were the only thing we were into and *if* we had more
    spare cash and *if* I had another 50 years left on this planet I'd
    probably play as well. ;-)
    T i m
    [1] Anti-roll bar arm, track control arm, radius arm, and steering
    rack bushes, strut inserts and road springs.
    T i m, Jun 15, 2009
  2. T i m
    Yes, the big spring is the contra spring that goes on the clutch pulley,
    they can degrade and need replacing. It's not a common thing to replace
    though. I usually keep a CVT service kit in my toolbox, that consists of
    a belt and rollers. Usually replace a few sets of rollers to one belt
    though. When the acceleration starts going down, I strip the CVT and
    check the belt width / condition and the rollers, then just replace
    what's worn.
    Wouldn't mind giving them a go. Someone else I know seems to use them,
    they last longer and improve acceleration apparently. But.. are more
    expensive. When I next get some money I'll buy a set.
    Heh... very dry.
    Small capacity Honda engines seem to crop up everywhere, I'd have
    thought they're the most widely used small capacity motor... who knows?
    I don't think the Chinese have the materials and production quality
    quite right yet. I'd be more tempted to go to a good breakers and source
    a nice 2nd hand one. I use;
    http://www.stainforthonline.co.uk/blackknight/
    I can't fault them at all, they've come up trumps every time for me.
    Good on prices too.
    I've seen bike shops put both 80W90 and 10W40 in scooter gear boxes,
    depending on what they had most of I guess. Personally, I put 80W90 with
    added molyslip gearbox treatment in there. Some scooter gearboxes have
    helical cut gears, some have straight cut gears, some run a mixture of
    plain / roller bearings / ball bearings. I'm happiest sticking an EP oil
    in there due to the potential for high temperatures. A non EP oil may
    just not be enough protection on a hot day with the throttle wound back[1].
    [1] No oil cooler, back drum brake generating heat and less than a tea
    cup of oil.
    Muck, Jun 15, 2009
  3. T i m
    T i m Guest
    Thought so, so why do they show it beside a variator kit?
    I thought it might not be. Once I'd seen how powerful it wasn't (when
    the guy in the bike shop held the spring compressed with his hands
    while I took the (pre loosened) big nut off) I didn't think it was one
    of those things that was under a huge amount of stress.
    Oh, they flat as fast as that eh? FWIW I'll keep an eye on these ones
    I trued up in my lathe (and still above the minimum diameter) and see
    how well they last. I will get a new set or two and a belt in ready
    though (good idea).
    Is that typically the first sign of issues then, lack of acceleration
    rather than top speed?
    I might too. ;-)
    So Honda made this engine did they?
    Yes, I think they are where now where Taiwan were when they first
    started (not geographically of course). ;-)
    Mind you, more and more 'Big name brands' seem to be getting their
    smaller models (or engine units thereto) from China now.
    Ah, thanks, another handy bookmark.
    Well I agree sometimes that is the case ... or they think it's a
    better solution or what they are used to. [1]
    Ok and if yours have been ok etc ...
    So it could just be a drag thing, thicker oil lowering the MPG etc?
    Mind you, I guess the CVT would offer less shock loads to the
    transmission than a manual solution?
    Indeed!
    Whilst on the subject of lube. The Service manual states 3 different
    types of lube for the CVT components. I know your variator runs dry
    (ruling out one) but what do you use on the clutch sheave pins /
    shaft, and the variator splines please?
    T i m
    [1] A guy I used to race EV's against (Cedric Lynch) developed an
    electric outboard motor and we saw him testing in on a 'Solar Canadian
    Canoe'. I say 'developed' as electric outboards existed but they were
    fairly inefficient and not suitable for solar powering. Most
    eoutboards place a traditional electric motor in the actual underwater
    part and bolt a prop straight to the motor shaft. Whilst this is
    direct drive the motors themselves aren't very efficient (electrical
    design plus water seal drag etc). So, on his unit he placed one of his
    highly efficient motors when the engine would be on an IC OB but there
    was still quite a bit of drag in the underwater part (because it had a
    bevel gear and bearings so had to be lubed and needed seals etc). So,
    he developed his own gears and bearings that could be lubricated with
    water and ran the casing with holes to allow water in and out.. ;-)
    T i m, Jun 15, 2009
  4. T i m
    It usually affects the vibration levels you get through the floor and
    handle bars. My engine runs pretty smoothly for a stroker, but still
    hurts me if I ride for too long.
    I should have said that it's a scooter, so it's not designed with
    handling in mind. People have modified the frames to much reduce the
    hinge in the middle thing though.
    If you're a larger chap, I'd try upping the pressure a little, say to 36
    at first. Does it have a two up tyre pressure listed? Decent rubber
    improves things a lot, both in grip and smoothness. I'm running Michelin
    Pilot Sport SC tyres, excellent in the dry, OK in the wet. They have a
    more progressive break away, not the sudden 'letting go' sensation like
    cheap nasty scooter tyres.
    Usually scooter steering head bearings are the older ball type bearings.
    You can get taper roller bearing conversion kits, which are worth it
    imho, when your old ones are worn out.
    I knew someone with one of those! What a strange device that was. ;)
    Well, I'm going to keep fiddling with my scooter until I can't any more.
    With luck I'll have the free time and health to pursue some nifty
    scooter related engineering projects in the coming year.
    Muck, Jun 15, 2009
  5. T i m
    It's been fine since I rebuilt after a numpty bike shop got to it and
    the gearbox ground its self to bits.
    Would prefer gearbox life over a theoretical (measily?) mpg increase any
    day. I bet you'd get better mpg increase by keeping your plug, engine
    oil and air filter replaced at a regular interval.
    Not sure, there are the shock loadings from the wheel? I know off road
    scooter racers use cushioned final output shafts to lessen instantaneous
    loads on the gear train. They're rather like the cush drive on a
    conventional chain driven bike.
    Now I use marine grease on everything as corrosion seems to be the
    biggest problem with scooter CVTs. The cooling air fan sucks in water on
    a rainy day and blasts everything inside with wet air. I used to use
    corrosion block grease, but ran out and haven't had the money to buy an
    more yet. Sheave pins?
    Heh.. still using bevel gears eh? I've got a design I came up with for
    something that does away with all that. :)
    Muck, Jun 15, 2009
  6. T i m
    They can be a source of trouble, and can sometimes get deformed by the
    pulley. I know my rear pulley turns as it moves in and out, this can
    distort and weaken the spring. There are little plastic sliders you can
    put between the spring and the pulley to prevent this happening. They're
    only really used if you've fitted a stronger contra spring though.
    On a good day, I can usually push the rear pulley back against the
    contra spring if I use the belt as a wedge. Mind you, it's time for
    diazepam and pain killers after. :)
    A mate (Gary) just told me he uses the sliding variator weights and
    they're good stuff. I'd be inclined to listen to him, as he knows his stuff.
    It's more a gradual process that one day you think.. hey, this is slower
    than it should be. My two stroke has a on / off power band, when things
    aren't right, the motor starts coming out of its power band when
    accelerating.
    I'll believe they've made quality improvements when I start hearing of
    less Chinese components like ball bearings failing.
    Oh boy.. must be getting tired, forgot to reply to all the post.
    Muck, Jun 15, 2009
  7. T i m
    T i m Guest
    Oh. ;-(
    Well, true, but I guess there is such a thing as OTT lube wise. No
    point having a perfect final drive and the rest of the bike worn to
    bits. ;-)
    Engine oil and filter (although the filter on the Maj is huge and
    cleanable) I'll give you, and if yours is a stoker I'll give you the
    plug <g> but thinking out loud, when did anyone actually have a plug
    fail on a std road vehicle these days? I mean, the plugs in the kit
    car have been in there 20 years and as far as I know they are fine? If
    I had to change all ~25 spark plugs I have in various machines here
    every year just 'because' it would be an expensive deal?
    Oh, good point then.
    Ah, I wondered why it looked a bit corroded *inside* the CVT casing.
    Is that across the board would you say? I think this Maj has a rear
    facing intake cover and a few fins and a filter before rain could
    actually get in there. I guess water vapour loaded air etc ...
    I bought some super marine environment proof white grease a while
    back. It was like putty and felt as sticky!
    Sorry, not sure if that's the right name for them ... the 4 (in this
    case) 'Pins' that guide the moving sheave (pulley face) open and
    closed on a spiral track?
    And more efficient I hope? ;-)
    Our kitcar front road springs also work that way (MkII Escort based),
    most vehicles even at the time had a bearing in the top mount.
    I was considering the 10 tonne hydraulic press but daughter power is
    easier and quicker. ;-)
    Any idea how much they cost and can you get them over here? If the
    traditional rollers need changing as often as you suggest then they
    could end up being a money saver?
    The funny thing was this lower tuned Maj was quite nice to ride with
    the dragging clutch as it pulled away from tickover with few revs.
    Shame it dragged at the lights etc though.
    I think that has been the case for ages though, skimping on the little
    bits because they all add up when making thousands of the things. My
    Clarke steel cutting band saw had it's bearings collapse and I
    replaced them all with decent (FAG I think) for about 20 quid. I think
    that's nothing on a £200 item but it's another 20 quid off their
    bottom line.
    Thanks for all the help / advice so far though ... all a brave new
    world for me (well, since my Lambretta SX150 anyway and I never needed
    to do anything to that in two years of daily commute).
    T i m
    T i m, Jun 15, 2009
  8. T i m
    When you're talking a tea cup full of oil, I'd be inclined to use the
    best stuff you can get. Less wear means less friction and heat.
    I use 'race plugs' these days, you know, the ones with the really pointy
    electrodes (It's late and my head is a bit fuzzy ok..). I'm not talking
    about plugs failing, I'm thinking of getting a nice fat spark and
    putting less strain on the ignition system. Hence getting a nice bang
    every time. :)
    Heh. When I finally CNC that custom crank case out of aluminium billet
    for my V twin two stroke, I'll get it anodized to help prevent all that. ;)
    The rear vent is usually an outlet I thought. There are usually fins on
    the end of the crank shaft pulley to pump cooling air through the CVT
    housing.
    Oh yes... I used marine grease on that too. The blue coloured stuff I
    think it was. Topped up every time I changed the belt.
    Could be, it reduces the parts count somewhat. That means cost savings
    in production, and a premium price for 'new' technology. :)
    I'll make myself a tool to compress the contra spring one of these days.
    Apparently, these people do them over here. http://www.crossan.co.uk/ .
    I've got one or two nice ideas for CVT related / scooter related
    engineering projects in the pipe line. Among them, push button
    selectable rpm for the clutch engagement. Coupled with some other
    things, it would give you a soft / medium / hard setting for power
    delivery. This would be useful in the winter.
    This twist and go scooter stuff was all new to me a few years ago,
    still, it's nice to pass on some stuff I've learned.
    Muck, Jun 16, 2009
  9. T i m
    T i m Guest
    Yeahbut <devils advocate mode>, lets say 10W30 actually lubricated the
    final drive to such a degree that it ran for 200,000 miles and with a
    fraction of the drag of 80W90 and saved even a few gallons of fuel in
    the process ...? <dam/off> I still believe it is possible to make
    things worse (actually *causing* overheating etc) by using to thick or
    to much lube, however, in the case of this final drive I don't think
    80W90 is going too far. ;-)
    I know of them but not used them. I'm old remember so have seen all
    sorts of plug designs come and go. In the days when 2/s would whisker
    their plugs easily they did one with a ground electrode that was free
    to rotate so break any whisker as it formed. ;-)
    Fair enough, so, can you actually tell when a plug has 'gone off' and
    what happens to the plug when it does and what do you do to fix it? I
    mean is it a gap adjust or clean etc?
    And I guess having that done won't be the expensive bit! ;-)
    It is, a fairly large rectangular port at the back / underneath. There
    is also a baffled drain hole at the very bottom of the casing.
    Indeed, what I meant to say was the actual intake to the CVT is via a
    rearward facing cowling. The intake is as you say at the front, driven
    by a crank mounted fan / variator pulley_sheave_half and the cover
    that sits over the filter has an input port that faces rearwards by a
    couple of inches, plus it's all sorta behind the side panels ... so,
    for rain itself to actually get in there you would have to be going
    backwards. ;-)
    So you would have to take the clutch off / down to do that (mines
    pretty well sealed up with 'O' rings and covers etc)?
    That reminded me of old technology ... my first scooter (when I was
    14) what in fact my Dads, then my Uncles Lambretta LD150, my first
    shaft drive bike. ;-)
    Mate in the bike shop initially lent me a tool he'd made up himself.
    It seemed pretty basic and whilst not as fancy as the pukka thing it
    looked like it would do the job. I might make one for myself (for when
    the Daughter-press isn't about) so maybe when I do I'll make a couple
    (and send you one)?
    Thanks, bookmarked and I've dropped them a line.
    That would be nice but I could see for most people / road work
    wouldn't it be set once then forgotten?
    You mean on your 'racing' type scoot or all machines?
    It all helps to paint the bigger picture ... how different people
    consider their mounts and what they like do with them etc.
    I quite like the satisfaction gained by bringing something that has
    been a bit neglected back to good functionality, partly because in so
    doing you often learn stuff you wouldn't otherwise (like I wouldn't
    have taken this CVT down had it been working ok) and that can help you
    use said machine better and / or be in a better position to fix /
    upgrade it when the need or opportunity arises. Like the replacement
    clutch I was given ... I wouldn't have recognised one as a potential
    replacement (as the part numbers didn't tally) had I not had need to
    closely inspect the old one to see why it wasn't working properly etc.
    T i m
    T i m, Jun 16, 2009
  10. T i m
    Well, engine and gear oils are tested differently... This may explain
    some of the differences. :)
    http://www.vintagetriumphregister.org/maintain/oil-overview.shtml
    If the electrode starts getting blunt, I replace, simple as that.
    I'll be doing the design and programming, a mate will be doing the
    cutting on his machine. I'll have to pay for a big bit of billet though.
    Your pulley assembly must be made differently to my one. There's a
    spacer that goes through the middle of my clutch, that comes out and you
    can then lube up the pins.
    It's useful to be able to launch quickly in traffic light races. It's
    also useful to soften things a bit when grip isn't too high. The new BMW
    super bike has different engine settings, it's got race / normal / rain.
    I think people would regard the ability to soften things up as a safety
    feature.
    On my two stroke, I've come unstuck a few times when the power kicks in
    when riding in the winter and the rain. Going sideways is fun, but
    falling off isn't.
    I like to understand things, then set about improving them. :) It's what
    I've been trying to learn how to do (formally) for the last 4 years. lol.
    Muck, Jun 16, 2009
  11. T i m
    T i m Guest
    Interesting ta.
    This was the sort of thing I was talking about (re using a 80W90 where
    a 10W30 was specified): "An oil with too high a viscosity may not pump
    to the proper parts at low temperatures and the film may tear at high
    rpm."
    Ah, no. The variator is like that but on the clutch that would get you
    near but not actually on the pins on mine.
    Agreed, on a 'super bike'. I would suggest the YP250 is already soft.
    And I also have some extra control with the handle on the right. ;-)
    Sounds fun. ;-)
    T i m
    T i m, Jun 16, 2009
  12. T i m
    It's a roller coaster ride that you pay for after having been on it.
    Muck, Jun 17, 2009
