PING : Electronic experts.
Discussion in 'UK Motorcycles' started by Borg, Oct 23, 2010.
  1. Borg
    Colin Irvine Guest
    Colin Irvine, Oct 23, 2010
  2. Borg
    Catman Guest
    Would be a bit of a bugger to store, that's for sure.
    www.cuore-sportivo.co.uk
    Catman, Oct 23, 2010
  3. Borg
    Catman Guest
  4. Borg
    Graham. Guest
    Graham., Oct 23, 2010
  5. Borg
    Alan Guest
    A most axial leaded thermal fuses are pointy at one end, although it
    doesn't matter which way around they are fitted
    Alan, Oct 23, 2010
  6. Borg
    TMack Guest
    TMack, Oct 23, 2010
  7. Borg
    TMack Guest
    Strangely enough he managed it OK in his second "go away" posting!
    TMack, Oct 23, 2010
  8. Borg
    David Paste Guest
    Or... it was a different person.
    David Paste, Oct 23, 2010
  9. Borg
    TMack Guest
    Quite right, my mistake. Apologies all round.
    TMack, Oct 23, 2010
  10. Borg
    Guest Guest
    Thermal fuses usually are.
    Guest, Oct 23, 2010
  11. Borg
    eamo Guest
    a fine collection of spellings, Sir, and no mistake. Where did you
    encounter them, or are they 'your own work'?
    Eamo the drunk mick
    eamo, Oct 24, 2010
  12. Borg
    Alan Guest
    A thermal fuse failure results in speeds 1, 2 and 3 not working but
    speed 4 working as normal. Two speeds don't gradually die - it's all 3
    bottom speeds with a thermal fuse failure.
    Speeds 1 and 2 failing is more likely to be the switch itself
    mechanically failing or one of the resistors in the green blob failing.
    The fact that you lost the fastest speed as well suggests the
    conventional fuse in series with the motor has now also blown. The
    thermal fuse and resistors play no part in the fastest speed setting.
    This failure may be a combination of failures
    Switch
    Resistor Pack
    Motor (conventional) fuse found on one of the fuse panels.
    Alan, Oct 24, 2010
